### The problem
A repair is not generated for a supervised system.
## System I…nformation
version | core-2025.6.0b0
installation_type | Home Assistant Supervised
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.13.3
os_name | Linux
os_version | 6.1.0-26-amd64
arch | x86_64
timezone | America/New_York
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
GitHub API Calls Remaining | 4993
Installed Version | 2.0.5
Stage | running
Available Repositories | 1880
Downloaded Repositories | 28
</details>
<details><summary>AccuWeather</summary>
can_reach_server | ok
remaining_requests | 12
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | true
subscription_expiration | August 24, 2025 at 8:00 PM
relayer_connected | true
relayer_region | us-east-1
remote_enabled | true
remote_connected | true
alexa_enabled | true
google_enabled | false
cloud_ice_servers_enabled | false
remote_server | us-east-1-9.ui.nabu.casa
certificate_status | ready
instance_id | cb8f11775bbe42878839a021bdcf890e
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Debian GNU/Linux 12 (bookworm)
update_channel | beta
supervisor_version | supervisor-2025.05.3
agent_version | 1.2.0
docker_version | 27.3.1
disk_total | 219.9 GB
disk_used | 31.3 GB
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization |
supervisor_api | ok
version_api | ok
installed_addons | Samba share (12.5.1), Terminal & SSH (9.17.0), ESPHome Device Builder (2025.5.1), Z-Wave JS UI (4.3.1), Network UPS Tools (0.14.1), Samba Backup (5.2.0), AdGuard Home (5.2.9), Zigbee2MQTT (2.3.0-1), MariaDB (2.7.2), phpMyAdmin (0.11.1), Studio Code Server (5.19.3), Get HACS (1.3.1), ecowitt2mqtt (2024.10.0), Mosquitto broker (6.5.1)
</details>
<details><summary>Dashboards</summary>
dashboards | 7
resources | 11
views | 65
mode | yaml
</details>
<details><summary>Network Configuration</summary>
adapters | lo (disabled), eno1 (enabled, default, auto), docker0 (disabled), hassio (disabled), vethd12978d (disabled), vethc5092f2 (disabled), veth0632d56 (disabled), veth0501aaa (disabled), vetha533135 (disabled), veth83f9ca0 (disabled), veth6e6bcc0 (disabled), vethd8dcd71 (disabled), vethd4b4998 (disabled), veth4863af8 (disabled), vethee2c460 (disabled), veth1681e81 (disabled), vethc23cdf0 (disabled), veth791ed81 (disabled)
ipv4_addresses | lo (127.0.0.1/8), eno1 (192.168.1.134/24), docker0 (172.17.0.1/16), hassio (172.30.32.1/23), vethd12978d (), vethc5092f2 (), veth0632d56 (), veth0501aaa (), vetha533135 (), veth83f9ca0 (), veth6e6bcc0 (), vethd8dcd71 (), vethd4b4998 (), veth4863af8 (), vethee2c460 (), veth1681e81 (), vethc23cdf0 (), veth791ed81 ()
ipv6_addresses | lo (::1/128), eno1 (fe80::ea2d:c701:b86:361d/64), docker0 (fe80::42:3cff:fe10:17a8/64), hassio (fe80::42:dff:fea7:d90d/64), vethd12978d (fe80::e45e:75ff:fe8f:8df9/64), vethc5092f2 (fe80::78dc:e4ff:fec5:1926/64), veth0632d56 (fe80::c859:a4ff:fed8:c9b6/64), veth0501aaa (fe80::40ce:37ff:fef1:6d78/64), vetha533135 (fe80::b4d5:17ff:fe17:4479/64), veth83f9ca0 (fe80::a881:cfff:fe8e:5773/64), veth6e6bcc0 (fe80::1440:f8ff:fe7d:65e5/64), vethd8dcd71 (fe80::c88d:b1ff:fed1:da65/64), vethd4b4998 (fe80::f0e9:23ff:fe81:f7f7/64), veth4863af8 (fe80::d8e1:6ff:feea:186a/64), vethee2c460 (fe80::4878:eeff:fe08:bd47/64), veth1681e81 (fe80::86:4ff:fe06:6adb/64), vethc23cdf0 (fe80::a09d:6bff:fe7e:f95e/64), veth791ed81 (fe80::7074:15ff:fe70:7d0b/64)
announce_addresses | 192.168.1.134, fe80::ea2d:c701:b86:361d
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | March 27, 2025 at 8:51 PM
current_recorder_run | May 27, 2025 at 7:10 AM
estimated_db_size | 2173.64 MiB
database_engine | mysql
database_version | 10.11.6
</details>
<details><summary>Spotify</summary>
api_endpoint_reachable | ok
</details>
### What version of Home Assistant Core has the issue?
core-2025.6.0b0
### What was the last working version of Home Assistant Core?
NA
### What type of installation are you running?
### Integration causing the issue
_No response_
### Link to integration documentation on our website
_No response_
### Diagnostics information
_No response_
### Example YAML snippet
```yaml
### Anything in the logs that might be useful for us?
```txt
### Additional information
_No response_
