2024.3: Drag 'n Drop it like it's hot! šŸŽ‰
Not sure what you mean by ā€œregressionsā€ , but i believe it pretty much describe the complexity.
In 2024.3.3 there seems nothing related, in 2024.3.2, you find the latest ā€œupdateā€. ( Which solves some parts ) … so ā€œregressionsā€ does not describe which issue you are ā€œwaitingā€ for to be solved.
If you follows the various ā€œbumpsā€ and ā€œwork- in progressā€ , you might figure out if your particular use-case, is addressed ( start by follow-up on the bug-report you commended in, and follow the links to the discussions/work there, maybe you can even contribute with your findings )
Sorry, how your post is related to my post?
Updated to 2024.3.3 this morning and getting the following errors on my dashboard:
Custom element doesn't exist: mini-media-player
Reverted back to 2024.3.1 backup and all is working again.
Like the standard software term?
ā€œa type of software bug where a feature that has worked before stops workingā€
SNMP device trackers worked fine up thru 2024.2.5 and was broken in every 2024.3.x I’ve tried thus far and isn’t a listed breaking change. Rolling back fixes it.
That’s what these new version threads are, no? Discussion of revision bumps and changes?
Something like that yes, but if you ask me, i believe the ā€œroot-causeā€ is the previous( early ) upgrade to Python3.12, Apparently there are not only undiscovered bugs(beside those which have been revealed) in in this ā€œearlyā€ release of Python-version, there might also be changes/enhancement, which could be hard to predict the impact of.
So as you are a software-developer(Professional), you can just feel ā€œluckyā€ that your not a part of the ā€œback-endā€ , which have to solve this situation. :wink: , beside ā€œRollbackā€ and Lean Back , and watch your Favorite Weekend TV Channel
I wish it was as easy as re-writing the automations. That’s what I have been doing over the last 2 days. Anyhow, thanks for the help…
Yeah, atleast you still have a working installation, and don’t have to start from scratch again
Make sure to perform a full backup, when you get things running properly again
PS: I was Shocked !, when they implemented this ā€œobscuredā€ Device_id, was thinking WTH, atleast i didn’t have 2 dozens automations, with Device_Triggers, and for most i could use ā€œStateā€ as Trigger
Please speak English.
After updating Core to 2024.3.3 my Home Assistant dashboard cast to Google Nest Hub 2 is not working properly.
After about a minute from the start of the cast (service call Google Cast: Show dashboard view) the Nest returns to its picture slide show (screensaver). What I can see the Home Assistant Google Cast integration thinks its casting. Logbook does not show any new events.
I restored 2024.3.1 and everything is again working as expected. I’m running Raspberry pi 4, HAOS 12.1.
Any advice what to do?
Forgot to mention something possibly relevant. I use Nabu Casa.
I just upgraded to 2024.3 and have a major dhcp issue.
Here is the log entry:
Logger: homeassistant.setup
Source: setup.py:296
First occurred: 8:33:53 AM (1 occurrences)
Last logged: 8:33:53 AM
Setup failed for 'dhcp': Unable to import component: No module named 'scapy.modules.six.moves'
  File "/usr/src/homeassistant/homeassistant/loader.py", line 886, in async_get_component
    comp = await self.hass.async_add_import_executor_job(self.get_component)
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/loader.py", line 921, in get_component
    ComponentProtocol, importlib.import_module(self.pkg_path)
  File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 995, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/usr/src/homeassistant/homeassistant/components/dhcp/__init__.py", line 16, in <module>
    import aiodhcpwatcher
  File "/usr/local/lib/python3.12/site-packages/aiodhcpwatcher/__init__.py", line 10, in <module>
    from scapy.config import conf
  File "/usr/local/lib/python3.12/site-packages/scapy/config.py", line 25, in <module>
    from scapy.base_classes import BasePacket
  File "/usr/local/lib/python3.12/site-packages/scapy/base_classes.py", line 32, in <module>
    from scapy.modules.six.moves import range
ModuleNotFoundError: No module named 'scapy.modules.six.moves'
  File "/usr/src/homeassistant/homeassistant/setup.py", line 296, in _async_setup_component
    component = await integration.async_get_component()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 892, in async_get_component
    comp = self.get_component()
Things I have tried:
  1. Revert installation - everything works
  2. Home assistant safe mode to see if a custom component is an issue - still has dhcp issue
    3 I noted in the change log :" Bump aiodhcpwatcher to 0.8.1 (@bdraco - #113096)". I used pip install aiodhcpwatcher’ in terminal to upgrade to version 1 and rebooted - same
    Issue with dhcp.
This prevents all my esphome devices from connecting, so it is a major issue for me.
I’m surprised that this does not seem to be affecting anyone else. What could be the issue?
I opened a core issue for this.
Well that was fast! The excellent support provided by Nick Koston quickly identified an issue with a python library component - scapy.
It turns out that one of the custom components I installed was downgrading the library version, making it incompatible with 2024.3.
An upcoming 2024.4 release will prevent downgrading by custom components in the future
Fantastic support!
Solved. To circumvent previous problem I had called cast twice. Now as that problem does not exist anymore the second call caused this new problem. Removed the second call to cast and everything works.
Browser_mod development is picking up again via my fork, known as the Phoenix Version. See 2.3.4 discussion.
