A different take on designing a Lovelace UI
Unfortunately that didn’t work. I tried that and I tried this as well, which I have used for other items and I still can’t get the state.
base_on:
  template:
    - settings
    - extra_styles
  variables:
    state: >
      [[[ return !entity || entity.state; ]]]
    entity_id: >
      [[[ return !entity || entity.entity_id; ]]]
    entity_picture: >
      [[[ return !entity || entity.attributes.entity_picture; ]]]
    circle: >
        if (entity) {
          let input = entity.state,
            r = 22,
            c = r * 2 * Math.PI,
            dasharray = c,
            dashoffset = c - input / 100 * c;
          return `
            <svg viewBox="0 0 50 50">
              <circle cx="25" cy="25" r="${r}" stroke="rgb(0,0,0)" stroke-dashoffset="${dashoffset}" stroke-dasharray="${dasharray}" stroke-width="2.3" fill="rgba(255, 255, 255, 0.85)" style="transform: rotate(-90deg); transform-origin: 50% 50%;" />
              <text x="50%" y="54%" fill="rgb(0,0,0)" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${parseInt(entity.state)}<tspan font-size="10">lx</tspan></text>
            </svg>
  aspect_ratio: 1/1
  show_state: false
  show_label: false
  show_icon: false
  styles:
    grid:
      - grid-template-areas: |
          "icon  circle"
          "n     n"
          "l     l"
          "s     s"
      - grid-template-columns: repeat(2, 1fr)
      - grid-template-rows: auto repeat(3, min-content)
      - gap: 1.3%
      - align-items: start
      - will-change: transform
    name:
      - justify-self: start
      - line-height: 110%
      - font-size: 15px
      - font-weight: bold
    state:
      - line-height: 110%
      - font-size: 12px
    label:
      - line-height: 110%
      - font-size: 12px
    card:
      - border-radius: 10px
      - border-width: 0
      - -webkit-tap-highlight-color: rgba(0,0,0,0)
      - transition: none
      - --mdc-ripple-color: rgb(0, 0, 0)
      - color: rgb(0, 0, 0)
      - background-color: rgba(255, 255, 255, 0.85)
Show me your code of the card itself
Here you go. This is the actual code and the main templates it relies on.
          - type: custom:button-card
            template:
              - sensor_on
              - icon_lux
            entity: sensor.bedroom_ep1_multi_sensor_illuminance
            show_state: true
sensor_on:
  template:
    - base_on
  tap_action:
    action: more-info
base_on:
  template:
    - settings
    - extra_styles
  variables:
    state: >
    entity_id: >
    entity_picture: >
    circle: >
        if (entity) {
            r = 22,
            dasharray = c,
          return `
            </svg>
  aspect_ratio: 1/1
  show_state: false
  show_label: false
  show_icon: false
  styles:
    grid:
          "icon  circle"
          "n     n"
          "l     l"
          "s     s"
      - gap: 1.3%
    name:
      - line-height: 110%
      - font-size: 15px
      - font-weight: bold
    state:
      - line-height: 110%
      - font-size: 12px
    label:
      - line-height: 110%
      - font-size: 12px
    card:
      - border-width: 0
      - transition: none
Hey are you even getting an image on recently added for Plex? I dont even get a proper image to show…
Hi!
I assume youve setup your Voordeur card to light up when the door opens. Could you perhaps share your code for this? I’ve been trying to get that to work but for some reason just cant. Thx fellow dutchie :wink:
Hi all,
do you anybody know why I have broken that “Vardagsrum”? I tried to delete it (that grid) and then I had broken “Studio” grid.
I tried to modify a lot of stuff but…without result… I am lost
Thanks in advance
I would like to edit the title area of ​​the grid to show when motion is detected in this area. I don’t care if with an icon as you can see in the image or even editing, for example, the color of the name of the area.
I have tried to do it in many ways (ie. card_mod) but I have not succeeded, can someone help me?
type: grid
title: Vardagstrum
view_layout:
grid-area: vardagstrum
columns: 1
cards:
Yes
I use this repo : GitHub - NemesisRE/sensor.plex_recently_added: ▶️ Plex component to feed Upcoming Media Card.
Check this:
Can anyone help me with this? I am using a smart power plug that tracks the amount of power it uses, based on which I have created a button. I’ve setup an if statement so when the power usage is above 10w, the button says the computer is online (which it is). However, when that happens and the PC is on, the button itself stays white. I’ve tried everything I know but cant seem to get it to work, can anyone check my code and see whats going wrong? Thanks!
            entity: sensor.plug_gamingpc_power
            template:
              - base
              - icon_tv
              - loader
            custom_fields:
              icon: >
                <ha-icon icon="mdi:server" style="color: #9da0a2;"></ha-icon>
              circle: >
                  if (entity) {
                    return `
                        <circle cx="25" cy="25" r="20.5" stroke="#313638" stroke-width="2" fill="rgba(255,255,255,0.00)" />
                        <text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${parseInt(entity.state)}<tspan font-size="10"> W</tspan></text>
                      </svg>
            tap_action:
              action: call-service
              service: automation.trigger
              service_data:
                entity_id: automation.kantoor_aan
            state_display: >
                if (entity.state > 10) {
                    return 'On';
                    return 'Off';
maybe create a binary sensor
already tried that, didnt work. Gave me the same result, everything state wise worked fine, but I couldn’t get the actual button to change color based on state.
I have a washing machine made on a binary sensor. Above 10W the card lights up white - on
Can you share your code to see if I can adjust it with my own sensors?
I believe I see an error in your state display code. Both on and off are expecting an entity.state greater than 10.
Oh yeah, had already fixed that right after I posted here and it still didnt work. Good eye tho! :wink:
Sorry. Above 2W the sensor is on.
    sensors:
      pralka:
        friendly_name: "Pralka"
        value_template: "{{ states('sensor.pralka_energy_power')|float > 2.0 }}"
Just created this, the state once again works, it reports as true, but doesn’t light up the button. Whats your button code?
            entity: binary_sensor.pralka
            state_display: >
              [[[ if (variables.state === true) return variables.translate_unknown;
                  if (entity.state == 'on') return 'Pranie';
                  if (entity.state == 'off') return 'Wyłączona';
            double_tap_action:
              !include popup/pralka.yaml
            template:
              - base
              - icon_washing
Same thing, doesn’t turn on, but it also doesn’t show the return values that you setup. I 1-1 copied your code and only changed my entity to sensor.gamingpc_status and it didnt work…
