Thank you. I managed to fix it, according to the instructions.
Edit important
Just did a full system reboot instead of restart of hass
And
That does the trick!
After initial update (early comment)
As many updated
but canā reach the internal menus of integrations (hacs and official)
Neither can I open backups f.e.
Functionwise it is working
Hacs keeps working but wonāt open(white screen)
z2m works but canāt open (white screen)
glances doesnāt open
backups keep loading
Energy +configuration works completely
! WARNING !
2024.5 broke zigbee for some people (myself included). If zigbee is mission critical for you, you may wish to hold your horses before upgrading.
! WARNING !
It was my case, zha failed after upgrade, I have gone back to the previous version
Since this last update the WAQI gives errors:
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '3307', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '2676', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '3311', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '2669', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '2674', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '2673', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '2671', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '3310', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '5386', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '3560', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.958 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '2672', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '3309', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '5106', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '7934', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '2668', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '4583', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '3716', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '2675', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '5879', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '5880', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
2024-05-02 08:48:07.959 ERROR (MainThread) [homeassistant.helpers.entity_registry] 'sensor' from integration waqi has a non string unique_id '5102', please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+waqi%22
There is a issue logged already on Github
Dear Homeassistant Team,
by viewing the 2024.5 Release Party, install the version directly to the system.
After restart some pages from the Setting dialog like Home Assistant Cloud are shown āError while loding pageā. This will be at Cloud, Integration, Automation, Areas, Dashbords, Voice-Assistant and so on. On System the Page will load but page general, repairs, logs, analytics, network, storage and Hardware are also not loading.
Browser cache refresh?
simple mistake but clears all errors. Thank you for the Tips.
Anyone find some switches really slow now?
you click on the webpage, the device then sorta hang on click turns on.
With some itās so slow the switch in the gui goes back to the off position, you hear the plug turn on and then the gui goes no wait, it is on and puts it back to the on position.
Used to be instant either way.
You need to tell more about what device, what integration. But these type of problems are often indicative of communication problems for Zigbee or Z-wave.
Same here!!!
Keep reading. They managed to roll back to the previous version: 2024.5: Just a little bit smaller - #21 by Fonzy0083
Then they were advised to find out why it happened: 2024.5: Just a little bit smaller - #32 by tom_l
But we have not heard anything since.
Thank you for the ability to rename devices (entities) used on the energy dashboard. Thatās a very welcome one.
In my case I managed to fix the issue of restart by disabling a custom integration in the very short time I had the UI available. In my case the custom integration causing a memory fault was Dreame Vaccum. If the UI becomes available for a short period of time you need to see in the startup messages in the UI what is the last custom integration that is loaded and try to disable it as soon as possible.
After update Node-Red custom sensors no longer show up.
Did a roll-back to previous version (replacing entire VM with nightly backup).
When is this issue will be addressed? Does anybody know?
Energy Dashboard doesnāt display āconsumed solarā in some scenarios #13701
You are right. Usually I only ensure to do a backup prior to .0 release. Can you share a procedure on how to chose the version prior to the reboot, I was completely stuck but I managed to disable the custom integration causing the issue, during the 30 seconds window I had prior to the crash and reboot
As some already mentioned: HA starts up, then gets stuck and somehow claims all memory (something stuck in a loop?) and gets killed by the kernel because of OOM.
Downgraded back to 2024.4.4 and works ok.
Same here - but downgrade to 2024.4.4 worked ok.
