A different take on designing a Lovelace UI
perhaps you must explain it a little bit more, the code you posted is from which file? the themes.yaml?
post the configuration.yaml and the themes.yaml file if this what you mean,
the line that you post has nothing todo with the themes.yaml?!
@weaverprojects
If you’re happy with it, I can make the hue:lily for you today, I just couldn’t make it yesterday
EDIT
Here you are
lily
icon_lily:
    styles:
      custom_fields:
        icon:
          - width: 100%
          - margin-left: -35%
          - margin-top: -20%
    custom_fields:
      icon: >
          let state = variables.state_on && variables.timeout < 2000 ? 'on' : null;
          return `
            <svg viewBox="0 0 40 40">
              <style>
                @keyframes on {
                  0% {
                    opacity: 0.5;
                  20% {
                    opacity: 1;
                  100% {
                    opacity: 1;
                .on {
                  animation: on 5s;
                  transform-origin: center;
              </style>
                <g transform="matrix(0.05 -0.0291 0.0383 0.0658 32.0409 15.6111)" id="806432">
                <path class="${state}" fill="var(--light-color)" style="stroke: none; stroke-width: 1; stroke-dasharray: none; stroke-linecap: butt; stroke-dashoffset: 0; stroke-linejoin: miter; stroke-miterlimit: 4; is-custom-font: none; font-file-url: none; fill-rule: nonzero; opacity: 1;" vector-effect="non-scaling-stroke" transform=" translate(-78.4998, -78.5)" d="M 78.5 0 C 52.9419 0 32.1166 35.2271 32.1166 78.5 C 32.1166 121.773 52.9419 157 78.5 157 C 104.058 157 124.883 121.773 124.883 78.5 C 124.883 35.2271 104.058 0 78.5 0 Z" stroke-linecap="round"/>
                </g>
                <g transform="matrix(1.3513 0 0 1.3513 24.9997 24.9996)" id="619688">
                <path  style="stroke: none; stroke-width: 1; stroke-dasharray: none; stroke-linecap: butt; stroke-dashoffset: 0; stroke-linejoin: miter; stroke-miterlimit: 4; is-custom-font: none; font-file-url: none;  fill: #9da0a2; fill-rule: nonzero; opacity: 1;" vector-effect="non-scaling-stroke" transform=" translate(-12.0077, -12.03)" d="M 20.5 6.6 c 0 -1 -0.4 -2.1 -1 -3.2 c -0.6 -1.1 -1.4 -2 -2.3 -2.5 c -0.9 -0.6 -1.8 -0.7 -2.5 -0.3 c 0 0 0 0 0 0 c 0 0 0 0 0 0 L 4.5 6.7 c 0 0 0 0 0 0 c -0.7 0.4 -1 1.2 -1 2.3 c 0 1 0.4 2.1 1 3.2 c 0.6 1.1 1.4 2 2.3 2.5 C 7 14.8 7.2 14.9 7.4 15 c 0.1 1.5 0.4 2.8 0.6 3.2 c 0.3 0.4 1 0.9 1.9 1.2 c -1.8 0.2 -3.7 0.6 -3.7 1.8 v 0.7 c 0 1.4 3.2 1.8 5.1 1.8 c 1.9 0 5.1 -0.4 5.1 -1.8 v -0.7 c 0 -1 -1.6 -1.5 -3.2 -1.7 c 0.7 -0.2 1 -0.6 1.2 -0.7 c 0.2 -0.1 0.3 -0.4 0.3 -0.7 c -0.1 -0.6 -0.7 -0.9 -1.2 -1 c -0.9 -0.3 -1.4 -0.3 -1.8 -0.2 c -0.2 -0.7 -0.2 -1.9 -0.2 -3.1 l 8 -4.7 c 0 0 0 0 0 0 c 0 0 0 0 0 0 c 0 0 0 0 0 0 c 0 0 0 0 0.1 0 c 0 0 0 0 0 0 C 20.2 8.4 20.6 7.7 20.5 6.6 z M 16.7 1.7 c 0.7 0.5 1.4 1.2 1.9 2.2 c 0.5 0.9 0.9 1.9 0.9 2.8 c 0 0.7 -0.1 1.2 -0.5 1.4 c -0.3 0.2 -0.9 0.1 -1.5 -0.3 c -0.7 -0.5 -1.4 -1.2 -1.9 -2.2 c -0.5 -0.9 -0.9 -1.9 -0.9 -2.8 c 0 -0.5 0.1 -1 0.3 -1.2 c 0 0 0 0 0 0 c 0.1 -0.1 0.1 -0.1 0.2 -0.2 c 0 0 0 0 0 0 c 0.1 -0.1 0.2 -0.1 0.4 -0.1 C 15.9 1.3 16.3 1.5 16.7 1.7 z" stroke-linecap="round"/>
                </g>
            </svg>
today i remake the lucca, its a little blurred
here is my hue:floor-lantern
lantern
icon_lantern_new:
    styles:
      custom_fields:
        icon:
          - width: 100%
          - margin-left: -25%
          - margin-top: -20%
    custom_fields:
      icon: >
          return `
              <style>
                @keyframes on {
                  0% {
                    opacity: 0.5;
                  20% {
                    opacity: 1;
                  100% {
                    opacity: 1;
                .on {
                  animation: on 5s;
              </style>
                <g transform="matrix(-0.0597 0 0 -0.097 25.1132 18.1834)" id="127847" clip-path="url(#CLIPPATH_3)">
                <clipPath id="CLIPPATH_3">
                <rect transform="matrix(1 0 0 1 0.0001 0.0005)" id="clip0_302_122" x="-79" y="-79.5" rx="0" ry="0" width="158" height="159"/>
                </clipPath>
                <path class="${state}" fill="var(--light-color)" style="stroke: none; stroke-width: 1; stroke-dasharray: none; stroke-linecap: butt; stroke-dashoffset: 0; stroke-linejoin: miter; stroke-miterlimit: 4; is-custom-font: none; font-file-url: none; ; fill-rule: nonzero; opacity: 1;" vector-effect="non-scaling-stroke" transform=" translate(-78.9999, -79.4995)" d="M 157.307 120.309 L 124.594 35.4256 C 124.113 34.1165 122.872 33.2477 121.485 33.249 H 36.2565 C 34.8878 33.2564 33.6712 34.1271 33.215 35.4256 L 0.231964 121.193 C -0.170713 122.206 -0.0439854 123.355 0.570009 124.254 C 1.16278 125.18 2.17913 125.742 3.27342 125.75 H 154.671 V 125.682 C 155.411 125.686 156.131 125.441 156.716 124.985 C 158.162 123.858 158.426 121.765 157.307 120.309 Z" stroke-linecap="round"/>
                </g>
                <g transform="matrix(1.3658 0 0 1.3658 25 25.0001)" id="191525">
                <path style="stroke: none; stroke-width: 1; stroke-dasharray: none; stroke-linecap: butt; stroke-dashoffset: 0; stroke-linejoin: miter; stroke-miterlimit: 4; is-custom-font: none; font-file-url: none; fill: #9da0a2; fill-rule: nonzero; opacity: 1;" vector-effect="non-scaling-stroke" transform=" translate(-11.9999, -11.6362)" d="M 13.89 9.73 c -1.07 -0.37 -2.71 -0.37 -3.78 0 L 9.2 3.46 c 1.78 0.22 3.82 0.22 5.6 0 L 13.89 9.73 z M 16.83 0.55 c -2.66 -0.73 -7.02 -0.73 -9.67 0 C 4.55 1.27 4.63 2.42 7.29 3.12 C 7.4 3.15 7.53 3.17 7.64 3.2 l 1.18 8.12 c 0.09 0.32 0.58 0.7 1.68 0.9 v 8.97 c -0.73 0.12 -1.27 0.31 -1.44 0.55 C 9.02 21.8 9 21.86 9 21.91 v 0.54 c 0 0.45 1.34 0.82 3 0.82 s 3 -0.37 3 -0.82 v -0.54 c 0 -0.3 -0.61 -0.56 -1.5 -0.71 v -8.98 c 1.09 -0.2 1.56 -0.59 1.68 -0.9 l 1.18 -8.13 c 0.12 -0.03 0.25 -0.05 0.36 -0.08 C 19.37 2.42 19.45 1.27 16.83 0.55 z" stroke-linecap="round"/>
                </g>
            </svg>
try this ,
add this over “const state”
          let color;
          if (variables.state === 'on' && variables.timeout < 2000) {
            color = 'var(--primary-color)';
          if (variables.state === 'off' && variables.timeout < 2000) {
            color = '#a0a0a0';
          if (variables.state === 'on' && variables.timeout > 2000) {
          if (variables.state === 'off' && variables.timeout > 2000) {
            color = '#a0a0a0';
and this to the path you want to color
fill="${color}"
and now you can change for the color you want
ON
OFF
#a0a0a0
Can someone please help me how i can fix this error?
i followed all the steps and when i want to restart homeassistant to change the theme after that i can not restart homeassistant becuase of this error:
Error loading /config/configuration.yaml: Secret monitors_mute_state not defined
that is because you are missing a included file where the “monitors_mute_state” is definied.
try delete the sensor or find it in the includs
Yes, it is from themes.yaml
I dont know what to explain, i only copied the files in my NUC and would give it a try
And it says that the problem is in that file, and so i copied the line out
I’m trying to change the ratio of the buttons. I’ve changed the ratio it to 3/1 (and some font-sizes etc.), but how do I get rid of the giant space between the buttons? I would like the same space as when the buttons were squares. I’ve tried to play around with the grid-template-row in the ui-lovelace.yaml but can’t get it to work. I’m I looking at the wrong place? Can someone point my in the right direction?
Try looking into the templates.yaml or the button_card_templates.yaml.
no idea if I understand you at all but I try to understand it again
this is the original themes.yaml from mattias
hass-config/themes.yaml at master · matt8707/hass-config (github.com)
line 28 is this
      input-ink-color: rgba(255, 255, 255, 0.87)
what is in your configuration.yaml in the line 28 ?
where can i find all the icons you used so i can change the icons i need to.
and how can i change the background? (wallpaper)
thx for the icons
where do you find all the icons? i need icons for shutters…
how did you manage to change the font size within the buttons on the panel? i would like to make it a little bit smaller
is it possible for you to adjust this icon and also the rest of the files for a cover with only a closed and open state pls? im having a hard time to get this working :frowning:
I tried you suggestion but it didn’t work,
maybe I didnt understand your instructions, this is how it looks after I changed it:
      icon_hue: >
          let color;
            color = '#a0a0a0';
            color = '#a0a0a0';
          return `
            <svg viewBox="0 0 50 50">
              <style>
                @keyframes on {
                  0% {
                    transform: scale(0.85);
                  20% {
                    transform: scale(1.1);
                  40% {
                    transform: scale(0.95);
                  60% {
                    transform: scale(1.03);
                  80% {
                    transform: scale(0.97);
                  100% {
                    transform: scale(1);
                .on {
                  animation: on 0.8s;
              </style>
              <path fill="${color}" d="M27.4 47.3h-4.9s-.7.1-.7.8.4.9.7.9h4.9c.3 0 .7-.1.7-.9s-.7-.8-.7-.8zm3.3-2.9H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0 .8-.1.8-.9-.1-.8-.9-.8-.9-.8zm0-3H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0 .8-.1.8-.9-.1-.8-.9-.8-.9-.8zm0-2.9H19.3s-.8 0-.8.8.6.9.8.9h11.5c.2 0 .8-.1.8-.9s-.9-.8-.9-.8zm5.2-23.2c-3.3-5.3-7-5.6-10.9-5.6-3.8 0-8.4.4-10.9 5.6-.1.1-.1.3.1.7.4.8 3.3 7.2 3.2 18.8 0 1.1-.1 1.6 0 1.7 0 .1 0 .7 1.1.7h13c1 0 1-.5 1.1-.7v-1.7c-.1-11.6 2.8-18 3.2-18.8.1-.4.1-.5.1-.7"/>
              <path class="${state}" fill="${color}" d="M14.1 15.3c3.4-.3 7-.4 10.9-.4 3.8 0 7.5.2 10.9.4.4-.4.7-.8.9-1.1C39 8.5 38.9 6.5 38.9 6c-.2-4.4-8.4-5-12.1-5h0-3.4c-3.7 0-12 .5-12.1 5 0 .5-.1 2.5 2.1 8.2 0 .3.3.8.7 1.1z"/>
            </svg>
Can you please verify it.
Thanks a lot.
I guess this has every thing to do with the grid you have defined. hoe have to make more grid rows
so more rows in grid area en don’t forget to edit the grid-row-template. If you add one row change the 2 into 3 and so on.
 grid-template-columns: repeat(4, 1fr) 0
  grid-template-rows: 0 repeat(2, fit-content(100%)) 0fr
  grid-template-areas: |
    "sidebar  .           .       .       ."
    "sidebar  vardagsrum  studio  sovrum  ."
    "sidebar  media       övrigt  hemma   ."
    "sidebar  footer      footer  footer  ."
try this
icon_hue: >
          let color;
            color = '#a0a0a0';
            color = '#a0a0a0';
          return `
              <style>
                @keyframes on {
                  0% {
                  20% {
                  40% {
                  60% {
                  80% {
                  100% {
                .on {
                  animation: on 0.8s;
              </style>
            </svg>
i am actually not at home to test it, but you forgot
Wow @AndyVRD, nice dashboard! Is it possible to share your config?
I’m sorry to say it’s still not working :frowning:
How can I change it to another Language? By Hand? Or can i set it anywhere?
hanks
Hello. How are you? Could you share the temperature card template? Thank you
