A different take on designing a Lovelace UI
I don’t understand exactly what you mean?
I just answered a question from @henkkeumus and provided the solution for the slide effect with deep.
here is my working example
swipe
I know. What I meant was that inside your slider you cannot include something like a volume control input_number input … or at least I have never found a “decent” way that functions properly.
Given your example, what if I had this inside the slider?
Try then to change the volume. You can, clicking certainly. Sliding the volume control, kludgy at best. I tried many/most of the slider card parameters from slider.js and cannot get it to act like I would want it. Because sliding the volume control also slides the panel.
Oh and in testing again, implementing something with a hold-action seems to not work. I had a series of remote controls for my TVs and changed from swiper card to vertical stack and all hold actions now work (they do not on a PC with swiper).
Too bad because it is pretty … but pretty non-functional too for many cases.
Yes, that’s right, the swiper card is unfortunately very bitchy and hasn’t been developed further for ages.
but I think I would have done it when I had read the thread and tried everything possible.
It was never perfect but I think it was possible to get what you’re trying to do.
If I find the time again, I’ll try the whole thing again and then give you feedback.
EDIT
this can be a solution
allowTouchMove: false
How to add double arrow?
Thanks for the suggestion. In the end I went with collapse cards as they provided a GUI my wife and kids would use. They click to open the remote control and then do as they desire. No sliding involved and everything works.
For Anyone wanting it I created an Octoprint 3D Printer card to use with Matthias’s UI style:
button_card_templates.yaml code:
printer:
  template:
    - base
  aspect_ratio: 1/1
  show_state: true
  show_icon: false
  show_name: true
  show_current_temperature: true
  show_control: true
  state:
    - operator: template
      value: sensor.octoprint_print_state
  custom_fields:
    circle: >
        if (Math.round(states['sensor.octoprint_percentage_complete'].state) > 0 && states['sensor.octoprint_percentage_complete'].state < 100) {
          const input = states['sensor.octoprint_percentage_complete'].state
          const radius = 20.5;
          const circumference = radius * 2 * Math.PI;
          return `
            <svg viewBox="0 0 50 50">
              <style>
                circle {
                  transform: rotate(-90deg);
                  transform-origin: 50% 50%;
                  stroke-dasharray: ${circumference};
                  stroke-dashoffset: ${circumference - input / 100 * circumference};
                tspan {
                  font-size: 10px;
              </style>
              <circle cx="25" cy="25" r="${radius}" stroke="#b2b2b2" stroke-width="1.5" fill="none" />
              <text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${input}<tspan font-size="10">%</tspan></text>
            </svg>
Modify the line below in the “base” template to include “Printing” as an “on” state:
Note: This is what controls when a card’s background turns white for future reference…
base:
  template:
    - settings
  variables:
    state_on: >
      [[[ return ['on', 'home', 'cool', 'fan_only', 'playing','Printing'].indexOf(entity === undefined || entity.state) !== -1; ]]]
    state: >
#Rest of base template
Icon Code (to be added to the bottom of button_card_templates.yaml):
icon_3dprinter:
  styles:
    custom_fields:
      icon:
        - width: 77%
        - margin-left: 1%
        - margin-top: 5%
  custom_fields:
    icon: >
      <svg viewBox="0 0 90 73">
        <<g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g><rect fill="#9da0a2" x="0" y="63" width="90" height="10" rx="3"></rect><rect fill="#9da0a2" transform="translate(10.000000, 33.000000) rotate(90.000000) translate(-10.000000, -33.000000) " x="-23" y="30" width="66" height="6" rx="3"></rect><rect fill="#9da0a2" transform="translate(78.000000, 34.000000) rotate(90.000000) translate(-78.000000, -34.000000) " x="44" y="31" width="68" height="6" rx="3"></rect><path d="M7,3 C7,1.34314575 8.34757814,6.41357826e-15 9.99253964,6.2593707e-15 L78.0074604,-1.16714867e-16 C79.6601944,-2.71651068e-16 81,1.34651712 81,3 L81,3 C81,4.65685425 79.6524219,6 78.0074604,6 L9.99253964,6 C8.33980564,6 7,4.65348288 7,3 L7,3 Z" fill="#9da0a2"></path><rect fill="#9da0a2" x="16" y="56" width="56" height="3"></rect><rect fill="#9da0a2" transform="translate(44.000000, 26.500000) scale(1, -1) translate(-44.000000, -26.500000) " x="12" y="25" width="64" height="3"></rect><rect fill="#9da0a2" transform="translate(44.000000, 19.500000) scale(1, -1) translate(-44.000000, -19.500000) " x="12" y="18" width="64" height="3"></rect><rect fill="#9da0a2" x="25" y="23" width="15" height="10"></rect><rect fill="#9da0a2" x="31" y="31" width="3" height="4"></rect></g></g>>
      </svg>
lovelace.yaml code: add this to where you want the card to live in your dashboard
          - type: custom:button-card
            entity: sensor.octoprint_print_state
            tap_action: !include popup/Printer.yaml
            template:
              - base
              - printer
              - icon_3dprinter
and popup/Printer.yaml code: (this requires the threedy card from HACS)
action: fire-dom-event
browser_mod:
  command: popup
  title: Printer
  style:
      :host .content {
        width: calc(385px + 510px);
        max-width: 90vw;
      threedy-card div div div:nth-child(2) {
        height: auto !important;
        opacity: 1 !important;
            transform: none !important;
    layout-card$grid-layout:
        hui-vertical-stack-card {
          animation: border 1s forwards;
        @keyframes border {
          0%, 100% {
              border-right: 1.5px solid rgba(0, 0, 0, 0.2);
        /* phone */
        @media screen and (max-width: 800px) {
              border-bottom: 1.5px solid rgba(0, 0, 0, 0.2);
              padding-right: 0;
              animation: none;
      $hui-vertical-stack-card:
          hui-horizontal-stack-card {
            padding: 0em 2em 2.3em 2em;
        $hui-entities-card$: |
          .card-content {
            padding: var(--card-content-padding);
        $hui-horizontal-stack-card$: |
          #root {
            justify-content: space-evenly;
  card:
    type: custom:threedy-card
    base_entity: sensor.octoprint
    monitored:
      - Status
      - ETA
      - Elapsed
      - Hotend
      - Bed
      - Remaining
    printer_type: I3
    name: Prusa Mk2.5S Bear
    theme: Default
    temperature_unit: C
NOTE: using this card requires you to add the following template sensors:
template:
  - sensor:
      - unique_id: OctoPrint Time Elapsed
        name: "OctoPrint Time Elapsed"
        unit_of_measurement: "s"
        availability: >
          {{ not is_state('sensor.octoprint_start_time', 'unavailable') }}
        state: >
          {% set start = as_timestamp(states('sensor.octoprint_start_time')) %}
          {% if is_number(start) %}
            {{ (as_timestamp(now()) - start) | int }}
          {% else %}
            unknown
          {% endif %}
        attributes:
          start_time: "states('sensor.octoprint_start_time')"
      - unique_id: OctoPrint Time Remaining
        name: "OctoPrint Time Remaining"
        availability: >
          {{ not is_state('sensor.octoprint_estimated_finish_time', 'unavailable') }}
        state: >
          {% set finish = as_timestamp(states('sensor.octoprint_estimated_finish_time')) %}
          {% if is_number(finish) %}
            {{ (finish - as_timestamp(now())) | int }}
          {% else %}
            unknown
          {% endif %}
        attributes:
          start_time: "states('sensor.octoprint_estimated_finish_time')"
      - unique_id: OctoPrint Percentage complete
        name: "OctoPrint Percentage Complete"
        unit_of_measurement: "%"
        state: >
          {{ states['sensor.octoprint_job_percentage'].state | round(0)}}
      - unique_id: OctoPrint Print State
        name: "OctoPrint Print State"
        state: >
          {% if is_state('sensor.octoprint_current_state', 'Operational') %}
            idle
          {% elif is_state('sensor.octoprint_current_state', 'Printing from SD') %}
            Printing
          {% elif is_state('sensor.octoprint_current_state', 'Starting print from SD') %}
            Printing
          {% else %}
            Down
          {% endif %}
Threedy Card can be found here although be warned it seems to be a dead project:
https://github.com/dangreco/threedy
BE WARNED: The pop-up card does not currently scale to mobile resolutions as the code above stands… I’m not an expert by any means but I THINK it’s because the threedy card does not support it but if someone wants to swing by the thread and see if I messed up the scaling somewhere along the way let me know…
you mean behind the name?
title: Wohnzimmer ↔
easy copy it here and paste it in your ui-lovelace.yaml behind the name
anyone else having issue with sidebar not showing after update to Home Assistant 2022.7.0 my sensor.template_sidebar doesn’t exsist anymore the state list
Mine is working fine. Did you check the update blog to see what breaking changes they did? They did some changes to Google Calendars so maybe that might be affecting you.
Indeed! I have it too.
Thought it was the sonoff update at first but maybe its the version update… ill rollback the backup from yesterday.
Hello. How do I identify if it is the battery percentage or the lock, what I want to see in the upper right space.
Because the circle is configured with a width of 45 and so the padlock looks good but the percentage does not. Since the two share the same configuration. Do I have a way to put a condition to know who I am setting that width for? Thank you
Sin título
lock:
  tap_action:
    loader: |
        let elt = this.shadowRoot;
        if (variables.state_on && variables.lock === 'locked') {
          elt.getElementById('lock').classList.add('locked');
          window.setTimeout(() => {
            elt.getElementById('lock').classList.remove('locked');
          }, 1100);
        } else {
          let loader = (id, style, timeout) => {
              elt.getElementById(id) && (elt.getElementById(id).style.display = style,
                  elt.getElementById('loader').style.display = 'none'
                }, 20000))
          loader('circle', 'none', 'initial'),
          loader('loader', 'initial', 'none');
  custom_fields:
    circle: >
        if(entity) {
          let state = states[entity.entity_id + '_estado_de_sesion'].state.toLowerCase();
          if (state === 'locked') {
            return `
                <style>
                  @keyframes locked {
                    from,
                    to {
                      transform: translateX(0);
                    10%,
                    30%,
                    50%,
                    70%,
                    90% {
                      transform: translateX(-8%);
                    20%,
                    40%,
                    60%,
                    80% {
                      transform: translateX(8%);
                  .locked {
                    animation: locked 1.1s;
                </style>
                <path id="lock" class="${state}" d="M8.2 22.6h2.4v-7.2C10.6 7.5 17.1 1 25 1s14.4 6.4 14.4 14.4v7.2h2.4V49H8.2m26.4-26.4v-7.2c0-5.3-4.3-9.6-9.6-9.6s-9.6 4.3-9.6 9.6v7.2"/>
              </svg>
          } else {
            let bateria = "";
            const stroke_color = '#b2b2b2';
            const fill_color = 'none';
            if(entity.state == 'online') {
              if(entity.entity_id == 'sensor.pc_florencia')
                bateria = states['sensor.pc_florencia_bateria_charge_remaining_percentage'].state + "%";
              if(entity.entity_id == 'sensor.pc_milena')
                return;
              let stroke_color = '#b2b2b2';
              let fill_color = 'rgba(255,255,255,0.04)';
              return `
                  <circle cx="29" cy="21" r="20.5" stroke="${stroke_color}" stroke-width="1.5" fill="${fill_color}" />
                  <text x="60%" y="45%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${bateria}</text>
                </svg>
  styles:
    custom_fields:
      circle:
        - width: 45%
        - fill: var(--state-icon-color)
        - margin: 1% 2% 0 0
        - justify-self: end
        - opacity: 1
        - display: grid
Hey Lars,
I’ve restored a backup from yesterday. This backup is on the latest version 2022.7.0 and sidebar works.
I’m now going to update the Sonoff LAN intergration from HACS as that was something I updated too as the intergration broke yesterday due to an issue with an ID hidden in the code.
… Maybe that breaks it… I’ll report back in a min :slight_smile:
i see your door icon, is it animated?
or is this the default “icon_closet” icon ?
Yep its the closet icon indeed.
Welp, restored backup and updated every addon again, sidebar still works so I have no clue what broke it in the first place then lol …
@larsvb88 The update broke more than the sidebar. Due to the fact it’s running on a new BT engine and Python 3.0 more addons break with this update unfortunatly. I think rolling back to 6.7 is the best (for me) at this point.
That’s sad, did look forced breaking changes but couldn’t find any particular that would affect the sidebar template. Hmm also roll back to a previous backup for now
Mine broke too. But checking the logs showed it was because somehow the sidebar entity was duplicated and it wouldn’t allow two entities with the same name/ID.
So for now I’ve renamed it in template to sidebar2 and referenced that in the UI yaml and everything is running smoothly on the new HA core.
Someone explain to me how it works and what the card lock icon Gives?
@Mattias_Persson
hey
perhaps you can help me, i use this code, but now the tilt animation is gone and the biggest problem my graph is not rounded at the bottom and the graph gradient is not high enough, i tried it now for hours, but i had no luck.
can you please help?
shit
            template:
              - temperature
              - icon_climate
            entity: sensor.multisensor_ankleidezimmer
            tap_action:
              action: none
            hold_action:
              action: none
            custom_fields:
              graph:
                card:
                  entities:
                    - entity: sensor.multisensor_ankleidezimmer
                      color_thresholds:
                        - value: 0
                          color: "#276696"
                        - value: 69
                          color: "#228C22"
                        - value: 75
                          color: "#d35400"
                        - value: 76
                          color: "#c0392b"
and the code from the button-card-templates
temperature:
    template:
      - base
    show_name: true # Hides Card Name
    show_state: true # Hides Card state
    state_display: >
      [[[ return '&nbsp;'; ]]]
    custom_fields:
      circle: >
        const temperature = Math.round(entity.state);
        return `<svg viewBox="0 0 50 50"><circle cx="25" cy="25" r="20.5" stroke="#313638" stroke-width="1.5" fill="#FFFFFF08" style="
        transform: rotate(-90deg); transform-origin: 50% 50%;" />
        <text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle" dominant-baseline="middle">${temperature}°C</text></svg>`; } ]]]
      graph:
        card:
          type: "custom:mini-graph-card"
          height: 140
          hours_to_show: 24
          points_per_hour: 1
          line_width: 8
          font_size: 75
          decimals: 0
          animate: true
          show:
            icon: false
            state: false
            legend: false
            labels: false
            labels_secondary: false
            points: false
          color_thresholds:
            - value: 0
              color: "#276696"
            - value: 69
              color: "#228C22"
            - value: 75
              color: "#d35400"
            - value: 76
              color: "#c0392b"
    styles:
      custom_fields:
        graph: [bottom: 8%, left: 2%, width: 123%, position: absolute, margin: 0% 0% -13% -14%]
        icon:
          - width: 67%
          - fill: "#9da0a2"
        circle:
          - display: initial
          - width: 90%
          - margin: -6% -5% 0 0
          - justify-self: end
          - opacity: 1
