2024.2: More voice, more icons, more integrations, more... everything!
You can try it, it works for me without problems.
This update has totally killed my ability to view HA in iframes. Anyone else got this issue? Iā€™ve had to revert to the previous version after two solid days of trying to rectify it. Canā€™t see anything in breaking changes about it. Any help?
Is it same?
Yep, same issue. None of the suggestions there fix it.
EDIT: Yes, it did fix it, thanks.
You just need to name the iframe name=ā€œha-main-windowā€ then it starts working again.
<iframe src="xxxx" name="ha-main-window" ></iframe>
Weird, but it fixed it for me.
2024.2.2 break ZHAā€¦ cannot connect to my Athom brigdeā€¦ ā†’ rolledback to 2024.2.1
Rather than debugging and helping others?
No i haventā€¦ still running 2024.1.3
I noticed there is an update for HLS:
But still no updated frontend in 2024.2.2 with this changeā€¦ and i dont know if it will fix the issue but its really annoying :frowning:
lost on the purpose for this PR ā€˜fixā€™ in Fix cpu percentage in System Monitor by gjohansson-ST Ā· Pull Request #110268 Ā· home-assistant/core Ā· GitHub
Fix cpu temperature percentage in System Monitor.
A return of 0 is a false value so we should return None on such to declare unknown
As I had already installed latest dev install (to test the magical state_translated() template functionality), I had noticed that the former 0% now are replaced by unknownsā€¦
The move from the former perfectly fine implementation for processor percentage before the move in 2023.11(which brought about the useless/faulty 0% and 100% extrema) brought us trouble, and now we have hidden troubleā€¦
why dont we return to the original functionality of a reliable processor percentage instead of continuing on this flakey road
remains like this for an hour or so, and then keeps returning.
For those who use the Motion Blinds integration to control TDBU blinds (Top Down Bottom Up): the 2024.2.2 release breaks the integration, so you may want to wait untill that is fixed.
2024.2.2 Erratic reporting of System Monitor CPU use, instead of zeros the entity becomes unavailable
2024.2.1 System Monitor CPU would drop to zero
Export data from history dashboard, great new feature which highlights the problem further
Drag and drop in Automations ist great, but does not seem to work on the android mobile app, only on desktop? Or am I missing something?
It would definitely be more helpful on the small screen for meā€¦
The same for me. After update CPu state became unknown
Someone can help me please?
From the 2024.2.1 i canā€™t update to 2024.2.2 without this problem;
[Error returned from Supervisor: System is not ready with state: setup]
Raspberry Pi3-64
Everyday I keep getting the following about the Tuya Integration and have to re-authenticate. Anyone else having this issue ?
Log details (WARNING)
Logger: homeassistant.config_entries
Source: config_entries.py:468
First occurred: February 16, 2024 at 10:00:06 PM (1 occurrences)
Last logged: February 16, 2024 at 10:00:06 PM
Config entry ā€˜[email protected]ā€™ for tuya integration could not authenticate: Authentication failed. Please re-authenticate
Yep, youā€™re totally right, Tom! Iā€™m even editing my previous post to clarify what you said, sorry for having being ambiguous.
I got surprised someone from Tuyaā€™s end thought about getting a simpler way for HA to authenticate to their APIs, even though they do :poop: work with their APIs as I mentioned, and never ever got back to the Tuya integration tracker to check what the heck 20% of the HA users could be talking about.
Edit: looks like it wasnā€™t even direct work from the Tuya team - as someone else in the thread commented, instead they wrote a HACS integration for SmartLife which probably started with the new auth method; no clue why they didnā€™t integrate that directly on the main integration, and instead created a ā€œrivalā€ integration?? lololol
And to those that usually point at Tuya users as ā€œitā€™s your fault for having chosen thatā€, itā€™s important to notice that many people donā€™t live in countries with diverse automation options as the USA or Europe. The choices here usually are to either ā€œliveā€ with whatever Chinese companies do with the Tuya chips and sell on AliExpress, or donā€™t automate a lot of stuff. Brazilian tech companies are, guess what, rebranded Tuya devices, and even then, they only sell very basic stuff like plugs, lights and cameras.
So, yeah, while I had an option to not buy Tuya, itā€™s not like there are other options to actually do what their devices are supposed to do. Not for me, not for many of the users stuck with Tuya.
Not that it bothers me a ton, but you might want to stop using the term ā€œMaster Bedroomā€ in your screenshots. Sort of a legacy term that can be offensive to some. Same with black/white list. Primary or Main Bedroom, block/allow list are the updated terms.
I have successfully used oauth with home assistant for a decent while now. Authentik has a guide but it could also be done with any oauth provider and an oauth2/oidc proxy such as oauth2-proxy and nginx or traefik.
While it is frustrating that it is not built in to home assistant if you are an advanced user (which I would consider setting up oauth advanced) then using a proxy to inject header auth from oauth authentication should be within your abilities.
Updating to 2024.2.2 broke my SIA Alarm Systems integration. Both the Sia integration and the Alarm system itself (Ajax) report no connection anymore.
