hehe, no one thinks like you
better post full and complete templates in the future to prevent confusion
icon: >
mdi:coffee-maker{{'-check' if is_state(entity,'on')}}
icon: >
Itâs not a problem of understanding. Iâm quite sure, the people you directed your post to, do understand your meaning.
But thatâs not the point here:
You are an experienced user with nearly 2000 posts in this forum. Whatever you write will not only be read by the people you direct it to, but by all users, even unexperienced ones.
If they take your example from above, they will get one or more errors. And thatâs whatâs not good. Like it or not, but you as experienced user have to look out for things, that could get a wrong impression or example.
Thatâs why context is needed, and an incompletly posted example will not help others in the future, if they find your post via the search.
I for one am quite sure, you mean well with these post, but sometimes they are not suitable without context for unexperienced users. Please donât get me wrong, I like to read your sometimes chaotic posts, and Iâm willing to understand them, but you canât set that as a standard for all users.
Please donât take that as criticism, I for one make enough mistakes on my own, so Iâm in no position to judge, but I wanted to explain that a little further.
No hard feelings!
Great work HA devs! Another awesome release! With the new thermostat look, it got me thinking⌠Is there a way to select a different temp sensor to act as the current temp of the thermostat card? The Nest app does a good job of this where is displays all the rooms I have a temperature sensor (including the location of the thermostat). In the evening I can select a kids room (which has a Nest temp sensor) and the thermostat uses the temp in that location as the current temp and will cool or heat the house so that room hits the desired temp. I donât think the updated card can do this, but just wanted to bring this up.
Respectfully, in the future, you may wish to consider putting as much effort into composing a functional Jinja2 example as you did in sharing your many thoughts about why you think it doesnât have a mistake.
I agree with you. Itâs demonstrated by your inordinately long reply, explaining why you think the (obviously flawed) example is fine.
is this a bug in the new Tile features?:
considering the color is set to follow status, I would have expected the slider to show the same color as the icon?
I donât think the tile card shows color there.
guess not.
Ive set them colors to:
state-cover-closed-color: maroon
state-cover-closing-color: blue
state-cover-open-color: gold
state-cover-opening-color: orange
state-cover-unknown-color: slategrey
and see the icon use that correctly. Itâs just that this bright slider really shows in my darker evening/noght themes⌠hurt the eye.
maybe Paul can have a look at that. Ill have a look at a FR in the Frontend discussion section
Itâs most like just a brightness slider.
If you considered it an âexampleâ , im so sorry , next time iâll just write
Have you tried using
[quote="boheme61, post:163, topic:611299"]
{% else %}
{% if
[/quote]
instead of {elif}
When i answer people who are pretty well knowledge in templates
So âmaybeâ i wont pissing of some people, who canât find better to do than picking on irrelevant details.
( if aceindy didnât understand, im sure he would have asked, but apparently i totally misunderstood his question )
The whole icon issue is clear and working, i just wanted to know if the same was possible in the template helper (as i wanted to move it from yaml to helper)
(i moved it anyway, the icon is âniceâ but not essential )
Post a Feature Request. Thereâs already one to have the Template helper support availability
For all of those having issues with supervisor not being setup, I tested a suggestion mentioned in the Github issue.
Enter Terminal/SSH and type: ha core rebuild
Home Assistant restarts and after that my supervisor is loaded in the integrations pane again.
I donât understand how core rebuild could fix Githubâs network issue. Have you restarted HA several times and it still works?
I changed my firewallâs DNS server to remap github.com to GitHubâs US server, that fixed the issue.
My curtains show the correct colour for the slider.
right but thatâs a position slider and not a brightness slider. Brightness in HA has always been yellow. Just like on a light without color.
Is that a brightness slider? It looks like a cover entity, so would be position as well (?), but I donât speak whatever language that is, so I canât be sure.
Same
If it wasnât clear, my tile card is for a cover entity also âŚ
Seems like it should reflect the colour of the entity then. Not sure why it doesnât. Whatâs the YAML for the card?
Thatâs Dutch btw.
