You should migrate to the core Shelly integration.
Fix is comingā¦
Done!
I use the version 2.0.0b16 and how tried redownloading integraton too, have no idea why its not working. Only thing that worked for me was to roll back to older container image
ZHA and Overkiz are broken by 2024.12, reverting back to 2024.11 and no issues.
Change to this updated and maintained version of SmartIR:
I have 2 of these and both triggered just fine last night and this morning.
Not the best experience if you are doing some midnight tinkering and accidentally activate a scene that turns on all the lights in the house, waking up everyone.
Damn, it really happened to me exactly like that (not turning on the lights but opening the shutters.
This would be a solution to the problem that the agent is not aware what the last prompt was but one of the benefits of trying it first locally is that it reduces costs. The LLMs are not (completely) free. For example the Google LLM is free for some amount of requests but if it is exceeded, it will cost you money.
I never tinker or update when its dark. Always wait to next morning!
Yeah - that is so annoying. Now it has been stable for a few weeksā¦
With 2024.12 if HA is set on Slovenian language interface some of the text is in scandinavian language.
How come NordPool integration is listed as a ānewā integration in 2024.12 ??
Iāve had the Nordpool integration for many years!
Alexa media player still broken in 2024.12?
It was custom before, now itās built in. I do not know if the feature parity is the same as the custom integration. Your custom integration will overwrite the built in one, so thereās nothing to worry about if you are still using the custom integration.
My guess, not the same developer.
Also looks like different output, but I have not tried the ābuild inā
Yes, and itās likely to be broken for some time.
Upgrading hass-core on a Raspberry Pi 3 running Raspbian/Debian Bookworm (i.e.: current stable) breaks on PyAV:
(venv-3.12) pi@hass:~/.homeassistant $ uv pip install -U homeassistant
AV_CODEC_FLAG2_NO_OUTPUT
src/av/codec/context.c:15851:48: error: āAV_CODEC_FLAG_FRAME_DURATIONā
undeclared (first use in this function); did you mean
āAV_CODEC_CAP_FRAME_THREADSā?
15851 | __pyx_t_2 =
__Pyx_PyInt_From___pyx_anon_enum(AV_CODEC_FLAG_FRAME_DURATION); if
(unlikely(!__pyx_t_2)) __PYX_ERR(0, 76, __pyx_L1_error)
error: command '/usr/bin/gcc' failed with exit code 1
INFO:homeassistant.util.package:Attempting install of numpy==2.1.3
Incorrect config
General Warnings:
- Integration error: default_config - Requirements for stream not found: ['av==13.1.0'].
Successful config (partial)
And apparently we came from the Hass AV fork ha-av 10.1.1
and upgraded to upstream av 13.1.0
. Unfortunately that depends on ffpmeg 7.1 while Bookworm comes with version 5.1.6.
Thereās no newer ffmpeg version available in Debian Backports, so I might end up building the package from the source package in Debian testing. Now I only need some timeā¦
FYI you are correct, they are different developers
True. Iāve been told that some swedish guy was translating into slovenian file instead his own⦠i changed to english for now. From what i saw on ālokaliseā over 3000 words are overwritten, so unless thereās any kind of backup there weāre fu**edā¦
