That’s up2date of course!
Uh yeah, it is fixed but you may have to wait for HA 0.116 later today (I’m on beta)
Does 0.116 break anything else?
There’s mention of a breaking change for Custom Lovelace Cards.
No, everything works but there’s this issue with custom-header. maykar posted a workaround but he’s archiving the project for 0.117.
sorry if I ask stupid but I am trying to use the buttom-card with your light template, but I am getting found undefined alias ‘icon_spot’ in what do I do wrong or forget??
It’s yaml anchors. You can think of it as:
& = copy
* = paste
I think you’re getting undefined alias because it has nothing to copy from
#button-card icon
icon_spot: &icon_spot >
[[[ const state = entity.state === 'on' ? 'animate_on' : 'animate_off';
return `<svg viewBox="0 0 50 50"><style>@keyframes animate_on{0%{tra...
#another button with same icon
icon_spot: *icon_spot
So we’ll need a different way to have it appear full screen?
I believe so but kiosk mode was the only feature I used and this script works just as well.
https://github.com/matt8707/hass-config/blob/ac5c462d7646415c2ebcc44eadbb9d6c37c55b12/www/kiosk.js
EDIT: Added it to HACS instead
Mattias, thanks. I have removed custom header from HACS and also removed it from my configuration.yaml and my lovelace yaml.
In configuration.yaml I now have
- url: /local/kiosk.js
type: module
and that file in the root of www.
I rebooted Home Assistant.
Is there something I need to add in my lovelace yaml to use kiosk.js ?
thanks!
If it matters type should be type: js
. It checks if you have the query string ?kiosk
in your url.
hass:8123/lovelace/default_view?kiosk
It is working now. Thank you Mattias!
I had copied type: module from the entry above. Updating it to type: js and then adding ?kiosk to the url made it work perfectly.
I appreciate it.
Mmm, something else broke again with an update of a custom component, but I have no clue which. Some cards aren’t being styled anymore
Check my include/themes.yaml
Euh? Do I understand it correctly I have to remove whitespace around the “>” in the element path in style definitions?
Yeah. Don’t ask me why
But I’m still on 0.114.4?
But you updated card-mod, where the issue is
Aha, I see. Thanks.
OK fixed it, thanks! Until the next breaking change
I can’t seem to get this to work. After numerous HA restarts it worked once, then after a refresh it was gone again. I put the kiosk.js file (with that exact code double check) on www/ folder. Then in configuration exactly like you wrote and put ?kiosk
at the end of url.
Do I need to do something else as well? I already cleared CH. Using Edge Chromium btw.
Thanks in advance
