2024.10: Heading in the right direction
Thanks I missed that, I’ll try that.
Good tip. I also reverted back to old version. ( I dislike Telldus, but all the cheap tempsensors still needed :slight_smile: )
Got exactly the same. Up untill B12 nothing was wrong. Final it does this. Reverting back to b12 doest the same, now going back to a lower number.
Now on b8, stays up and running.
Will investigate tomorrow further.
I’m neither a fan of this unused area between badges and section title, don’t really know why it is there :frowning: However the new heading card with its entity feature enables complete new capabilities, so I have removed all my badges and added them to headings which looks much more better now, thank you for this feature.
Hi All,
Do we need also update those kind of platform parts in the automation?
from
    - wait_for_trigger:
        - platform: event
          event_type: ios.notification_action_fired
          event_data:
            categoryName: "DYNAMIC"
to
    - wait_for_trigger:
        - trigger: event
          event_data:
You don’t need to. But yes, those are triggers so you can update them if you want.
Then my OCD is running already to update them :slight_smile:
Well this is a bummer. One of my two HAOS systems continues to restart causing problems with automations. And worse, it’s my system at home that the family relies on. Restoring to 9.2 or 9.3 isn’t playing nice either. Lesson learned. Full backups before release updates. :confused:
Do you have alexa media player? If yes, check out the global banner.
Global banner?
Same here Google Cloud TTS stopped working for me too, unless it was trying to say something that was previously cached. Proper functionality of being to say anything I throw at it was restored by rolling back to 2024.9.3.
That’ll teach me not to try doing an x.x.0 update again for a while, I usually leave updates towards the end of the month, and I’m not prepared for life without my sexy aussie TTS :slight_smile:
Since 2024.10 update, all my matter devices are unavailable.
Matter server log shows this:
Is popup animations a “new feature” or a frontend bug? How do I disable it?
Popups now open too slowly. Even restart popup window now has this animation.
After failed attempt to update my HA keeps crashing… Not really a good first impression.
Are you using Alexa media player? If so, you know what to do.
Since in automation now we have
triggers:
  - trigger: homeassistant
then shall we use
{{ trigger.trigger == 'homeassistant' }}
instead of
{{ trigger.platform == 'homeassistant' }}
Traces still show a “platform”:
Well, this Doc is still telling us to use “platform”.
And still there is a non-plural “wait_for_trigger”:
- wait_for_trigger:
    - trigger: ...
    - trigger: ...
Completely uneventful update for me, which is nice. :partying_face:
Love the new graph colours. They work much better with both my day and night themes.
It took very little time to update all my automations and scripts to the new schema using find and replace in VSCode. Even though it is not actually required I did this to force myself to use the new schema to keep current when helping others here on the forums. Also the new schema makes a lot of sense.
That may or may not be changed, I don’t know. Either way, as I said before it is a work in progress. Expect more updates in future releases.
Out of curiosity, are other Firefox users finding that the new Heading card displays in their browser default font (in my case, DejaVu Serif) instead of Roboto?
I’ve seen this behavior before in other parts of the frontend, but this update makes it very apparent in Heading cards. I’ve recorded my observations in this thread and this GitHub issue.
For context, I’m using Firefox 130.0.1 (64-bit), Snap version, canonical-002-1.0 on Ubuntu 22.04.5 LTS (64-bit).
Win10x64, FF 130.0.1 - Roboto is used.
