You can try this Fit content · Issue #41 · matt8707/hass-config · GitHub
Can someone try this out, I think I got it to work…
Edit:
on view change the text scrolls even if it fits
So i am a noob to all of this (literally started like 1 week ago), but this lovelace UI is so perfect, i had to try and use it.
(if this is already asked and answered, sorry, but this thread has 2362 replies at time of writing, and i cannot read all of em)
I am running into the following issue.
I want one of the tiles to control a group of lights, so i got a light group going, linked the entity, all is good!
However, the lights in question also have RGB, so i wanted to use the color picker, and i get this:
Each of these three works independent of one another, so i can set the colors of each of the 3 lights separately. Which is not a bad thing i guess, but my goal was to have all 3 lights be in sync all the time.
Maybe i just missed something obvious?
Thanks! Here’s the fix:
(and also add light group, update entities · matt8707/hass-config@857931c · GitHub)
If you’re interested in why… I used to use light groups, using hue grouped lights
used to be faster (frontend) plus consolidate_entities
was broken…
hoped this would also work on a regular custom:button-card state or label, but unfortunately it doesnt scroll the full text, but only the bit that is actually visible on first sight…
- type: custom:button-card
entity: sensor.buienradar_symbol # replace with any sensor which state is a longer text...
template: extra_styles
aspect_ratio: 1/1
show_icon: false
show_name: true
show_state: true
styles:
state:
- animation: marquee 20s linear infinite
would you know what that is?
using the marquee tag does work in that respect:
<marquee>
<span style='color: var(--primary-color);align-items: center;'>${alarm} at ${entity.state}</span>
</marquee>
Probably
styles:
state:
- overflow: visible
but I don’t think it’s a good idea to add ResizeObserver to every button-card, performance wise
confirmed, thank you very much!
OMG that was the solution, I was wondering why the consolidate entities switch didn’t make any difference! Thanks!
I also noticed the difference with a group and a light-group, so for anyone reading this in the future, a light group is the way to go.
A regular group creates multiple issues, like the brightness percentage in the dashboard becoming NaN% as well as the slider doesn’t want to hold the position.
So go with light groups.
@CDRX2 , i did, regular groups made created much more issues (read above)
@Mattias_Persson, again thank you soo much!
It worked for me. Thanks a lot
it’s messy, but here it is @gerard33
icon_xbox:
styles:
custom_fields:
icon:
- width: 150%
- margin-left: -8%
- margin-top: 3%
custom_fields:
icon: >
if (variables.state === 'on' && variables.timeout < 2000) {
return `
<svg viewBox="0 0 50 50">
<style>
@keyframes on {
50% {
transform: translateY(0);
100% {
transform: translateY(-45%);
.on {
animation: on 2s cubic-bezier(0.550, 0.085, 0.680, 0.530) both;
</style>
<g style="clip-path: url(#mask);">
<g class="on">
<path fill="#107C10" d="M4.102 21.033C6.211 22.881 8.977 24 12 24c3.026 0 5.789-1.119 7.902-2.967 1.877-1.912-4.316-8.709-7.902-11.417-3.582 2.708-9.779 9.505-7.898 11.417zm11.16-14.406c2.5 2.961 7.484 10.313 6.076 12.912C23.002 17.48 24 14.861 24 12.004c0-3.34-1.365-6.362-3.57-8.536 0 0-.027-.022-.082-.042-.063-.022-.152-.045-.281-.045-.592 0-1.985.434-4.805 3.246zM3.654 3.426c-.057.02-.082.041-.086.042C1.365 5.642 0 8.664 0 12.004c0 2.854.998 5.473 2.661 7.533-1.401-2.605 3.579-9.951 6.08-12.91-2.82-2.813-4.216-3.245-4.806-3.245-.131 0-.223.021-.281.046v-.002zM12 3.551S9.055 1.828 6.755 1.746c-.903-.033-1.454.295-1.521.339C7.379.646 9.659 0 11.984 0H12c2.334 0 4.605.646 6.766 2.085-.068-.046-.615-.372-1.52-.339C14.946 1.828 12 3.545 12 3.545v.006z"/>
</g>
</g>
<defs>
<clipPath id="mask">
<path d="M4.102 21.033C6.211 22.881 8.977 24 12 24c3.026 0 5.789-1.119 7.902-2.967 1.877-1.912-4.316-8.709-7.902-11.417-3.582 2.708-9.779 9.505-7.898 11.417zm11.16-14.406c2.5 2.961 7.484 10.313 6.076 12.912C23.002 17.48 24 14.861 24 12.004c0-3.34-1.365-6.362-3.57-8.536 0 0-.027-.022-.082-.042-.063-.022-.152-.045-.281-.045-.592 0-1.985.434-4.805 3.246zM3.654 3.426c-.057.02-.082.041-.086.042C1.365 5.642 0 8.664 0 12.004c0 2.854.998 5.473 2.661 7.533-1.401-2.605 3.579-9.951 6.08-12.91-2.82-2.813-4.216-3.245-4.806-3.245-.131 0-.223.021-.281.046v-.002zM12 3.551S9.055 1.828 6.755 1.746c-.903-.033-1.454.295-1.521.339C7.379.646 9.659 0 11.984 0H12c2.334 0 4.605.646 6.766 2.085-.068-.046-.615-.372-1.52-.339C14.946 1.828 12 3.545 12 3.545v.006z"/>
</clipPath>
</defs>
</svg>
return variables.state === 'on' && variables.timeout > 2000 ? `
<g style="transform: translateY(-45%);">
</g>
</g>
<defs>
<path d="d="M4.102 21.033C6.211 22.881 8.977 24 12 24c3.026 0 5.789-1.119 7.902-2.967 1.877-1.912-4.316-8.709-7.902-11.417-3.582 2.708-9.779 9.505-7.898 11.417zm11.16-14.406c2.5 2.961 7.484 10.313 6.076 12.912C23.002 17.48 24 14.861 24 12.004c0-3.34-1.365-6.362-3.57-8.536 0 0-.027-.022-.082-.042-.063-.022-.152-.045-.281-.045-.592 0-1.985.434-4.805 3.246zM3.654 3.426c-.057.02-.082.041-.086.042C1.365 5.642 0 8.664 0 12.004c0 2.854.998 5.473 2.661 7.533-1.401-2.605 3.579-9.951 6.08-12.91-2.82-2.813-4.216-3.245-4.806-3.245-.131 0-.223.021-.281.046v-.002zM12 3.551S9.055 1.828 6.755 1.746c-.903-.033-1.454.295-1.521.339C7.379.646 9.659 0 11.984 0H12c2.334 0 4.605.646 6.766 2.085-.068-.046-.615-.372-1.52-.339C14.946 1.828 12 3.545 12 3.545v.006z"/>
</clipPath>
</defs>
</svg>
<path fill="#9da0a2" d="M4.102 21.033C6.211 22.881 8.977 24 12 24c3.026 0 5.789-1.119 7.902-2.967 1.877-1.912-4.316-8.709-7.902-11.417-3.582 2.708-9.779 9.505-7.898 11.417zm11.16-14.406c2.5 2.961 7.484 10.313 6.076 12.912C23.002 17.48 24 14.861 24 12.004c0-3.34-1.365-6.362-3.57-8.536 0 0-.027-.022-.082-.042-.063-.022-.152-.045-.281-.045-.592 0-1.985.434-4.805 3.246zM3.654 3.426c-.057.02-.082.041-.086.042C1.365 5.642 0 8.664 0 12.004c0 2.854.998 5.473 2.661 7.533-1.401-2.605 3.579-9.951 6.08-12.91-2.82-2.813-4.216-3.245-4.806-3.245-.131 0-.223.021-.281.046v-.002zM12 3.551S9.055 1.828 6.755 1.746c-.903-.033-1.454.295-1.521.339C7.379.646 9.659 0 11.984 0H12c2.334 0 4.605.646 6.766 2.085-.068-.046-.615-.372-1.52-.339C14.946 1.828 12 3.545 12 3.545v.006z"/>
</svg>
this is my version of icon XBOX
icon_xrotate:
styles:
custom_fields:
icon:
- width: 90%
- margin-left: -10%
- fill: >
return (variables.state === 'on' || variables.state === 'playing') ? '#107b10' : '#9da0a2';
custom_fields:
icon: >
let state;
state = 'on';
if (variables.state === 'off' && variables.timeout < 2000) {
state = 'off';
if (variables.state === 'on' && variables.timeout > 2000) {
state = 'on_timeout';
return `
<svg viewBox="0 0 1331.67 1333.33">
<style>
@keyframes on {
0% {
transform: rotate(0deg) translate(0%, 0%);
100% {
transform: rotate(-360deg) translate(-1.5%, 0%);
@keyframes off {
0% {
transform: rotateY(-360deg) translate(-1.5%, 0%);
45% {
transform: rotateY(-40deg);
55% {
transform: rotateY(0deg);
65% {
transform: rotateY(-15deg);
75% {
85% {
transform: rotateY(-5deg);
95% {
.on {
animation: on 1.1s;
animation-fill-mode: forwards;
transform-origin: 50% 50%;
transition-timing-function: cubic-bezier(0.85, 0, 0.15, 1);
.off {
animation: off 1.1s linear;
animation-delay: 0.05s;
animation-fill-mode: both;
transform-origin: 45% 41%;
</style>
<path class="${state}" d="M665.83 534.66s1.66 0 0 0c200.91 152.76 541.3 528.02 438.35 634.29-117.89 102.95-270.65 164.39-438.35 164.39-167.7 0-322.13-61.44-438.35-164.39-104.61-106.27 237.44-481.53 436.69-632.63 0-1.66 1.66-1.66 1.66-1.66zm347.03-436.7C911.57 36.52 800.32-.01 665.83-.01c-134.5 0-245.74 36.53-347.03 97.97-1.66 0-1.66 1.66-1.66 3.32s1.66 1.66 3.32 1.66c129.51-28.23 325.44 83.02 343.71 94.65h3.32c18.26-11.62 214.2-122.87 343.71-94.65 1.66 0 3.32 0 3.32-1.66s0-3.32-1.66-3.32zm-813.61 92.98c-1.66 0-1.66 1.66-3.32 1.66C74.72 313.81 0 481.52 0 665.82c0 151.1 51.48 292.24 136.16 403.49 0 1.66 1.66 1.66 3.32 1.66s1.66-1.66 0-3.32C88 909.91 348.69 529.67 483.19 370.26l1.66-1.66c0-1.66 0-1.66-1.66-1.66-204.23-202.57-272.31-180.99-283.93-176.01zm649.23 174.35l-1.66 1.66s0 1.66 1.66 1.66C982.98 528.01 1242 908.26 1192.19 1066v3.32c1.66 0 3.32 0 3.32-1.66 84.68-111.25 136.16-252.39 136.16-403.49 0-184.31-74.72-352.01-197.59-473.22-1.66-1.66-1.66-1.66-3.32-1.66-9.96-3.32-78.04-24.91-282.27 176.01z"/>
</svg>
```[Processing: Screenrecorder-2022-01-13-13-00-14-380~2.mp4...]()
Sorry I forgot the dash between light and groups, of course I meant light-groups, the link points to that documentation
I play media from my Squeezbox to all my players in the house. When playing songs from spotify, i see the art cover. but from some radio stations, there is no cover provided. so the mini media player shows me the default art cover.
I dont find a solution to this, so i want to show a other image, that looks better.
The only way i see to check if it is spotify or radio, is the media_content_id. When playing spotify, it gives me “spotify: xxxxxxxxxx” when playing radio, it starts with" https: xxxxxxx". I made a sensor, that splits this to “https” and “spotify”.
Now i change the entity_image between “https” and “spotify” with this
type: custom:config-template-card
variables:
- states['sensor.radio_split'].state
style:
left: 80%
top: 35%
entities:
- media_player.homeyk
card:
entity: media_player.homeyk
show_entity_picture: true
show_name: false
entity_picture: |-
"${ if (vars[0] === 'spotify') { '/local/image/spotify.svg' }
else if (vars[0] === 'http') { '/local/image/radio.svg' }
else { 'xxxxxxxxxxx' }
what i dont get, is the “else” at the end. I want that it shows the entity-picture that is give from the media player. Something like {{ state_attr(‘media_player.homeyk’, ‘entity_picture’) }}. How can i do this? I know its not something special for this thread, but i hope someone can help.
UPDATE:
I use a conditional, that works.
Does somebody already have a button / popup for a 3d-printer?
What has to be configured for the last_changed sensors to work? Can seem to get that one.
Are you talking about person/home? Nothing if you remove triggers_update
and variables
. If you want the timestamp to survive restarts hass-config@9738395
Never used config-template-card but it should be states['media_player.homeyk'].attributes.entity_picture
Hi Pex
Strangely enough, the calendar doesn’t show me tomorrow’s appointment. It only appears the next day
button:
In the calender, however, this is displayed as normal.
Calendar:
normaly they must show me: Hello Test
Any Idea?
Does anybody need more variables? The idea is that this part can easily be pasted when button_card_templates.yaml
is updated.
