@Mattias_Persson hi, how I get these sensors?
sensor.hass_version_installed
sensor.hass_version_latest
with the version integration it doesn’t work…
thx in adv.
thx in adv.
Hello. Did you add this integration?
[Link to Integrations: Add integration – My Home Assistant](https://Version Integration)
Hi. What calculation did you make to complete the circle according to the value it has inside. Thank you
Hello. Could someone share the temperature card template? Thank you
variables:
circle_input: >
let sensor = states['sensor.your_volume_entity_here'];
return sensor === undefined || sensor.state;
thanks for the reply. I did not express myself very well. I meant the whole card. I’m having trouble displaying the chart properly as it doesn’t fill all the way to the bottom and there’s a gap at the bottom of the card
Mmh, I have an AC and made 3 scripts. Every script has it’s own timer inside (1hr, 2hrs and 3hrs).
Now I want to link this script to a button to trigger the AC to run it for a certain amount of time and to shutoff.
Now, it works when I add the template ‘- base’ to it, but it doesn’t work if I want to run it on the custom button card with the template ‘- icon_only’.
The scaling doesn’t work very well with the base template on the entity so I have no clue how to proceed here.
My current config:
- type: custom:button-card
entity: script.1u_ac_slaapkamer
hold_action:
action: none
icon: mdi:numeric-1-box
template:
- icon_only
Also tried (but didnt work)
tap_action:
action: call-service
service: script.turn_on
service_data:
entity_id: script.1u_ac_slaapkamer
template: icon_only
Can somebody help me with this?
Can you send a screenshot, I dont get what you mean with this.
I got here and I don’t know how to continue. The graphic was outside the card
This is my card. this is the code from @Mattias_Persson
and this is my code in the ui-lovelace.yaml
entity: sensor.sensor_terrasse_temperature
tap_action: none
state_display: >
[[[ return ' '; ]]]
template:
- base
- circle
- icon_climate
custom_fields:
icon: >
<ha-icon icon="mdi:thermometer" style="color: #9da0a2;"></ha-icon>
circle: >
if (entity) {
return `
<svg viewBox="0 0 50 50">
<circle cx="25" cy="25" r="20.5" stroke="none" stroke-width="1.5" fill="rgba(255,255,255,0.04)" />
<text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${parseInt(entity.state)}<tspan font-size="10">°C</tspan></text>
</svg>
graph:
card:
type: sensor
entity: >
[[[ return entity.entity_id; ]]]
graph: line
card_mod:
style: |
.header, .value, .measurement {
display: none !important;
push_graph: >
setTimeout(() => {
let elt = this.shadowRoot,
card = elt.getElementById('card'),
container = elt.getElementById('container'),
graph = elt.getElementById('graph');
if (elt && card && container && graph) {
card.insertBefore(graph, container);
}, 0);
return null;
styles:
custom_fields:
graph:
- position: absolute
- width: 100%
- height: 100%
- clip-path: inset(0 round var(--custom-button-card-border-radius))
- left: 0
- bottom: 0
Cool. thanks for sharing. With this I will be able to see what the problem was
Excellent friend. I work perfect. Thank you very much
The only thing I don’t understand is where the color of the line comes from
You can just add the color parameter at the css styling
- color: '#html_color_code_here'
@Mattias_Persson how did you get it sorted to get the slide animation? Like, when you slide in your gif it has some depth to it. Mine just staticly slides from left to right.
If I don’t change it in the repository, it has it as you want.
I was trying with line-color. Thank you
add effect: ‘coverflow’ to the parameters of the swipe card in ui-lovelace.yaml
- type: custom:swipe-card
parameters:
effect: 'coverflow'
speed: 550
spaceBetween: 40
threshold: 5
here is the thread with examples
could you show an example were to place the color option in the code?
thx
Just don’t include something like a slider on your card , or do you have a solution for that? I mostly gave up on swiper because I could not have a slider that would not also cause swiping and my wife said “forget it”
Like input_number slider in a card which you can say “I am sliding that and not the card” … I gave up. Gave her a hold_action
