I tested running an automation using Assist, but it only enables / disables the automation instead of running it? Using ChatGPT in Swedish. Perhaps that particular configuration isn’t working properly, or are there anyone else having the same issue?
(Yes, I remembered to add the automation to the assistant)
I’m stupid. Somehow I thought the update was the automations that were added and could be executed, but it was the script. I’ve tested it and it works perfect
May want to add a note if you can’t see the Layout tab on the cards to clear cache. Was raking my brain on Firefox why I didn’t have the feature. Looked at Chrome and it was there. Cleared cached on Firefox and it appeared.
I tried resize new feature, 4 slot tile card with brightness now taller than before. Before it occupied less than 2 rows and looked more compact (nicer). Now the limit is 2 rows.
Some ideas:
I would like to select grid with the cursor like in Excel
Maybe empty space filler card to create a small horizontal gap? Or configurable horizontal gap where you can set size of the gap.
hm… I’ve heard about this issue from others as well.
I am not sure about the root cause of it, but there was a PR for adding the HmIP-ESI devices…
It also appears, that the upstream-library (homematicip-rest-api) was probably rewritten - this might have caused this issue.
Unfortunately, it was not mentioned as breaking change in the PR by the code owner… and it also seems, that no one with Homematic IP integration participated in the beta-test.
Then, this would have been noticed earlier
It looks like a nice release but unfortunately, I can’t use it because it forces my HA-setup into recovery mode!
And in recovery mode, it fails to load the logs so I haven’t managed to debug it. The only option was to revert to my backup of 24.6.4. I suspect one of my HACS integrations of course but hard to know which one.
ODC grants you a limited, revocable, non-exclusive, non-transferable license (without the right to sublicense) to use the Software solely for your personal use on your Home Assistant device in the continental United States and Canada
yep, only for ESP32 right now. you could probably create custom voice recognition sentences that would create a timer. maybe use LLM to perform the actions.
Aladdin Connect has been removed, as Home Assistant cannot use the upstream library at this time.
I replaced our garage door openers with Genie branded ones, and was planning on getting the Aladdin Connect hardware soon to add them to Home Assistant. If Aladdin Connect isn’t supported anymore, does anyone have a good way to add Genie garage door openers to Home Assistant?
Note to myself!
Always double-check the braking changes twice! AND remember to remove deprecated stuff when you get a notification.
I forgot to remove the old legacy API password configuration.
I just finished upgrading HA as well as upgrading my ESP32-S3 box to the latest ESPHome, and I’m still getting “sorry, timers are not supported on this device”.
Is there something I’m missing?
EDIT: It looks like my device is still on 2024.5.0, even though I’ve tried to update it and ESPHome no longer shows an update.
Re: Card resizing: maybe in the next release we will see 2x more rows that would allow to resize cards height more, i.e. I am proposing to make a single “cell” 2 times smaller.
