How to Troubleshoot Raspberry Pi Crashing
Please note the Suggested hardware in the installation instructions. Some users have found that a Pi 3 B is not sufficient to run Home Assistant. And 1 GB of RAM is not enough to run Home Assistant.
What does the Green and Red light mean?
  1. Ensure you are using an appropriate power supply. See the warning at the top of this page:
  1. USB peripherals directly attached to the Pi can exceed the power supply limits (for example SSDs and Disk drives). Use the Raspberry Pi Power Supply Checker Integration to monitor your power. Always attach these to a separately powered USB hub then attach the USB hub to the Pi.
  2. Try a different power supply (power supplies can fail).
  3. The SD card, SSD, etc. may have corrupt files from a crash, power fail, repeated power cycles without proper shutdown, etc. Try a clean install and recovery from a backup. Or If you find the configuration.yaml, copy all files and directories (including hidden files) in that folder somewhere safe, and after installing a new HA, copy them to your new installation.
  4. Check the system log files to see if there are any errors that correlate to the times of the crash. If the system won’t boot, you can move the system media (e.g. SD Card) to a Windows system and use Linux Reader to read the partitions and files. Look for the following log files in the \config folder.
    • Home-assistant.log [current logfile]
    • home-assistant.log.1 [previous logfile]
    • Home-assistant.log.fault
  5. Check the other log files.
  1. Could an Integration be misbehaving?
    • Check the Known Issues for the integration
    • Remove the suspect integration to see if that helps.
  2. More diagnostic and repair tools can be found here: Common tasks - Operating System - Home Assistant.
  3. Does the problem only happen Monday at like 2AM? There is a process that runs in HA at that time and if your SD card is a bit iffy, it has been known to cause PI crashes. See: HA stops work every Monday - #101 by hdehaseleer Consider changing your SD card.
Home Assistant Cookbook - Index
The Home Assistant Cookbook - Index
Home assistant crashing, how to find what's causing it?
Home Assistant Crashing \ Rebooting
Is there an OS Boot log?
HA crashes every couple days and I have no idea how to find out why
HA unavailable in seeemingly randow intervals - why does it crash?
HASSOS freeze
[WARN] Home Assistant CLI is not running! Jump into emergency console!
Home Assistant reboots with Echo Atom
HomeAssistant doesn't work anymore, Supervisor disconnected
Random RPI4 Crashes. Logs are not saved. SSD error?
Home assistant freezing every 16-17 hours
HA OS crashing
Home assistant keeps crashing after 5 to 10 minutes
Bricked SD card after power outage
Issues after power loss with docker containers and Supervisor
Hassio keeps crashing regularly
Rebooting problem on Raspberry Pi 5
# Core 2026.4.2 crashes with Signal 11 during onboarding — Pi 4B Rev 1.5, HAOS 16.3
Home Assistant Yellow LEDs freaking out
HA refused to connect after new install
Boot Loop on my Backup-Raspi4
2026.2.3 Broky my Zigbee2mqtt Network - SONOFF ZBDogle-P
[RPi 3 Model B] Hardware limits or SD card worn out?
Boot message: “Waiting for the Home Assistant CLI to be ready…”
HA stops responding, can not find the cause
Home Assistant keeps restarting. Help in analyzing log files appreciated
Pi 400 HAOS keeps disconnecting but I can ping the Pi
Scheduler Card stopped working
Best procedure for shutting down the pi 4
How to figure out why HA crashed?
Issues with RAM memory?
HA (2025.9.1) and zigbee2mqtt (latest vesion) communication takes toooo long
Persistent Home Assistant Failure: Configuration.yaml Disappearing Issue
Crashing HA, debug help required
Panic: runtime error: HAOS RPI4
Instalation RPI 5 problem
Installation: Raspi appears to have booted correctly but refuses connection
Reliable solid state drive
Probably bricked my Home Assistant - some unbricking tips would be helpful!
HA core crashing randomly
Hassio Crash
HASS - Failed to start network Manager wait online
Help diagnosing constant crash/restarts
Can't update HA and system crash randomly
Home Assistant Continuously Restarting ~ every 5 minutes
HA 12.3 not booting on RPI4
Error installing HA os
I think my raspberry pi broke?
HAOS on RPi froze - and systemd ate my logs
HA on RPi4 crashes at random intervals - How to check if it's a power issue?
Multiple restarts
RaspPi HAOS Restore results in 500 Internal Server Error
My home assistant stop working (im beginner)
Rpi5 ha problem
Home assistant Pinging but cant enter or ssh
Home Assistant crashing 2 or 3 times a day
HA boots and then freezes
Homeassistant on Raspberry pi 5 got locked up
Home Assistant frontend stuck on loading screen after 2 weeks of stable work (Pi 5 + NVMe)
Unstable Home Assistant latest version on Oroid N2+
Help with Raspberry PI 5 trubleshooting
Raspberry Pi 4 hangs loading HAOS
New RPi5, fresh 2025.1.2 image, core keeps crashing
Crash - Argo tunnel issue
Not working - I cannot access Home Assistant
Rpi 5 HA freeze(Hangs)
HA freezes after reboot
HAOS on Raspberry Pi4 not booting
Raspberry fails to connect to localHost
Every few hours, Home Assistant loses it's internet connection
HDMI not working on RBPi4b
HA crashes every few hours
No more access to the interface after reboot
Help investigating RPi Crash
Why it reboots (switched to an other 3d)
New User how to check reason of crash
HAOS hangs intermittently
[Need Help] on Home Assistant becoming unreachable from the network
Broken SD (again)
Trying to get HA running on Rasp Pi 5
Raspberry Pi 5 not connecting
Clean, fresh install on Raspberry Pi 5, not working
HA not stable?
Unable to remote into HA, but it's working?
HA crashing - how to debug?
Cannot acces via web UI anymore, [Errno5] and configuration.yaml not found
Raspberry pi HA crashed - help to identify root cause and misc mysteries - next steps?
Home Assistant Cookbook - Discussion Thread
Regulary Crashes of HA OS
HA freezes randomly and only come back after power off and on again
RPI4 restart cause homeassistant to not boot
Install HA on Raspberry Pi 5
Update to 2025.7.1 does not work
Issue after Storm
2025.8.2 and almost all integrations stopped working
HA always corrupt after restart
RPI5 hangs, requiring hard reset. Is there a watchdog?
Segmentation fault on RPi 4 4GB - corrupted board?
Unable to restore backup after OS restore on a Raspberry Pi
Random uncommanded HAOS restarts - how to debug?
Can not boot fully - including safe mode
Error reading from server: EOF
Home Assistant starts very slowly
Newbie... Right after install: 500 Internal Server Error Server got itself in trouble
My HASSOS seems to have dissappered and I get a docker daemon error Pi5 install
Crash MAJ 206.4.x with rpi 4 and 5
Need help: HASS doesn't boot after power outage
Raspberry Pi Bootlooping after update
Latest update bricked my HA yellow
Yellow Core Restarts Regularly - Please guide me for further troubleshooting
Raspberry Pi 4 - Home Assistant crashes *a lot*
Rpi 5 8gb - case argon neo 5 nvme SSD installation
Issue updating HA Core - can it be done on a fresh install and then applying backup with older version?
Restore hangs after resetting home assistant green with SD Card method
Home Assistant on Raspberry Pi 4 issue - Connection Drops
Database corrupts every few hours, reboot shows no error and a working database
Home Assistant freezes from time to time
HA freezes
Configuration.yaml and more not available
Moving to a new Raspberry PI
HA is constantly crashing and restarting and i'm out of ideas. Can anyone help?
All Historical Data is gone since some versions
Home Assistant Green keeps crashing on a daily basis
You just responded to an 11 month old post with an answer that doesn’t make sense?
My pi 4 was crashing every few days but moving the ssd from a USB 3 port to a USB 2 port appears to be the solution.
