My goal is to be able to use a 433Mhz Etekcity remote to control various things in Home Assistant so I can turn off a lamp at night without having to yell at a voice assistant. I don’t actually want to use the 433Mhz power outlets (I’ll use WiFi plugs instead since they can report their current state) just the remote.
I first tried setting up the Sonoff RF Bridge with Tasmota following Dr Zzs’ guide. Once I set that up and pressed the “1 On” button repeatededly, I get non-unique values in data and some of the other fields if they matter.
01:28:41 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:28:41","RfReceived":{"Sync":6060,"Low":220,"High":590,"Data":"505500","RfKey":"None"}}
01:28:45 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:28:45","RfReceived":{"Sync":6060,"Low":220,"High":590,"Data":"505532","RfKey":"None"}}
01:28:48 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:28:48","RfReceived":{"Sync":6060,"Low":220,"High":600,"Data":"505500","RfKey":"None"}}
01:28:54 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:28:54","RfReceived":{"Sync":6060,"Low":220,"High":590,"Data":"505500","RfKey":"None"}}
01:28:58 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:28:58","RfReceived":{"Sync":6050,"Low":220,"High":590,"Data":"505500","RfKey":"None"}}
01:29:02 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:29:02","RfReceived":{"Sync":6020,"Low":220,"High":600,"Data":"505533","RfKey":"None"}}
01:29:04 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:29:04","RfReceived":{"Sync":6050,"Low":220,"High":590,"Data":"505500","RfKey":"None"}}
01:29:06 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:29:06","RfReceived":{"Sync":6060,"Low":220,"High":590,"Data":"505500","RfKey":"None"}}
01:29:08 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:29:08","RfReceived":{"Sync":6050,"Low":220,"High":590,"Data":"505500","RfKey":"None"}}
01:29:11 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:29:11","RfReceived":{"Sync":6060,"Low":220,"High":590,"Data":"505500","RfKey":"None"}}
01:29:13 MQT: tele/Sonoff_rfbridge/RESULT = {"Time":"2020-03-28T01:29:13","RfReceived":{"Sync":6070,"Low":210,"High":600,"Data":"505530","RfKey":"None"}}
This forum post suggested trying ESPurna instead of Tasmota, but when I tried to upload the firmware via Tasmota’s web interface (even with SetOption78 1) I would get an error, Upload buffer miscompare. When I tried flashing via the pins, it felt like pressing the reset button wasn’t putting it into flashing mode, tried several times and kept getting Failed to connect errors.
So then I tried a different tack and hooked up a MX-05V to an ESP8266 running ESPhome. But when I press “1 On”, I get different codes each time.
[05:26:54][D][remote.rc_switch:243]: Received RCSwitch Raw: protocol=5 data='1000110000'
[05:31:58][D][remote.rc_switch:243]: Received RCSwitch Raw: protocol=6 data='101001001'
[05:56:17][D][remote.rc_switch:243]: Received RCSwitch Raw: protocol=5 data='11111101'
So am I doing something wrong somewhere? Or does this mean I probably can’t use this particular Etekcity remote? Is there a better way to simply get a few buttons that I can push to trigger things in Home Assistant (so far I’ve only got WiFi devices)?
