Sadly the linked you posted cannot be opened. Maybe try to post another link or a screenshot.
I didn’t, mine was a little different (the P829) but this sensor from Kerui should work without problem.
I’m pretty sure only the shell is different, the electronic is either based on the same design or exactly the same.
Hello @1technophile can you please help me? I flashed OpenMQTTGateway on an esp8266. As a module I attached a 433mhz (stx882 & srx882) and over mqtt I get the error.
Socket error on client OpenMQTTGateway, disconnecting.
1560193438: New client connected from 192.168.1.xxx as OpenMQTTGateway (c1, k15, u’yoda12’).
seems a credential issue, please chech your username/password versus the ones entered into mosquitto.
May I advise you to open your questions here, this thread is more dedicated to compatible devices rather than support.
I’ve had to lock the main table in the device list: https://docs.google.com/spreadsheets/d/1DdtVtSsN25nwP6BZI5q6C9yDGz37tUWjw2SQ1RGwBxU/
People where editing and adding there personal comment in the list or hiding some of the entries.
Not the main table cannot be edited but entries can be added under it and I’ll then compile them to the rest.
Meanwhile I’m now having a dedicated sheet below:
Comment can be added but I keep the editing rights
Thank you for sharing that list of compatible devices!
I am new in the HA world and I am looking for an easy Interior alarm keypad that can be used to disarme the alarm.
Is it feasible with the one below :
YAOSE 433MHz Wireless Keypad for Smart Home Security System Extention Keypad for Burglar Fire Alarm Panel Support RFID Key Tag
Thx!
Your link go to a page not found, I canno’t see the model.
I suppose that you are referring to this one:
https://www.aliexpress.com/item/1005001355580355.html
On a security standpoint I don’t advise to use 433mhz basic protocols to disarm an alarm. I advise to disarm by a secure way like a wired keypad or your HA app.
Please note that the RF compatible devices are now listed below:
Thank you!
Have you any specific wired keypad to recommend?
kr,
JP
No idea. You will find easily references compatible with arduino or esp boards on ecommerce diy websites.
