2024.12: Scene you in 2025! 🎄
Hi :wave:!
Try to reconfigure that connection.
If the issue persists, please create a GH issue or a new thread here for that. Feel free to @-ping me in there.
actually it is off by default, you have to edit assist settings to turn it on
report here: Issues · Tasshack/dreame-vacuum · GitHub
same setting as you, my whole home assistant container is 1.8gb at the moment, but I never tracked its size
It is no secret: our voice hardware will be revealed on 19 December 2024.
What does that mean?
All mine (sunrise and sunset triggers) have been working.
Check your underlying OS time (not HA system time). Check your HA location has not changed (unlikely).
My zha stoppt working. Downgraded to 2024.11.3 zha worked again.
nothing relating to this issue.
good point… looking at the Host log it is currently scrolling through log entries saying ~8:45am but it is currently 4:45pm (Perth, West Aus). Is that time supposed to be localised or is that supposed to be GMT? (if it’s GMT then that’s fine)
Time zone setting is fine:
Yes it is.
Seems to be a simple fix, simply add the context of the last few commands or the current conversation into the A.I. Would not be surprised if a developer reads this and adds this in the january release :slight_smile:
Do we not get a little teaser or preview of this big hardware announcement?
those shouldnt be causing any change at all because:
this is not a breaking change , and there will be no deprecation
you can forever keep your former syntax, search elsewhere for your trouble
Please be aware this update breaks the Overkiz local integration.
Details here…
SmartIR are not working in this Version!
I have switched back to version 11.3.
Best regards
Gunter
what version of Dreame vacuum (custom component) are you using?
I am on 2.0.0b16 and not noticed any issue with the integration.
If you are still on 1.0.4 I would recommend to switch to the current 2.0 beta version (which is quite stable) - since the 1.0.4 was not updated since may.
Thanks for the update, was a smooth one… it’s a bit odd, but somehow, I miss the work on adding new design options to my dashboards… :smiley:
With 2024.12.0 core update, my Shelly devices were no longer available in HA. After restoring my HA 2024.11.3 backup, the Shelly devices (Dimmers and Plugs) are available again in HA. I noticed a bug report on GitHub [BUG]update home assistant core to 2024.12.0 breaks em · Issue #782 · StyraHem/ShellyForHASS · GitHub
I have 2 HA boxes, one is running 1.0.4 without any issues after the upgrade. Second box I am about to upgrade now.
The map takes a while to load in after a reboot, but that is on both boxes.
the map will be extracted from the cloud, so I don’t think, that this is a HA or a topic specific for the integration… :slight_smile:
But glad, that the 1.0.4 is working for you.
That indicates, the issue for janip81 is probably not an issue specific to the dreame integration, but might be a conflict with something else.
ShellyForHass will no longer receive further development updates. This decision stems from the fact that its features and functionality have been seamlessly integrated into Home Assistant, making it redundant to maintain a separate plugin.
https://github.com/StyraHem/ShellyForHASS
