A different take on designing a Lovelace UI
Hi @Mattias_Persson. How do you get the youtube token to be seen in the media card?
okay, later this day i will have a look at it.
Hi! Quick question : where do you truncate the text into one line so it display “long tex…”?
I would rather have it on two lines…
Thanks in advance!
Thanks for your reply. I thought that would help too, but the space stays the same. (Or is it even a little bit bigger?) The grid-template-rows is updated to 3.
Hi @Mattias_Persson ,
Is it possible to create a icon and a button with up/stop/down for roller shutters and curtains?
Now it only support to push on it and use a pop-up or so.
Your help would mee much appreciated.
@Quinnod34 cool icons! Did you perhaps also have a cool icon for a sunshade?
Or anybody else, looking for a cool animated sunscreen icon for this dashboard :sunny:
Having loads of fun building out my own dashboard.
However, I feel like I’m missing something obvious as nothing shows in the Sidebar. Can anyone help me get pointed the right way as everything I’ve tried so far seems to get me nowhere? Thanks in advance.
Paste your ui-lovelace.yaml as a start.
Will answer my own question here incase anyone else is has the same problem.
Needed to add square: false to every grid-area.
      #                  VARDAGSRUM                   #
      - type: grid
        square: false
        title: Vardagsrum
        view_layout:
          grid-area: vardagsrum
        columns: 2
        cards:
Hello Guys. I need some help with the config. I just copy the copy of hass-config/popup/footer/updater.yaml
Error Msg : ButtonCardJSTemplateError: TypeError: Cannot read properties of undefined (reading 'state') in 'if (entity) { let links = new RegExp('<a href="([^"]+)"', "g"), installed = entity
And Also the Icon is very big, how to fix it?
entity: light.bed_light
icon: mdi:air-conditioner
tap_action:
  action: fire-dom-event
  browser_mod:
    command: popup
    title: Uppdateringar
    style:
        :host .content {
          width: 100%;
      hui-grid-card:
          button-card:nth-child(2),
          button-card:nth-child(4) {
            margin: 0.6em 0 2.1em 0.8em;
          button-card:nth-child(6) {
            margin: 0.6em 0 0.5em 0.8em;
          #root {
            grid-gap: 0 !important;
            padding: var(--card-content-padding);
            width: max-content;
    card:
      type: grid
      columns: 1
      square: false
      cards:
        - type: custom:button-card
          entity: sensor.hass_version_installed
          template: updater_hass
          triggers_update:
            - sensor.hass_version_latest
            - sensor.hass_version_latest_beta
          icon: mdi:update
          styles:
            card:
              - width: max-content
              - filter: |
                    return `[[[
                      if (entity) {
                        return entity.state === states['sensor.hass_version_latest'].state ||
                          entity.state === states['sensor.hass_version_latest_beta'].state
                            ? 'opacity(30%)'
                            : 'drop-shadow(3px 3px 5px #00000050)';
              - display: |
                    return `[[[
                      return entity
                        ? 'flex'
                        : 'none';
          tap_action:
            services: |
                return `[[[
                  hass.callService('browser_mod', 'toast', {
                    message: 'Startar watchtower...'
                  hass.callService('switch', 'turn_on', {
                    entity_id: 'switch.docker_watchtower'
          template: icon_name
          entity: sensor.hacs
          template: updater_hacs
          entity: sensor.hacs
          icon: mdi:open-in-new
          styles:
            card:
              - filter: |
                    return `[[[
                      if (entity) {
                        return entity.state === '0'
                          ? 'opacity(30%)'
              - display: |
                    return `[[[
                      return entity && entity.state !== 'unknown'
                        ? 'flex'
                        : 'none';
          template: |
              return window.navigator.userAgent.match(/iPhone/i)
                ? 'hacs_navigate_ios'
                : 'hacs_iframe';
          entity: sensor.template_updates
          template: updater_other
          icon: mdi:reload
          styles:
            card:
              - filter: opacity(30%)
              - display: |
                    return `[[[
                      return entity
                        ? 'flex'
                        : 'none';
          tap_action:
            toast: |
                return `[[[
                    message: 'Söker efter uppdateringar...',
                    duration: 3000
            action: call-service
            service: homeassistant.update_entity
            service_data:
              entity_id:
                - sensor.gosund_monitors_esphome_version
                - sensor.gosund_ac_esphome_version
                - sensor.gosund_fan_esphome_version
                - sensor.esphome_version_latest
                - sensor.playactor_version_installed
                - sensor.playactor_version_latest
                - sensor.kemper_version
                - sensor.udm_unifios
                - update.nas_dsm_update
          template: icon_name
I just easy to test the config with a simple button card. I can’t figure it out. please help.
Trying to get it fit and working on my Google Hub.
For some reason the touch input is lagging for the swipe animation en cuts out some of the buttons.
Anybody here that did get it to work though?
Hey, can you share that AC icon with me? I really like it!
can someone help me, if there is a solution to change the language or can somebody give me a translated version for german or english?
Big Thanks
The dashboard is made by Matias, his native langauge is Swedish, so he used Swedish words here and there because thats convenient for him. Just use a translator if you want to know what the word means.
Oh dear, thats clear. But i have seen many here in the thread using german or english. and the question is, can i change it by any settings or have i to set all the words by manual into an other language.
No, it’s manually written code. You can just copy and paste a file content into a translator, maybe that works for you, but no, there is no “feature” to translate anything in the config files… Atleast, not that I’m aware of.
Hi @Mattias_Persson How can I make the popup adapt to the number of icons I have? I can’t change the width of the window. Thank you very much
This is my code
browser_mod:
  command: popup
  title: Samsung Tv
  style:
    hui-vertical-stack-card:
        #root {
          padding-top: 1em;
        hui-horizontal-stack-card {
          padding: 0em 2em 1em  1em;
  card:
    type: vertical-stack
    cards:
      - type: horizontal-stack
        cards:
            icon: mdi:logout-variant
            tap_action:
              service: script.samsung_tv_source
            template: icon_only
Try this:
browser_mod:
  command: popup
  title: Living Room TV
  style:
          padding: 0em 2em 2.3em 2em;
      $hui-horizontal-stack-card:
          #root {
            justify-content: space-evenly;
  card:
    cards:
      - type: entities
        state_color: true
        show_header_toggle: false
        card_mod:
          class: content
        entities:
          - entity: media_player.lg_webos_smart_tv
            name: LG Smart TV
            secondary_info: last-changed
#          - entity: automation.tv_on_lights
          - entity: select.hdmi_lg
      #                TOP ROW BUTTONS                #
        cards:
      #                  MENU BUTTON                  #
            icon: mdi:menu
            tap_action:
              service: script.lg_tv_menu
            template: icon_only
Thanks for answering. The size of the window remains the same. If the buttons were centered.
Look in the “/config/popup/footer/nas.yaml” and play around with the width there.
