Only the current day can be viewed via the calendar sensor. I’m trying to create a rest sensor to create an event list. Otherwise you have to use other cards like atomic calendar revive.
Hey, first, thanks for sharing your work, an excellent UI was the missing piece for me to finally leave Homekit for good (not that Homekit’s app was very good, but the controls were user-friendly).
I am still a new to HA, but I have a background in web development, my question is, what is the coding language in the yaml files, in the template.yaml file for example? Is there any documentation on the syntax? Is it python, embedded in yaml using something like handlebars? It’s a huge pain trying to write an if statement that executes properly just by following your existing code, if there’s somewhere I can look to check all the available methods and proper syntax it would speed up my efforts considerably.
Thanks Mattias for sharing your awesome dashboard and configuration. I had a tablet laying around for some time and not really used it. Decided to put some time and effort in using your dashboard and very happy with the result. The tablet now has a nice place in my living room
For my computer I have installed the dashboard as an app with Microsoft Edge which is also a cool solution. See the attached screenshot.
Thanks again for making and sharing this. It makes Home Assistant even nicer to use
These are lights that can only be dimmed and have no color attributes so that will be the reason that the light_colorcalculation in the button-card-template will return it as black.
The blanche_battery_sensor if from the Tesla integration that you are using. My wife named her Tesla “Blanche” (white in french). You reminded me that I need to change that back to the Teslamate value.
And you are correct, Teslamate doesn’t do climate (but it does have a on/off binary sensor for climate). That’s why I still use the tesla integration along the teslamate one.
Both are running at the same time and I use the info I need from one or the other, whatever one is more accurate in time.
I’m still tweaking it. It’s not a priority right now.
Funny enough my values had been missing for the Tesla Integration and just today HA asked me to refresh the Refresh token. That was a first.
Teslamate can be very powerful combined with Grafana and a database but I have to admit that I tried to make it work for months and was never able to so I gave up. I just use the values, no graphs.
I already have an iPhone app for the graphs so I’m good.
Man, I could never get it to work. I gave up when the database disappeared one day and then Teslamate wouldn’t work even after reset and deleting it and reinstall and the guy who created it couldn’t figure out why. Then 5 months later I tried to reinstall it and it worked. I just left it at that.
But thanks… I’m good though.
