Anyone has problem with last updated with Zehnder integration?
I am having this exact same issue. Do I have to set up an external docker (app) for this new integration to work ? The instructions are not clear at all.
It took like 3 minutes here until it started working. But fluent is the only option that seems to work for the most part. No comparison really to what I get with go2rtc addon and webrtc card using this configuration:
camera.doorbell_audio_mic:
- "ffmpeg:https://192.168.20.157/flv?port=1935&app=bcs&stream=channel0_main.bcs&user=XXX&password=XXX#video=copy#audio=opus"
runs flawlessly at stable 20fps for hours even without any stutter and stays in sync with both video and audio.
UPDATE: It stopped working
We either need an option to disable Webrtc or get a way to configure go2rtc properly.
And how to change that in, say, picture-entity card? (i think iāll just keep and use your card for nowā¦)
My developer tools is flooding!
Lots of 404 since the webrtc updateā¦
Like 30 extra lines in just a second
some one using GitHub - brunosabot/streamline-card: Streamline your Lovelace configuration with with a card template system.? seems to be broken in 2024.11
I have a question about cards without visual editor support using precise mode in section layouts:
Iām currently using button cards from this HACS repo: GitHub - custom-cards/button-card: āļø Lovelace button-card for home assistant
Those buttons donāt have a visual editor. Therefore, Iām using YAML for the configuration. In my old dashboard, I had set them up in a way where I had 3 buttons per column. This wasnāt possible when I moved to a section view dashboard as the width of the column was split into 4 parts. Currently, I have 4 buttons per row and I was very excited about the new precise mode when I read the change log yesterday as it made it possible again to have only 3 buttons per row.
Unfortunately, I canāt figure out how to make that work with the YAML configuration. I changed other cards which have a visual editor into precise mode and had a look at the generated YAML.
It seems as if the āgrid_columnsā-parameter will just be set to 4 if the card fills a third of the row. This makes sense as the 4 unprecise parts of a row is split into 3 parts again which makes 12 of which a third equals 4.
But when I try and set the grid_columns of my custom card to 4. They act as if I set it to 4 of the 3 unprecise parts filling the entire row.
Am I missing something here? Is there maybe another boolean which I need to set to true for precise mode? Or is this simply a bug with cards without a visual editor or my specific card?
Maybe someone of you can help me. Thanks!
Hello, I wanted to put 2024.11.1 but my SAMSUNG cameras no longer work,
So I restored 2024.10.4.
Thanks for seeing the issue. I have the message: Failed to start WebRTC stream: Unknown command.
To get my Unifi Protect cameras streams working after the upgrade I had to clear cookies and site data in Firefox and sign in again. On Android native app, I had to close the app with a swipe up.
from the release stream:
Supervisor logs with Previous button and some other 3 dots menu
Local Supervisor however:
I do see this:
proving it is the new Frontend for the logs.
Any setting we need to enable there?
Yes, same with me. Rolled back to 10.4.
Sorry I had to rollback and for the moment hide this new update becauseit broke my EZVIZ cameras integration.
Perhaps the camera_view
needs to be set to live
instead of auto
. I believe auto will use image thumbnails.
For now, the order is preserved for predictability, there is currently no way to achieve that without a custom view.
You donāt have overflow and previous boot because because you didnāt rebooted your machine since the update so you donāt have previous boots. Try rebooting it, it should appear.
Some fantastic news for HA with LG providing the ThinQ integration themselves. Hopefully this will be the start of more manufacture led integrations!
Add this to each one and itāll be 1/3rd column wide
grid_options:
columns: 4
rows: 2
Not clear to me: Since I am running Home Assistant on Docker, do I have to add an extra docker container or configuration to get this WEB RTC thing working?
Itās built into Home Assistant core, which Home Assistant Container sets up. So you donāt have to add anything extra, just update your Home Assistant Container.
WEBRTC changes the aspect ratio of my camera feeds. i rather have the 3 second delay than this changing my view on the cameraās.
