Just started out with Home Assistant and this UI would look sick on my tablet. I tried to copy all the files in the repository to my HA installation folder but nothing happens. Guessing it’s not that simple…?
I understand I have to replace the entities with my own but I just want the interface to be up and running
Hi Mattias,
First of all, congratulations for your work and for sharing it with the community. I love the interface and I would like to integrate it at home but I don’t know how to do it.
I copied the project to my root and I try to use my minimal configuration to make it work but it gives me failures.
In configuration.yaml I removed everything except resources and logger but when I started index.html it gave me errors.
Could you provide a guide to set a clean configuration?
I’m sorry for my clumsiness.
Thanks in advance
I’ve been asked to do a guide multiple times but I have no interest in making one since there’s simply too much to cover. The documentation is there for a reason too.
Cloning my whole configuration is just a bad idea. Copy the parts that you like, one at a time and go from there.
An old post, but how can we add the white border radius also added in the non-rgb buttons? Mine are slightly smaller than the rgb version currently. I am searching for the right placement of the CSS but can’t get it correct
Thanks.
We can’t add the hue bulb to the custom_icons.js file I think, because of the large setup? I tried but won’t get it to work. I want to re-use it in other cards also (so not only/actualy not at all with button card)
I have another strange issue.
When I popup my light card, it won’t show the color picker (if i press the rgb icon). If i however click on the bulb, then go back to the popup… it does show:
(1: i press the rainbow, 2 i dont see the colorpicker, 3 i press on the lamp icon in the popup card, 4 i see the popup card in its original state, 5, i see the rgb picker…
sorry if I ask stupid but I am trying to use the buttom-card with your light template, but I am getting found undefined alias ‘icon_spot’ in what do I do wrong or forget??
