📱 Notifications & Announcements
@G2740
This will have to come form someone else as I am a full local man to the core and is why I use HA. It’s probably why I develop all my own blueprints
 full local control :metal:
The only thing I would consider is HA cloud.
Blacky :smiley:
Ok, guess i gotta add some things to my green and see if i can get it working local.
Hello
I want to use text to speech with Alexa player but service provider list is empty. There is an issu ?
@Sebibou91
You just need a TTS engine. If you have HA cloud it will be there but if you don’t use that you can use Piper as it is an official add on.
Go to Settings > Add-ons > click on Add-on Store > search for Piper and install it. Then once installed you can adjust your settings in the configuration tab in the Piper add-on. Once your happy then select it in the BP.
Enjoy
Blacky :smiley:
I’ve attached a sonoff door switch on the garage roller door and would like to use it to notify me when the roller door is open and when it is closed/closes. Will this automation be able to alert both a “garage door open” and then a “garage door closed” alert when it is closed?
Or is there another automation suited to my use case?
Secondly, for another application
 Lets say if I try to use this for a letterbox notification. I can use a motion sensor to detect when a letter passes by it into the letterbox, and then have this automation send the announcement. Is it possible to have a persistent notification come through (say approx once an hr), and or have the ability to acknowledge the message which cancels the automation?
Or once again, is there another automation more suited to this use case?
Thank you
JK
Initial release 1.2
:new: Update Input - Time Delay
  • Time Delay - Added option to select hours, minutes and seconds to give more options in your time delay.
    :warning: If you previously used the time delay and you update to this new version you will need to re select your time delay.
If you like this blueprint? Consider hitting the :heart: button in the top post :+1:
If you like my blueprints, and would like to show your support or just say thank you? Click Here :smiling_face_with_three_hearts:
Enjoy
Blacky :grinning:
@JK200SX
Hi John,
Have a look at :round_pushpin: State Notifications & Actions Blueprint. It includes “Start” and “End” states with action buttons and associated actions. “Start” for when the garage is open and “End” for when the garage is closed.
I’m planning to add a recurring message option to keep reminding you until the task is done, though I don’t have a timeline for that feature yet.
That said, this blueprint should still be useful for your needs.
Blacky :smiley:
Hi, i’m using HAOS and i followed your instructions and even restarted Home Assistant after installing Piper (which is started), but i can’t select it in the “Text-to-Speech Service Provider” field. Did i miss anything ?
@Chartreusito
Once you installed piper go into the add on and the documentation page tab at the top. You will see the below
 there you will have to install Wyoming
 it should be auto discovered in settings > device & services
Blacky :smiley:
Is there a way to have the notification tell you which sensor ran the automation? I am setting this up for smoke and water sensors.
@RogerB1
It would be the same way as the state blueprint. I have also replied to you over on that topic. Click Here
Blacky :smiley:
Hi Blacky,
Thank you once again for your outstanding blueprints!
I have a question regarding a wishlist entry: Is there already a way to repeat notifications until the original state is restored? I’d like to use this feature for doors when airing rooms. For example, after the door has been open for 10 minutes, I’d like to receive push notifications every X minutes until it is closed.
Thanks again!
@xXkr13g3rXx
Thanks for your suggestion. Yes this will be added to this blueprint
 I have added it to another one of my blueprints and I just need time to add this feature to this one.
Blacky :smiley:
Hi Blacky! Just got a reolink doorbell, and found your blueprint - perfect! :slight_smile:
One request, the TTS integrations don’t seem to work with Alexa. Is there a way to use the “notify” action or incorporate this into the blueprint? thanks!
@Nuwanda
I will put this on the list to add to this blueprint.
Blacky :smiley:
Oh la la
 Un grand merci pour cette automatisation
 simple Ă  mettre en oeuvre pour des novices comme moi
 une chance que je sois tombĂ©e sur votre post
 je cherche depuis plusieurs semaines Ă  obtenir ce genre d’alerte d’état ! et lĂ , il y a tout ce dont j’ai besoin ! (ios et google mĂȘme si son français est trĂšs moyen pour le coup) lol
ENCORE MERCI !!!
@iflo
Bienvenue dans la communauté
Vous ĂȘtes les bienvenus et je suis heureux que cela vous plaise. Merci pour vos aimables paroles.
English
Welcome to the community
You are very welcome and I glad you like it. Thanks for your kind words.
Blacky :smiley:
Bonjour,
J’adore toujours autant votre automatisme
 qui m’a permis de crĂ©er un bouton virtuel pour signaler Ă  la tribu de venir dans la cuisine ! :slight_smile: mais trop trop bien ! j’adore !
Juste une petite question, peut-ĂȘtre hors sujet, j’ai un portail Ă©lectrique qui se commande bien sĂ»r, aussi avec une tĂ©lĂ©commande physique.
Est-il possible de recevoir une alerte lorsqu’il est activĂ© par cette tĂ©lĂ©commande et non pas par l’application HA ? c’est peut ĂȘtre tout bĂȘte
 mais comme je le disais, je dĂ©couvre tout doucement cette usine Ă  gaz qu’est Home assistant
Merci par avance pour une réponse apportée
 et bonne journée/nuit à vous
selon le fuseau horaire
 :wink:
Hi
Greetings flo,
Please read the FAQ before posting. This is an English only forum.
Veuillez lire la FAQ avant de poster. Ce forum est uniquement en anglais.
How to help us help you - or How to ask a good question.
I use it to call everyone when it is dinner time to, it was the main reason I developed this blueprint and I love it too. Tip: Make sure you set this time restriction so when you accidentally press it to call everyone at 1am in the morning you don’t wake everyone up :wink:
In order to receive an alert from the remote control, Home Assistant (HA) must be able to detect when the remote is pressed. This event then acts as the trigger for an automation, which can send you an alert or notification using the blueprint.
In French
Je l’utilise pour appeler tout le monde Ă  l’heure du dĂźner, c’est la principale raison pour laquelle j’ai dĂ©veloppĂ© ce plan et je l’aime aussi. Astuce : assurez-vous de dĂ©finir cette limite de temps afin que lorsque vous appuyez accidentellement dessus pour appeler tout le monde Ă  1 heure du matin, vous ne rĂ©veilliez pas tout le monde :wink:
Afin de recevoir une alerte de la tĂ©lĂ©commande, Home Assistant (HA) doit ĂȘtre capable de dĂ©tecter le moment oĂč la tĂ©lĂ©commande est enfoncĂ©e. Cet Ă©vĂ©nement agit ensuite comme dĂ©clencheur d’une automatisation, qui peut vous envoyer une alerte ou une notification Ă  l’aide du plan.
Blacky :smiley:
