I don’t know if you solved it already, but I solved the problem by adding the theme again. This caused problems due to the changes in extra_styles.yaml.
@venealis
I’ve run it on a Windows server for a while, but just recently migrated it back to a Synology NAS.
The Windows server used HASS.Agent. And now I’m just using the Synology integration.
Here’s the current popup (plex.yaml called with tap_action)
action: fire-dom-event
browser_mod:
command: popup
title: Plex
style:
:host .main-title {
pointer-events: none;
hui-vertical-stack-card:
$hui-conditional-card>hui-vertical-stack-card$: |
hui-horizontal-stack-card {
padding: 0em 2em 1.5em 2em;
$hui-conditional-card>hui-vertical-stack-card$hui-horizontal-stack-card$: |
#root {
justify-content: space-evenly;
card:
type: vertical-stack
cards:
### ON ###
- type: conditional
conditions:
- entity: binary_sensor.ping_rackstation
state: 'on'
card:
cards:
- type: entities
state_color: true
card_mod:
class: content
entities:
- entity: switch.wol_plex
secondary_info: last-changed
icon: mdi:power
- type: custom:bar-card
width: 55%
height: 2em
decimal: 0
unit_of_measurement: '%'
positions: &pos
icon: outside
indicator: 'off'
severity: &sev
- color: '#303435'
to: 89
- color: '#6d2525'
to: 100
entity_row: true
entities:
- entity: sensor.rackstation_cpu_utilization_total
tap_action:
action: call-service
service: homeassistant.update_entity
service_data:
entity_id: sensor.rackstation_cpu_utilization_total
- entity: sensor.rackstation_memory_usage_real
tap_action:
service_data:
entity_id: sensor.rackstation_memory_usage_real
- entity: sensor.plex_issues
- entity: sensor.plex_sagaflix
icon: mdi:progress-upload
- entity: sensor.rackstation_last_boot
- entity: sensor.sagaflix_library_movies
- entity: sensor.sagaflix_library_tv_shows
- type: horizontal-stack
cards:
- type: custom:button-card
icon: mdi:power-sleep
tap_action:
service: switch.toggle
service_data:
entity_id: switch.hass_custom_sleep_cmd
template: icon_name
icon: mdi:cog-refresh
tap_action:
service_data:
entity_id: switch.hass_custom_hass_restart
template: icon_name
icon: mdi:restart
tap_action:
service_data:
entity_id: switch.hass_pc_restart
template: icon_name
### OFF ###
- type: conditional
conditions:
state: 'off'
card:
cards:
- type: entities
state_color: true
show_header_toggle: false
card_mod:
class: content
entities:
cards:
icon: mdi:power
tap_action:
service: switch.turn_on
service_data:
entity_id: switch.wol_plex
template: icon_name
Appreciate it thanks
I made an attempt at getting the circle value in a more generic way. but im going to give up for now.
the issue I have is the number of switches on is not up to date, it always displays 1, but ill post the code so you have more of a base to work from. this was added to the template code you posted above
variables:
circle_input: >
let on = 0, id = Boolean(entity.attributes.entity_id)
? [entity.entity_id].concat(entity.attributes.entity_id)
: [entity.entity_id];
for (let i = 1; i < id.length; i++) {
if(states[id[i]].state == 'on') on++
return entity === undefined || Math.round(on / (id.length -1) * 100 ) ;
custom_fields:
circle: >
let input = variables.circle_input,
radius = 20.5,
circumference = radius * 2 * Math.PI;
let inner_text = `${on} / ${(id.length -1)}`
return `
<svg viewBox="0 0 50 50">
<style>
circle {
transform: rotate(-90deg);
transform-origin: 50% 50%;
stroke-dasharray: ${circumference};
stroke-dashoffset: ${circumference - input / 100 * circumference};
tspan {
font-size: 10px;
</style>
<circle cx="25" cy="25" r="${radius}" stroke="#b2b2b2" stroke-width="1.5" fill="none" />
<text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${inner_text}</text>
</svg>
so I have been working on integrating my AC that was just a input_select for fan level and is now using the generic_thermostat, but I having an odd issue tithe the icon_fan2, on the left is the new card and on the right is the old card.
I found that the issue was when the icon was used along with the circle,
Fix
I needed to apply a better css selector in the icon’s css so it would over ride the css from the circle, I did try important but that didn’t work.
icon_fan2:
styles:
custom_fields:
icon:
- width: 75%
- margin-left: -3%
custom_fields:
icon: >
let path = `
<circle cx="25" cy="25" r="6.6"/>
<path d="M31.9 30.4c-.5.6-1.1 1.1-1.7 1.5-1.4 1.1-3.2 1.7-5.2 1.7-2.3 0-4.5-.9-6-2.4-.9 1.1-1.6 2.3-2.3 3.2l-4.9 5.4c-1.8 2.7.3 5.6 2.5 7 3.9 2.4 9.8 3.1 14.1 1.9 4.6-1.3 7.9-4.7 7.4-9.7-.2-3.4-1.9-6-3.9-8.6zM17 28.3c-.4-1-.6-2.1-.6-3.3a8.7 8.7 0 0 1 6.4-8.4l-1.6-3.5L19 6.2c-1.5-2.8-5-2.5-7.3-1.2-4 2.2-7.5 6.9-8.7 11.3-1.2 4.6.2 9.2 4.7 11.3 3.1 1.3 6.1 1.2 9.3.7zm26.9-17.6c-3.3-3.4-8-4.6-12.1-1.8-2.8 1.8-4.2 4.6-5.5 7.5 4.2.6 7.4 4.2 7.4 8.6 0 .9-.1 1.7-.4 2.5 1.3.2 2.8.3 3.8.4 2.3.4 4.7 1.3 7.1 1.7 3.2.3 4.7-3 4.8-5.6.3-4.6-1.9-10.1-5.1-13.3z"/>
style = `
<style>
@keyframes rotate {
0% {
visibility: visible;
transform: rotate(0deg) translateZ(0);
100% {
transform: rotate(1080deg) translateZ(0);
.start {
animation: rotate 2.8s ease-in;
transform-origin: center;
fill: #5daeea;
visibility: hidden;
will-change: transform;
.start > circle {
fill: #5daeea;
.on {
animation: rotate 1.8s linear infinite;
fill: #5daeea;
animation-delay: 2.8s;
visibility: hidden;
.on > circle {
fill: #5daeea;
.end {
animation: rotate 2.8s;
fill: #9ca2a5;
animation-timing-function: cubic-bezier(0.61, 1, 0.88, 1);
.end > circle {
fill: #9ca2a5;
.start_timeout {
fill: #5daeea;
visibility: hidden;
.start_timeout > circle {
fill: #5daeea;
.end_timeout {
fill: #9ca2a5;
.end_timeout > circle {
fill: #9ca2a5;
</style>
if (variables.state_on && variables.timeout < 2000) {
return `${style}<g class="start">${path}</g><g class="on">${path}</g></svg>`;
if (variables.state === 'off' && variables.timeout < 2000) {
return `${style}<g class="end">${path}</g></svg>`;
if (variables.state_on && variables.timeout > 2000) {
return `${style}<g class="start_timeout">${path}</g></svg>`;
} else {
return `${style}<g class="end_timeout">${path}</g></svg>`;
Hi! I feel like I’m missing something stupid. The sidebar isn’t coming up even though I haven’t done any edits to it yet. Any ideas? Thanks!
Got the same error yesterday, while I forgot to close a bracket inside a if-condition.
Hey @Laffer, these popups look great!
Are you able to share the code please? Or do you have a repo I could browse through etc?
Thanks!
Hey, fresh HA user here!
I have been trying to add this UI to my home assistant, without proper success.
I’m currently struggling on getting the button_card_templates to work and this is my setup:
The button card template is not defined in config.yaml, if it should be, which way to add it?
I’m completely new to programming so it might be an easy fix, but it seems i can not make HA read the yaml files inside “button_card_templates”, i have been searching online for hours…
I have tested with 'button_card_templates / ’ and without ’ / '… NB, the " behind is not there usually, was after a test i performed.
Can someone tell me what to do to get these button-card templates to work?
Figured it out! Somehow the ’ turned into ` so I replaced those and got it working
Copy this in your first line:
button_card_templates:
!include_dir_merge_named button_card_templates
In your case its “button-card-templates” instead of “button_card_templates”
On firefox it is very blurry as well here. Is there any way to "configure"this in the tilt.yaml or int he tilt JS we included? the gif is not showing the heavyness of the issue tho.
Uh, this worked, thank you!!! I feel pretty stupid right now, but i feel i have tested that out earlier so i don’t really understand what i have done wrong. But as long as it works now.
has perhaps some make a animated volume icon?
for on / off state?
Welcome @AlfieJ04
They are amazing.
I don’t have all of them but I did copy the Plex one with some edits to get it working for my HA set-up.
Most of the work with the popups like this is getting the data, crating the popup after that is not that bad.
Code
browser_mod:
command: popup
title: Plex
style:
padding: 0em 2em 2.3em 2em;
#root {
card:
cards:
- type: entities
state_color: true
card_mod:
class: content
entities:
- entity: switch.docker_plex
icon: mdi:power
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: '#6d2525'
to: 999
entity_row: true
entities:
- entity: sensor.template_plex_cpu
- entity: sensor.template_plex_mem
- entity: sensor.template_plex_state
icon: mdi:heart-pulse
- type: divider
- entity: sensor.plex_crawfordnas
- entity: sensor.crawfordnas_library_audiobooks
- entity: sensor.crawfordnas_library_movies
- entity: sensor.crawfordnas_library_tv_shows
cards:
name: Scan Libraries
icon: mdi:refresh
tap_action:
service: script.plex_refresh_all
template: icon_name
icon: mdi:magnify
tap_action:
service: button.press
service_data:
entity_id: button.scan_clients_crawfordnas
template: icon_name
Hi @masoncrawford1994, thanks for sharing.
I did manage to get something similar put together in the end;
nice work, I like the Movies and Tv shows displaying the usage ill need to look into if I can get that data out of Plex.
Depending on how you have your Plex instance configured, you could use SSH command-line sensors similar to mine;
movies_folder_used: ssh -q -o StrictHostKeyChecking=no -i /config/.ssh/id_rsa <yourUser>@<yourServer> du -shc <yourFolder> | awk '{print $1}' | tail -n 1 2>/dev/null
movies_folder_items: ssh -q -o StrictHostKeyChecking=no -i /config/.ssh/id_rsa <yourUser>@<yourServer> ls -1U <yourFolder> | wc -l | awk '{print $1}' | tail -n 1 2>/dev/null
My popup entry looks like this:
- entity: sensor.movies_folder_items
type: custom:multiple-entity-row
state_header: current
show_state: false
icon: "mdi:folder-play"
#secondary_info: last-changed
entities:
- entity: sensor.movies_folder_used
I cant read the text on my popups on my tablet. On mobile or browser everything works.
What could this be?
Set theme to dark
