Is the theme on for that device?
can you provide the yaml for the dashboard?
can you provide more info on “Tried different things”, what are the things you have tried?
Hi everyone - I’m an extreme noob when it comes to yaml. Hoping someone can help me out with what I am sure is a super dumb question.
I’m just starting to try to implement this UI and am running into this issue with every card:
Because I have multiple yaml dashboards going, I’ve had to edit my configuration.yaml slightly, but everything else is largely the same save for some entity/name references. It seems like I’m just not referencing the “extra_styles.yaml” somehow? I’m trying to keep my config organized, so it’s currently in config/ui-lovelace/button_card_templates with the rest of the light.yaml, icon_hue.yaml, etc. And for reference, this is the button_card code:
- type: grid
title: Kitchen
view_layout:
grid-area: kitchen
columns: 2
cards:
- type: custom:button-card
entity: light.kitchen_cabinet_sink_lights_2
name: Cabinet & Sink Lights
template:
- light
- icon_hue
entity: light.laundry_room_cabinet_lights
template:
- light
- icon_shade
What am I doing wrong? Any help would be appreciated!
hi Amanda, welcome, and don’t worry we are all noobs at some point.
can I confirm a few things?
do you have this line at the top of your dashboard yaml?
button_card_templates:
!include_dir_merge_named button_card_templates
is a relative path to the folder that contains all the templates.
so as you have moved the folder you may need to change this line depending on the location of your dashboard yaml
it also looks like you need to set up the theme, have you done this?
thank you for providing a good questions.
Im updating my version of this UI from pre browser mod 2, i believe i have fixed all the breaking changes apart from this one:
it seems like the “placeholder grid areas” are having borders generated, i tried applying the fix mentioned here: HA 2022.11 introduces border to cards - theme update required to resolve. · Issue #118 · matt8707/hass-config · GitHub
but it seems to have not fixed the issue. Does anyone have any suggestions? I can post snippets if you need them, i don’t know where to look to resolve this as other who had the border issue appeared to not have it specifically here. will post snippets of my work if someone can point me in the right direction, cheers,
post ui-lovelace.yaml and I’ll have a look
Hi Mason,
Do you have an idea how I can add a sound? So as soon as the timer ends, there should be a sound.
Use a normal home assistant automation, the timer finishing will send out an event that an automation can listen for. I have it sending a notification to my tv and my phone for now but I have plans to expand the automation. You could send a service call to the tablet and play a sound if your tablet supports that.
Thanks Mattias,
heres my lovelace. its a pretty old version
- type: custom:grid-layout
layout:
#default
grid-gap: calc(var(--custom-layout-card-padding) * 0.8)
grid-template-columns: 1.175fr repeat(3, 1fr) 0
grid-template-rows: 0 repeat(2, fit-content(100%)) 0fr
grid-template-areas: |
"sidebar . . . ."
"sidebar hvac bedrooms cameras ."
"sidebar media bathroom home ."
"sidebar footer footer footer ."
mediaquery:
#phone
"(max-width: 800px)":
grid-gap: calc(var(--custom-layout-card-padding) * 1.5)
grid-template-columns: 0 repeat(2, 1fr) 0
grid-template-rows: 0 repeat(5, fit-content(100%)) 0fr
". sidebar sidebar ."
". bedrooms bathroom ."
". hvac cameras ."
". media home ."
". footer footer ."
#portrait
"(max-width: 1200px)":
grid-gap: var(--custom-layout-card-padding)
grid-template-columns: repeat(3, 1fr) 0
grid-template-rows: 0 repeat(3, fit-content(100%)) 0fr
"sidebar . . ."
"sidebar bedrooms bathroom ."
"sidebar hvac cameras ."
"sidebar media home ."
"sidebar footer footer ."
"sidebar . . ."
cards:
- type: custom:button-card #extra_styles fix
# SIDEBAR #
- type: vertical-stack
view_layout:
grid-area: sidebar
cards:
entity: sensor.template_sidebar
template: sidebar_template
- type: custom:popup-card
entity: weather.openweathermap
card:
type: custom:weather-card
style:
ha-card {
width: 80%;
border-width: 0px
forecast: false
hourly_forecast: false
details: true
current: true
- type: grid
cards:
- type: button
icon: custom:roborock-vacuum
tap_action:
!include popup/sidebar_vacuum.yaml
hold_action:
action: none
- type: button
icon: mdi:information-outline
tap_action:
!include popup/sidebar_information.yaml
hold_action:
action: none
- type: button
icon: mdi:arrow-up-bold-circle-outline
tap_action:
!include popup/sidebar_update.yaml
hold_action:
action: call-service
service: homeassistant.update_entity
service_data:
entity_id: sensor.hacs
# Cameras #
- type: grid
title: Cameras
view_layout:
grid-area: cameras
columns: 2
cards:
entity:
template:
- light
# - icon_hue
entity:
template:
- light
# - icon_shade
entity:
hold_action:
template:
- base
# - icon_tv
# - loader
entity:
hold_action:
template:
- base
- icon_hue
- loader
# HVAC #
- type: grid
title: Home Climate
view_layout:
grid-area: hvac
columns: 2
cards:
entity: climate.hvac
tap_action:
!include popup/mainhvac.yaml
template:
- base
- icon_climate
- climate
variables:
circle_input: >
if (entity) {
return entity.state == 'cool' ?
entity.attributes.temperature :
entity.attributes.current_temperature;
entity: input_select.sync_climate_type
name: '[[[ return entity.state]]]'
show_state: false
styles:
name:
- white-space: normal
- text-align: left
- vertical-align: text-top
tap_action:
service: input_select.select_next
service_data:
entity_id: input_select.sync_climate_type
hold_action:
action: none
template:
- base
- icon_sync
entity: switch.hallway_double_2
name: Fresh Air Intake
show_state: false
styles:
name:
- text-align: left
template:
- base
- loader
- icon_fan2
entity: script.quick_climate
return states['input_select.quick_climate_mode'].state;
hold_action:
!include popup/quickclimate.yaml
template:
- base
- loader
- icon_quick_mode
# BATHROOM #
- type: grid
title: Bathroom
view_layout:
grid-area: bathroom
columns: 2
cards:
entity: input_boolean.bathroom_auto
template:
- base
- icon_sync
entity: climate.bathroom1ecobee
tap_action:
!include popup/bathroom1climate.yaml
template:
- base
- icon_climate
- climate
variables:
circle_input: >
if (entity) {
entity: switch.equipment_1
hold_action:
!include popup/mirror.yaml #heated mirror popup, settings, timer etc
template:
- base
- icon_mirror
- loader
entity: fan.extractor_fan #change to fan.bathroom_extractor
hold_action:
!include popup/bathroom_extractor_fan.yaml # popup with fan settings, timer etc
template:
- base
- icon_fan2
- loader
# MEDIA #
- type: grid
title: Media
view_layout:
grid-area: media
columns: 1
cards:
entity: sensor.plex_recently_added
tap_action:
!include popup/media_plexplayer.yaml
template:
- conditional_media
- recently_downloaded
- icon_plex
- base
- loader
# - type: custom:swipe-card
# start_card: 1
# parameters:
# roundLengths: true
# effect: coverflow
# speed: 650
# spaceBetween: 20
# threshold: 7
# coverflowEffect:
# rotate: 80
# depth: 300
# cards:
# - type: horizontal-stack
# cards:
# - type: conditional
# conditions:
# - entity: input_select.conditional_media
# state: Recently Downloaded
# card:
# type: custom:button-card
# entity: sensor.plex_recently_added
# tap_action:
# !include popup/Media_plexplayer.yaml
# template:
# - conditional_media
# - recently_downloaded
# - icon_plex
# - base
# - loader
# - type: grid
# columns: 2
# cards:
# - type: custom:button-card
# entity: media_player.vardagsrum
# name: Vardagsrum
# template:
# - media
# - icon_apple_tv
# name: Sovrum
# entity: media_player.sovrum
# template:
# - media
# - icon_apple_tv
# entity: media_player.spotify
# name: Spotify
# template:
# - media
# - icon_spotify
# entity: media_player.kok
# name: Nest Mini
# template:
# - media
# - icon_nest_mini
# BEDROOMS #
- type: grid
title: Bedrooms
view_layout:
grid-area: bedrooms
columns: 2
cards:
entity: switch.hallway_double_1
hold_action:
action: none
template:
- icon_hue
- light
entity: climate.bedroom1ecobee
tap_action:
!include popup/bedroom1climate.yaml
template:
- base
- icon_climate
- climate
variables:
circle_input: >
if (entity) {
entity: climate.bedroom2ecobee
tap_action:
!include popup/bedroom2climate.yaml
template:
- base
- icon_climate
- climate
variables:
circle_input: >
if (entity) {
entity: climate.bedroom3ecobee
tap_action:
!include popup/bedroom3climate.yaml
template:
- base
- icon_climate
- climate
variables:
circle_input: >
if (entity) {
# HOME #
- type: grid
title: Home
view_layout:
grid-area: home
columns: 2
cards:
entity: person.ash
tap_action:
!include popup/home_ash.yaml
hold_action:
action: none
template: person
entity: device_tracker.pet_cleo
tap_action:
!include popup/home_cleo.yaml
hold_action:
action: none
template: cat
entity: device_tracker.pet_molly
tap_action:
!include popup/home_molly.yaml
hold_action:
action: none
template: cat
entity: person.grace
tap_action:
!include popup/home_grace.yaml
hold_action:
action: none
template: person
# FOOTER #
# view_layout:
# grid-area: footer
# entity: sensor.covid_19_folkhalsomyndigheten
# template: coronavirus
- type: custom:hui-element
card_type: horizontal-stack
cards:
Hi all – I’m seeking some template help.
My heating system reports hvac_action:
however the default state is hvac_modes:
which always displays as auto
on my button cards.
How could I tweak the base template to use hvac_action:
instead? Do I need to create a sensor or is there a better way?
base:
template:
- settings
- tilt
- extra_styles
variables:
state_on: >
[[[ return ['on', 'home', 'heating', 'fan_only', 'playing', 'unlocked'].indexOf(!entity || entity.state) !== -1; ]]]
state: >
[[[ return !entity || entity.state; ]]]
entity_id: >
[[[ return !entity || entity.entity_id; ]]]
entity_picture: >
[[[ return !entity || entity.attributes.entity_picture; ]]]
timeout: >
[[[ return !entity || Date.now() - Date.parse(entity.last_changed); ]]]
is_youtube: >
let is_youtube = entity?.attributes?.app_id === 'com.google.ios.youtube',
sensor = this?._config?.triggers_update,
media_title = entity?.attributes?.media_title,
watching_title = states[sensor]?.attributes?.title;
if (is_youtube && media_title === watching_title) {
return true;
hi @tomplums
1st don’t do that, I would not recommend changing base ever, you can over ride everything so there should never be a need to make a change to base
2nd why are you not using the climate template? that has hvac_action as the state, along with lots more.
3rd this is how
variables:
state: >
if (entity) {
return entity.attributes.hvac_action
state_on: >
return ['cooling','heating'].indexOf(!entity || entity.attributes.hvac_action) !== -1;
set display none on this
Perfect thanks for this. I’m an idiot – I’d templated the cards/layout before populating the entities and was trying to apply climate to a section of code meant for lights.
it happens,
I recommend keeping @Mattias_Persson repo open, that way you can always look at how he did it.
I use to use github1s, but now I just have a clone of the repo on my PC that I reference for both helping people with issues and when i’m working on my own config
Yes I practice that approach too.
But actually which climate template are you referring to? I don’t see any that use hvac_action in the repo.
my apologies I must have written that myself
this is the template I use for climate
# CLIMATE #
climate:
template:
- base
- circle
variables:
state: >
if (entity) {
state_on: >
circle_input: >
if (entity) {
return entity.state === 'off'
? Math.round(entity.attributes.current_temperature).toString()
: entity.attributes.hvac_action === "cooling"
? Math.round(entity.attributes.target_temp_low).toString()
: Math.round(entity.attributes.target_temp_high).toString();
circle_input_unit: '°C'
state_display: |
return variables.state.charAt(0).toUpperCase() + variables.state.substr(1).toLowerCase();
wow super clean weather section, are the backgrounds animated or are they images?
what are the bars on the bottom of the side bar?
Simple as that!
cheers mate, worked a charm
The weather icons are all animated. Backgrounds are pictures. Those bars are the rain forecast of the next 2 hours.
EDIT:
every bar represents the rain probability in % for every 12 minutes range.
wow smart, that would be handy for me, as I have a motorbike so knowing rain is on the way would come in handy, what weather integration do you use? would you mind posing the logic for the bars for a reference?
I’m not using any integration, I’m using straight the Accuweather API. They only allow 24 calls per day in its free plan for Minutecast, so I created three tokens so I can make a request every 20 mins.
https://developer.accuweather.com/
I’m using NR to make the call but it can be done creating a rest sensor or command or whatever in HA itself. It’s a GET request and the url should look something like this:
http://dataservice.accuweather.com/forecasts/v1/minute?q=43.016666%2C%20-7.550000&apikey=YOUR_API_KEY_HERE&language=es-es
Regarding those bars, I link you to a different post where I thoroughly exlained how it works. The config is shared in posts 16 and 17 but there’s the full explanation:
