2024.3: Drag 'n Drop it like it's hot! šŸŽ‰
First thats a horrible way to find out, it literally just released the build process. Give it a few minutes and have a little patience.
That said, anyone who has UniFi protect and wants to upgrade to 3.x on thier devices needs this build…
Once I’ve successfully updated to a 202m.n.p version, and never p=0, I tend to update to all the subsequent p versions.
Been falgged on forum many times…always available here
Edit: and it is in the blog post too
I was too quick! :rofl: :rofl:
same problem here! all my to-do-lists are going
just did the newest update and my list came back.
I’m not certain why you think I’m avoiding this question. I don’t recall this being asked for. Anyhow, the integrations are Zigbee Home Automation, Tuya, SmartThings, LocalTuya, Google Cast, Alexa Media Player and Mobile App.
I have 2 HA instances running. One for testing the other is the main. It only happened on the main instance
in other words, you can’t hardly ā€œblameā€ the updates, beside you can Roll back and it works !
Which make your ā€œdirect questionā€ to Tom, redundant, as you can just copy the working parts, and paste in the non-working
Another step could be that you go through the discrepancies you have in your ā€œMainā€ , as it works in your ā€œTestā€
IF You use the ā€œsameā€ integrations And Devices ( And Automations ) in both installations, i have no further to say, as different devices/integrations act differently , under such circumstances
Unfortunately these are not identical. In my test instance of HA I don’t have Zigbee, but many other things are the same so just coping the working parts and pasting isn’t an option
I Mend, you roll back ( you said it’s working ), copy the parts you asked Tom ( in a cryptic way ) to ā€œretrieveā€ with a template
Then Update, make sure to add Debug-level( In Logger ), if you are interested in specific Components detailed logging, or All
PS: I always/periodically click ā€œDownload Diagnosticsā€ for i.e Integrations/Devices, feels safer to ā€œlookupā€ here than ā€œscrollingā€ in a .storage-doc
I don’t know how to ā€œretrieveā€ this info with a template. Comparing the core.device_registry many ā€œidā€ have changed, so the automations (- device_id: ā€œā€) is empty.
Right, and maybe there’s no need to think of a template, to get this info(if it’s not in the device_registry, where you you retrieve it from, with a template ? ) , either you roll back, or open a previous working backup-file, there you have your ā€œoldā€ core.device_registry (plain txt json)
Noone can tell what’s happening in your system ( one of them ), not why the device_id’s are empty, nor why your automation is( but that’s most likely because you use ā€œdevice_triggersā€, so this non-user-friendly id, is used/retrieved from the *registry-file
So if you want to know more, roll back, to working version , enable debug , upgrade, maybe you get more info then
At least with a template I can compare the old with the new. Can you point me in the right direction for this ? I don’t appear to have the skill set to create it in Developer Tools Template
If you for some reason unknown now have ā€œnewā€ i suggest you just rewrite your automations, im sure you know which Devices you used in which automations, rewrite them.
And don’t use these ā€œobscured randomā€ device_id’s as triggers, use i.e state
No i can not "direct you in other directions, as i have no idea, for what reason you want to compare new(current) ID’s with Old ID’s , nor what you want to do with this ā€œlistā€ , which you as mention can find in a back-up( or a rollback, as you self mention )
Many ā€œtextā€ editors can compare 2 files,
Copy your current *registry-file, and the one with your old -device_id’s, compare them in the editor of choice. For what ever reason
So these 2 last suggestions, is what you should/can do , to make life easier for your self
You don’t even know what you want to do with this ā€œcomparedā€ list, AND you can’t use the old ID’s ! ( unless you roll back, and stay there )
Just pulled Docker image for 2024.3.3 and confirmed UniFi Protect integration using pyunifiprotect 5.0.2 works with the latest Protect 3.0.22 version running on my UDMProšŸ‘
Does anyone know if 2024.3.3 fixes the SNMP regressions that have plagued the 2024.3.x releases?
Has anybody else noticed that TRACES no longer shows the last RUN of an automation?
The condition prevented the run of the automation, which was expected.
However I cannot see the trace from when it was actually ran!
Well you got lucky then! I just updated to 2024.3.3 and two of my todo lists are still unavailable… Even with trying to manually fix them I’m out of luck.
EDIT: had another crack at editing the ics files and managed to recover the two lists.
To be honest, @TBH im not ret the first part of this page i still accutafte baucuse i find no way to cotnact the poeson of the @OP:
