Tried that…no luck…
Tried that too…no luck…
So where do i go from here ?
I’d love to use the new dashboard but now i can’t.
Anyway i appreciate your help. Thanks.
Tried that…no luck…
todays upgrade from 11.1 to 11.2 leads to incorrect sensor state phrasing. for example, previously my door sensors are said either OPEN or CLOSED. now all door sensors are showing as either OFF or ON.
ive verified the issue is with 11.2 after rolling back to 11.1.
11.1 -
11.2 -
anyone else?
edit:
measurement units seem to be affected too, as mine have gone missing.
and missing from some temp sensors
Have you tried refreshing your browser or cache?
that did it, thank you.
Hey there, i have a question. Is possible to repair Tuya integration?
Hi, I’m new here, wanted to add a +1 .
I since restarted HAOS (virtualized with proxmox, 4gb ram).
docker exec -ti /bin/bash into the homeassistant docker container
go2rtc uses up a lot of ram, and I don’t even have frigate or any camera integration installed.
Later edit: I am very gratefull for home assistant and this community, this is great!
Later later edit: I am probably out of my depth on the above, reading up on different aspects …
Another try after updating to 2024.11.2
Deleted default_config:
Added everything manually except go2rtc:
Addon RtspToWebrtc is running.
Restart HA
Cleared browser cache
Still slow and laggy camerastream.
They really messed up !!!
assist_pipeline:
backup:
bluetooth:
config:
conversation:
dhcp:
energy:
history:
homeassistant_alerts:
cloud:
image_upload:
logbook:
media_source:
mobile_app:
my:
ssdp:
stream:
sun:
usb:
webhook:
zeroconf:
I suggest you create a separate support thread then. Sorry I can’t help any further.
You can disable it by taking control of default_config
. It’s highlighted in an earlier post in this thread.
I have been unable to upgrade from 2024.10.4 I tried to upgrade to 11.1 and 11.2 and both time I get the following error:
024-11-16 08:13:15.427 ERROR (MainThread) [root] Uncaught exception
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 687, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 157, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 326, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 458, in async_from_config_dict
await async_load_base_functionality(hass)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 427, in async_load_base_functionality
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1977, in async_initialize
entries[entry_id] = config_entry
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1618, in __setitem__
self.check_unique_id(entry)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1659, in check_unique_id
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The entry unique id ['[email protected]'] is not a string.
Any suggestions on what is wrong, or where I should report this bug?
For my scenario, after upgrading from 2024.10.4 to 2024.11 - I can see python crashing in the CLI within like 15 seconds of Core starting up integrations - would any of the guidance here help? 2024.5+: Tracking down instability issues caused by integrations - when I checked logs before (admittedly not in debug mode) I didn’t see anything obvious causing startup issues. Should I try and turn on debug mode before upgrading, then attempt the upgrade again?
WebRTC OMG!! I have a page with 13 camera views that I hardly ever used, but now: pop, pop, pop… all visible within 20 - 30 seconds. an awesome performance improvement. Thank you!!
Hi All,
Is here someone who is using USB Modem to sending messages ? After update 2024.11.2 I have lost this functionality and errors look like below. Also I have noticed, that all statuses of entities are now not in Polish but in English.
Rejestrator: homeassistant.config_entries
Źródło: config_entries.py:3249
Pierwsze zdarzenie: 00:12:03 (5 zdarzenia)
Ostatnio zalogowany: 00:23:12
Error occurred loading flow for integration sms: cannot import name 'GammuAsyncWorker' from 'gammu.asyncworker' (/usr/local/lib/python3.12/site-packages/gammu/asyncworker.py)
------------------ ALSO -----------------------------
Rejestrator: homeassistant.setup
Źródło: setup.py:334
Pierwsze zdarzenie: 00:08:59 (1 zdarzenia)
Ostatnio zalogowany: 00:08:59
Setup failed for 'sms': Unable to import component: cannot import name 'GammuAsyncWorker' from 'gammu.asyncworker' (/usr/local/lib/python3.12/site-packages/gammu/asyncworker.py)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1011, in async_get_component
comp = await self.hass.async_add_import_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1071, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/sms/__init__.py", line 25, in <module>
from .gateway import create_sms_gateway
File "/usr/src/homeassistant/homeassistant/components/sms/gateway.py", line 6, in <module>
from gammu.asyncworker import GammuAsyncWorker
ImportError: cannot import name 'GammuAsyncWorker' from 'gammu.asyncworker' (/usr/local/lib/python3.12/site-packages/gammu/asyncworker.py)
File "/usr/src/homeassistant/homeassistant/setup.py", line 334, in _async_setup_component
component = await integration.async_get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1031, in async_get_component
self._component_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1023, in async_get_component
comp = self._get_component()
ImportError: cannot import name 'GammuAsyncWorker' from 'gammu.asyncworker' (/usr/local/lib/python3.12/site-packages/gammu/asyncworker.py) >
Entities status in EN (was wykryto):
Maybe a last question.
Is it normal i see this after deleting go2rtc in the default_config ?
Or do i have to make some adjustments in the yaml file ?
I don;t know how to explain this but after few hours now the same values are in Polish again (without, restart or other action from my site)
Regarding issue with SMS Gateway, still the same
I have 5 cameras: 3 - H265 (Dahua) & 2 - H264 (Hikvision) with
picture-entity cards for direct video output from cameras.
Frigate ver. 0.14.1 is installed (incl. go2rtc).
HAOS, generic-x86-64, bare metal system.
Everything works fine on version 2024.10.4.
After the update on 2024.11.2, picture-entity cards do not work for H265 streams, even through the existing go2rtc in MSE(mp4) mode.
Picture-entity card shows ordinary snapshot picture, but on tab/click it just minimizes to “only header-show” mode.
There are no errors in the logs.
H265 cameras only work with a ‘custom:webrtc-camera’ after installation of a WebRTC Camera, but this does not suit me.
How can I configure go2rtc or something else so that picture-entity cards will work with H265 streams at 2024.11.2 core?
Today i have upgraded to HA 2024.11.2 and wanted to try the logs streaming live!. Is this new feature reserved for HAOS or supervised installations? My installation is just HA in a docker container.
Has anyone else had trouble with Zigbee since upgrading to 2024.11.2? ZHA integration completely failed to the point I thought my SkyConnect had died. The integration failed to load and all Zigbee devices were unavailable. I tried reboots, a different USB extender, different ports on my RPi, and finally in desperation replaced my install from a backup from before the last update. That fixed the problem immediately.
I tried looking through the logs to find any errors, but because the integration wouldn’t initialize the ZHA integration page couldnt access the logs, and I couldn’t figure out what to look for in the log viewer in System. Anybody have any thoughts?
Are you using the build in integration or Webrtc as custom integration?
Well, never mind. Rolling back to an old backup worked for a few hours, and then the ZHA integration failed again and I’ve lost connection to everything. Guess it’s not the new update, at least? I’ll start a new thread elsewhere.
