Hey Xeo! Thanks very much! Will share the config soon, just need to package it.
The photos on the left are just picture-element entities. The menu is as well - I designed my whole UI and then exported images to use as buttons.
The graph at the bottom left is a mini-graph-card showing temperature of my house vs outside:
https://community.home-assistant.io/t/lovelace-mini-graph-card
The weather is simple-weather-card:
https://community.home-assistant.io/t/lovelace-simple-weather-card
Note: pretty much everything in my UI I have added custom styles to tweak it to be exactly how I wanted it to look, so the cards just worked as a foundation. I use card-mod to achieve more complex styling:
https://community.home-assistant.io/t/card-mod-add-css-styles-to-any-lovelace-card
