they probably wont support templating out of the box, but ofc you can use the state-colors in themes.
Im sure that anytime soon, people will start to try and card-mod them like you wish, so give it some time.
I do not think that a change of a state should be considered as a CHANGE.
And I never desired this.
For me, the CHANGES are like âuser changed smth in more-infoâ, âuser chaged yaml â caused a change of icon, template etcâ.
Having a table of 5000 entities sorted by âchangedâ & redrawn on every change of âstatesâ object is nonsense.
If it didnât update based on state changes the UI would never show new valuesâŚ
we are not sure, but please read what Karwosts wrote about the inner workings of the Frontend on those pages. Its in the link I posted on Entities
exactly, and since the template entities are now added, this might very well be weighing in extra
seems to be a known issueâŚcheck the custom componentâs GitHub page for details
(itâs not a Core issue)
Thanks. I restored my last backup and got everything back.
I see no benefit of showing a âlast-changed/last-updatedâ column on the Entities table. It will only cause lags if a user decides to sort by this column (and seems that it causes lags even w/o sortingâŚ).
Adding a âchangedâ column is a good idea - but not all types of changes should be considered ))
There is a current effort to keep Alexa Media Player going but so far it is still ongoing and may be nearing an end: Alexa Media Player - Custom Integration - On Life Support - Help wanted
Anyone else getting bluetooth warnings on startup after updating? I keep getting âhci0 (D8:3A:DD:22:D9:DE): Successful fall-back to passive scanning mode after active scanning failed (4/4)â
So badges are (1) a new card type which also has (2) the unique ability and restriction to always be in the top row!?
Why the forced combination? Why not offer that top row for any user chosen card, and provide a badge card as a freely placeable element? Am I missing something?
My push would be to focus on more generalized control over where elements are placed on the page: Top, bottom, left, full-width, stacked, collapsed, âŚ
Similarly, I would love to see higher customizability for cards we already have, like the entities or glance card. Both could have been unified to offer the look and feel of this new badge card. Today I am seeing one more independent card with its own options, kinks, and limitations ![]()
can I ask you to add that to the issue I posted earlier.
The more people share their experience there, the better the team can tackle this
Why is there such a big empty space under the badges? On phone it takes up a lot of space
Yes, thanks a lot for raising these issues.
Not installed .8 yet, will test & report later in those issues.
Yes, this is already known to the Alexa media Player people.
The issue is within an upstream library of Alexa media PlayerâŚ
My Reolink camera and doorbells give an error, no longer accept passwords.
Log in error.
Other people having problems with there Skyconnect? ZHA keeps crashing because the port of fhe Skyconnect cannot be accessed.
I noticed you mentioned as part of this release âIntegrations and helpers set up via YAML, now visible in the UI!â. Following the update, it looks like my Google Assistant integration is not showing up in the UI. I configured it manually via YAML.
Interestingly, it was showing up in the UI for all previous versions.
So is this change going to switch other people âservice.callâ automations to âactionsâ automatically, or is it going to follow previous updates and show flagrant disregard and break everyones stuff, because the post doesnât mention that at all.
Yes. It broke my Alexa too. I tried twice. Requires Re-uthentication but no way to do it.
