Hi All,
Is here someone who is using USB Modem to sending messages ? After update 2024.11.2 I have lost this functionality and errors look like below. Also I have noticed, that all statuses of entities are now not in Polish but in English.
Rejestrator: homeassistant.config_entries
Źródło: config_entries.py:3249
Pierwsze zdarzenie: 00:12:03 (5 zdarzenia)
Ostatnio zalogowany: 00:23:12
Error occurred loading flow for integration sms: cannot import name 'GammuAsyncWorker' from 'gammu.asyncworker' (/usr/local/lib/python3.12/site-packages/gammu/asyncworker.py)
------------------ ALSO -----------------------------
Rejestrator: homeassistant.setup
Źródło: setup.py:334
Pierwsze zdarzenie: 00:08:59 (1 zdarzenia)
Ostatnio zalogowany: 00:08:59
Setup failed for 'sms': Unable to import component: cannot import name 'GammuAsyncWorker' from 'gammu.asyncworker' (/usr/local/lib/python3.12/site-packages/gammu/asyncworker.py)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1011, in async_get_component
comp = await self.hass.async_add_import_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1071, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/sms/__init__.py", line 25, in <module>
from .gateway import create_sms_gateway
File "/usr/src/homeassistant/homeassistant/components/sms/gateway.py", line 6, in <module>
from gammu.asyncworker import GammuAsyncWorker
ImportError: cannot import name 'GammuAsyncWorker' from 'gammu.asyncworker' (/usr/local/lib/python3.12/site-packages/gammu/asyncworker.py)
File "/usr/src/homeassistant/homeassistant/setup.py", line 334, in _async_setup_component
component = await integration.async_get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1031, in async_get_component
self._component_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1023, in async_get_component
comp = self._get_component()
ImportError: cannot import name 'GammuAsyncWorker' from 'gammu.asyncworker' (/usr/local/lib/python3.12/site-packages/gammu/asyncworker.py) >
Entities status in EN (was wykryto):
