homeassistant.exceptions.TemplateError: ValueError: Template error: int got invalid input 'unknown' when rendering template '{{ states('sensor.template_other_updates') | int }}' but no default was specified
and:
TemplateError('ValueError: Template error: int got invalid input 'unknown' when rendering template '{{ states('sensor.template_other_updates') | int }}' but no default was specified') while processing template 'Template("{{ states('sensor.template_other_updates') | int }}")' for attribute 'other_updates' in entity 'sensor.template_updates'
TemplateError('TypeError: unsupported operand type(s) for +: 'int' and 'NoneType'') while processing template 'Template("{{ this.attributes.values() | sum }}")' for attribute '_attr_native_value' in entity 'sensor.template_updates'
But I think the last two are because of the first one.
If I update the hacs Integration, the popup error is gone, but the error in the system log is still there.
@Mattias_Persson Is there any way to use a custom:button-card with a camera and have live preview on the button?
I tried using show_live_stream: true but it does not help.
Double clicking on button opens normal camera stream which is live, but on the button card it is a static image all the time, refreshing browser tab updates images, but it is never as a live preview on the button
thank you André… but it doesn’t work. I’ve created a template file and adjusted the button-card in the ui yaml. But it shows always the mushroom light card.
I’ve just started this week with your dashboard. Really great work.
Suddenly my left icons are a larger then the middle and left ones… Any idea how this has gone wrong?
Made by mistake the full blur for media obviously
however, how can one add the blur effect as “shadow”
The idea would be to have the shadow as an extension of the media thumbnail, instead of just a random color (I know how to do the random color using drop-shadow()
I love the project!! Super clean and gorgeous! I’m new to HA! I was able to install hacs and get the dashboard, but it’s all in Swedish. How can I change the language to English? The only way to modify the dashboard is thru yaml?? Can’t I just use GUI?
Check the repository to see if you have all the sensors needed for the update. You can go back a dozen or so posts because from time to time someone has such a problem.
Hello @Mattias_Persson, thanks for the great work on updates, it really simplified the management.
I just noticed one problem related to it in case someone is using a supervised install.
In that case when there’s an home assistant core update sensor update.home_assistant_core_update is activated and consequentially I can see the update counted twice in home_assistant and update_entities.
Do you think that it can be fixed? Here’s the involved code in version_updates.yaml
- unique_id: updates
state: >
attributes:
home_assistant: >
{% set installed = states('sensor.current_version') %}
{% set latest = states('sensor.home_assistant_versions_beta') if version(installed).beta else states('sensor.home_assistant_versions') %}
{{ iif(version(latest) > version(installed) and '.' in installed and '.' in latest, 1, 0) }}
update_entities: >
{{ states.update | selectattr('state','eq','on') | list | count }}
other_updates: >
{{ states('sensor.template_other_updates') | int(0) }}
