2026.2.3 Broky my Zigbee2mqtt Network - SONOFF ZBDogle-P
Updated to 2026.2.3 today and it broke my Zigbee network disable my 3 SONOFF ZBDongle-P Routers. (one main connected to USB, the others are extentions)
Been working for years and suddenly this comes in and break the system :frowning_with_open_mouth:
Reverted back to 2026.2.2 and they are all working again.
Raspberry Pi 4
Regular OS setup
Connected to USB 2 port (long cable)
Sonoff ZBDongle-P with a special flash.
Again, been working for years. What is killing this off in 2026.2.3. Find this weird. Would be more obvious if 2026.2 would break it…
What does the logs say? For what it’s worth, my Z2M network is fine running on 2026.2.3.
Not likely.
More likely your SD card failed when you updated. If you are using a machine that uses an SD card, updates where a lot of files are removed and installed is a very stressful time and the time when SD cards are most likely to fail. I would check that. How to Troubleshoot Raspberry Pi Crashing
What’s ā€œspecialā€ about it?
EDIT: Saw your other post in a different thread about multiprotocol breaking in 2026.2.3.
HA devs have been warning for at least 2 years that multiprotocol is highly unstable and should not be used. They explicitly said it was unsupported.
Sonoff thought they knew better & released multiprotocol despite the warnings, claiming that it was now stable enough. I suggest you direct your frustration at Sonoff instead of these forums, because right now this is all I can picture:
I am not using an SD card. Harddrive. And it make no sence why this would break when going from 2026.2 to 2026.3
Does an HA restart clear it?
Donald T special. A very beautiful flash, the most beautiful flash ever seen.
No maybe not special but I do remember that it was pretty much hard work to get it up running. Flashing all three dongles took time.
Cant remember anything about multiprotocol… or exectly where I got it. I’ll have to try to find out.
However what was so bad about it if it worked for over 4 years?
What do you recommend to use instead? What is available?
No it didnt. Was hoping it would clear…
I didn’t realize you were the same person… What ShadowFist said, for sure.
Please don’t keep asking until you get an answer you like. That’s what the AI LLM’s are for.
And post this into a search engine…:
site:community.home-assistant.io multiprotocol
