A different take on designing a Lovelace UI
It worked, thank you very much!
yes, the dates are in the future.
i use tract integration for this card.
I liked the idea that from my current series/movies the information about the next upcoming episode is shown.
hi
How can I reduce the display on the sides everything escapes me.
Here’s my code.
action: fire-dom-event
browser_mod:
  service: browser_mod.popup
    title: Device Tracker
    content:
      type: grid
      columns: 2
      square: false
      cards:
        #01
        - type: custom:bar-card
          width: 55%
          height: 2em
          decimal: 0
          unit_of_measurement: '%'
          positions:
            icon: outside
            indicator: 'off'
          severity:
            - color: '#6d2525'
              to: 999
          entity_row: true
          entities:
            - entity: device_tracker.amazon_echo_dot
            - entity: device_tracker.amazon_echo_show
            - entity: device_tracker.khdr_mkhshbym_deco
            - entity: device_tracker.living_room_deco
            - entity: device_tracker.qvmh_shnyh_deco
            - entity: device_tracker.oven
        #02
          width: 45%
          height: 2em
          decimal: 0
          positions:
            icon: outside
            indicator: 'off'
          severity:
            - color: '#6d2525'
              to: 999
          entity_row: true
          entities:
            - entity: device_tracker.macbook_pro
            - entity: device_tracker.avi_phone
            - entity: device_tracker.camera_warehouse
        #03
          width: 55%
          height: 2em
          decimal: 0
          positions:
            icon: outside
            indicator: 'off'
          severity:
            - color: '#6d2525'
              to: 999
          entity_row: true
          entities:
            - entity: device_tracker.dishwasher
        #04
          width: 55%
          height: 2em
          decimal: 0
          positions:
            icon: outside
            indicator: 'off'
          severity:
            - color: '#6d2525'
              to: 999
          entity_row: true
          entities:
          columns: 2
          square: true
Thanks to the answers
@Mattias_Persson could you explain how i have to change the code to use browser mod 2 with version 2022.3? The popups are transparent with this version.
So maybe I am dense, but I am not 100% certain who to integrate this cover with this project… which one is the card in the actual lovelace.yaml and which one goes into the buttonc ard templates?
Could you post this card , I really like it
Anyone know why i’m not able to select vacuum cleaning mode from the dropdown, when i press on the dropdown list it closes the popup window?
it’s a bug in vacuum card, please update it:
I am quite new at coding in home assistant and I am having an issue where this button card shows up incorrectly on desktop, however it shows correctly on mobile.
Desktop:
Does anyone have any pointers on how to fix this?
lovelace code:
- type: custom:button-card
  entity: sensor.slaapkamer_aqara_temperature
  tap_action:
    action: none
  hold_action:
    action: none
  custom_fields:
    graph:
      card:
        entities:
          - sensor.slaapkamer_aqara_temperature
  template:
    - base
    - temperature
    - icon_temp
Temperature template:
temperature:
  show_state: false
  custom_fields:
    circle: >
      const temperature = Math.round(entity.state);
      return `<svg viewBox="0 0 50 50"><circle cx="25" cy="25" r="20.5" stroke="#313638" stroke-width="1.5" fill="#FFFFFF08" style="
      transform: rotate(-90deg); transform-origin: 50% 50%;" />
      <text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle" dominant-baseline="middle">${temperature}°</text></svg>`; } ]]]
    graph:
      card:
        type: "custom:mini-graph-card"
        graph_span: 1d
        locale: nl
        line_color: "#3182b7"
        line_width: 4
        font_size: 75
        show:
          icon: false
          state: false
          legend: false
          labels: false
  styles:
    name: [top: 57%, left: 10%, width: 100%, position: absolute]
    custom_fields:
      graph: [bottom: 0%, left: 0%, width: 100%, position: absolute]
      circle:
        - display: initial
        - width: 90%
        - letter-spacing: 0.03vw
        - margin: -6% -6% 0 0
        - justify-self: end
        - opacity: 1
      icon:
        - width: 67%
        - fill: "#9da0a2"
The base template is an exact copy of Mattias’ setup.
Mobile:
I only recently applied the August changes but I now have an issue with the left margin. Everything is too close to the left edge. I have removed the sidebar because I don’t use it and that seems to have caused the problem. I’m guessing it’s some extra styles with the sidebar components in button card templates or the tablet theme but I couldn’t find them. I haven’t changed any code except removing the sidebar from the grid layout. I just need to add a small margin on the left. Here’s how it looks:
#default
grid-template-columns: 0 repeat(3, 1fr) 0 # repeat(4, 1fr) 0
grid-template-areas: | # replace sidebar with dot
  ".  vardagsrum  studio  sovrum  ."
  ".  media       övrigt  hemma   ."
  ".  footer      footer  footer  ."
try this
documentation
https://github.com/thomasloven/hass-browser_mod
theme
https://github.com/matt8707/hass-config/blob/65ddf3fd7203562bb4a459d7288ec59e552c6b76/themes.yaml#L72-L80
It’s a problem related to having tilt effects enabled. Wasn’t previously a problem but it’s a bit beyond me to solve, so I disabled tilt.
Works like a charm! Now the next issue arises:
Again, I do not have the issue on mobile. Just desktop. Do you have any pointers for that?
Ah, I changed the variable name in themes.yaml.
Replace --custom-button-card-border-radius with --button-card-border-radius
I was curious how could this be implemented (See pic)… as I only have temperature sensors there is no point in having a full field for them but rather something minimalistic to see the degrees per room at a glance :slight_smile:
I`m kind of unskilled in modifying it myself so a code + where to add it would be really appreciated.
I’m thinking this could be added into the
- type: grid title: Other ++code and the sensor goes here
But again I’m not sure :smiley:
Thanks in advance
@Mattias_Persson
I am trying to add another pop up and struggling… This card works fine on its own but not in the popup and the error doenst really make it clear to me why
Here is my footer_pool.yaml file
 # update_entities:
#   action: >
#       hass.callService('homeassistant', 'update_entity', {
#           entity_id: [
#             'binary_sensor.rpi_ping',
#             'sensor.rpi_cpu',
#             'sensor.rpi_mem',
#             'sensor.rpi_sd',
#             'sensor.rpi_uptime'
browser_mod:
    title: Pool
    card_mod:
      style:
        #popup header
    content:
      type: vertical-stack
      cards:
        - type: picture-elements
          entity: sensor.aqualink_run_mode
          image: /local/pool/pool.jpg
          state_filter:
            "off": blur(2px) grayscale(100%)
          elements: !include_dir_list /config/lovelace/cards/pool
I then added this to the bottom of the lovelace
              <ha-icon icon="mdi:swim"></ha-icon> Pool
            tap_action: !include popup/footer_pool.yaml
            variables:
              notify: >
                  let id = states['binary_sensor.aqualinkd_alive'];
                  if (id) return id.state === 'off';
            template: footer
and whenever I clock on my new popup I get this error
Uncaught ButtonCardJSTemplateError: TypeError: entity is undefined in 'return entity.state.length > 0 ? "block" : "none"'
    anonymous https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js line 425 > Function:3
    _evalTemplate https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:425
    _getTemplateOrValue https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:425
    n https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:547
    _evalActions https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:547
    _handleTap https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:547
    _handleAction https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:547
    handleEvent https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:1
    __boundHandleEvent https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:1
    Xt https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:1
    dblClickTimeout https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:1
    setTimeout handler*bind/t.actionHandler.end https://xxxxxx.xxxxxxx.com/hacsfiles/button-card/button-card.js:1
button-card.js line 425 > Function:3:16
Source map error: Error: request failed with status 404
Resource URL: https://xxxxxx.xxxxxxx.com/hacsfiles/Homekit-panel-card/homekit-panel-card.js
Source Map URL: lit-element.js.map
Resource URL: https://xxxxxx.xxxxxxx.com/local/community/swiss-army-knife-card/SVGInjector.min.js?module
Source Map URL: ./dist/svg-injector.map.js
Resource URL: https://xxxxxx.xxxxxxx.com/hacsfiles/cover-popup-card/cover-popup-card.js?hacstag=235106875026
Source Map URL: index.m.js.map
and the entity is on
thanks
I try to arrange the update. And I constantly get the following error message:
my code:
updates:
  show_state: true
  show_name: false
  show_icon: false
  styles:
    state:
      - text-align: left
      - justify-self: left
      - white-space: normal
    card:
      - cursor: default
      - padding: 0.2em 0 0 0.6em
      - letter-spacing: var(--mdc-typography-body1-letter-spacing)
  tap_action:
    href:
  extra_styles: |
    #ripple {
      display: none;
    ha-icon {
      width: 1.4em;
      vertical-align: 12%;
      opacity: 0.5;
      padding-right: 2px;
    .title {
      font-size: 1.3em;
      font-weight: 500;
    .subtitle {
      font-size: 0.95em;
      line-height: 0.7em;
      padding-left: 3px;
      padding-bottom: 10px;
      font-weight: 500;
      color: #828383;
    a {
      color: var(--primary-color);
    ul {
      margin-top: -0.6em;
      font-size: 0.88em;
      letter-spacing: 0.5px;
      line-height: 1.6em;
    code {
      background-color: var(--secondary-background-color);
updates_hass:
  template:
    - updates
    - settings
  state_display: |
      if (entity) {
          let links = new RegExp('<a href="([^"]+)"', "g"),
              installed = entity.state,
              hass_version_latest = states[variables.latest],
              hass_version_latest_beta = states[variables.latest_beta],
              hass_release_notes = states[variables.release_notes],
              hass_release_notes_beta = states[variables.release_notes_beta];
          let latest = installed.includes('b')
              ? hass_version_latest_beta.state
              : hass_version_latest.state;
          let release_notes = installed.includes('b')
              ? marked.parse(hass_release_notes.attributes.body)
              : marked.parse(hass_release_notes_beta.attributes.body);
          let subtitle = installed === latest
              ? `${variables.translate_no_updates} <b>&larr;</b> ${installed}`
              : `${ !installed.includes('.') || !latest.includes('.')
                  : `${installed} <b>&rarr;</b> ${latest} ${variables.translate_available} ${String.fromCodePoint("0x1f389")}` }`;
          let output = installed === latest
              ? '<ul></ul>'
                  ? '<ul></ul>'
                  : release_notes.replace(links, '<a href="#" onclick="window.open(\'$1\')"') }`;
          return `
            <ha-icon icon="mdi:home-assistant"></ha-icon> <span class="title">Home Assistant</span><br>
            <p class="subtitle">${subtitle}</p>
            ${output}
updates_hass_icon_name:
  template: icon_name
  icon: mdi:update
  styles:
    card:
      - opacity: >
            return entity && (entity.state === states[variables.latest].state ||
              entity.state === states[variables.latest_beta].state)
                ? '0.3'
                : '1';
      - display: >
            return entity
              ? 'flex'
              : 'none';
updates_hacs:
  template:
    - updates
    - settings
  state_display: |
      if (entity) {
          let output = '',
              count = parseInt(entity.state) || 0,
              subtitle = count === 0
                  ? `${variables.translate_no_updates} <b>&larr;</b> ${states['update.hacs_update'].attributes.installed_version || ''}`
                  : `${count} ${count === 1 ? variables.translate_update_available : variables.translate_updates_available} ${String.fromCodePoint('0x1f389')}`;
          Object.keys(states).forEach(key => {
            let s = states[key],
                e = s.entity_id,
                a = s.attributes;
            if (e.includes('update.') && s.state === 'on' && a.release_url) {
                let split_url = a.release_url.split('/'),
                    name = `${split_url[3]}/${split_url[4]}`,
                    installed = states[variables.installed].attributes.repositories;
                if (installed.includes(name)) {
                    output += `<li><b><a href="#" onclick="window.open('${a.release_url}');">
                    ${name}</a></b> ${a.installed_version} <b>&rarr;</b> ${a.latest_version}</li>`
          return `
            <ha-icon icon="hacs:hacs"></ha-icon> <span class="title">Community Store</span><br>
            <ul>${output}</ul>
updates_hacs_icon_name:
  template: icon_name
  icon: mdi:open-in-new
  styles:
    card:
      - opacity: >
            return entity && entity.state === '0'
                ? '0.3'
                : '1';
      - display: >
            return entity && entity.state !== 'unknown'
                ? 'flex'
                : 'none';
updates_other:
  template:
    - updates
    - settings
  state_display: |
      if (entity) {
          let output = '',
              attr = Object.fromEntries(
                Object.entries(entity.attributes).filter(([, value]) => {
                    return value != false;
              count = Object.keys(attr).length;
          for (const [, value] of Object.entries(attr)) {
              output += `<li>${value}</li>`;
          let subtitle = count == 0
              ? variables.translate_no_updates
              : `${count} ${count == 1 ? variables.translate_update_available : variables.translate_updates_available} ${String.fromCodePoint('0x1f389')}`;
          return `
            <ha-icon icon="mdi:update"></ha-icon> <span class="title">אחר</span><br>
            <ul>${output}</ul>
updates_other_icon_name:
  template: icon_name
  icon: mdi:reload
  styles:
    card:
      - opacity: 0.3
      - display: >
            return entity
                ? 'flex'
                : 'none';
hacs_iframe:
  tap_action:
    browser_mod:
      command: popup
      title: HACS
      style:
        div: |
          .content {
            padding: 0;
        hui-iframe-card$: |
          ha-card {
            margin-left: -58px;
      large: true
      card:
        type: iframe
        url: >
          [[[ return `/${hass.panels.hacs.url_path}` ]]]
  template: icon_name
hacs_navigate_ios:
  tap_action:
    close_popup: >
      [[[ hass.callService('browser_mod', 'close_popup'); ]]]
    action: navigate
    navigation_path: >
  template: icon_name
hass_release_notes
Screen Shot 2022-09-30 at 06.05.18
what am I missing?
Hey @johntdyer, it may not be the issue, but have you added the js modules in your configuration.yaml? Example snippet of my configuration.yaml is shown below.
lovelace:
  mode: yaml
  resources: [
      { url: /hacsfiles/apexcharts-card/apexcharts-card.js,                         type:  module },
      { url: /hacsfiles/bar-card/bar-card.js,                                       type: module },
      { url: /hacsfiles/button-card/button-card.js,                                 type: module },
      { url: '/local/marked.min.js?v=4.0.18',                                       type: module },
      { url: '/local/vanilla-tilt.min.js?v=1.7.2',                                  type: module },
      { url: /local/fonts.css,                                                      type: css }
