The curl way is more consistent for me. The issue on my tablet is if I turn on the screen after 10 min, fully has to catch up so the screen is unresponsive for seconds.
I use cmd=startScreensaver and cmd=stopScreensaver because it’s instant on and there is no refresh delay.
I guess fully turns off the display in a way that prevents the tablet from going to sleep, or on some devices the screen is lowered to minimal brightness and displays a black image.
Hi… I.m trying to use a similar way to use my xiaomi vacuum with valetudo (model 1)… do you know the way to make multiple selection with " input_select" on Home Assistant??? or another command.
the goal is to choose multiples rooms and send to predefined valetudo zones (i´m use node-red for automations)…
Amazing work! I have one quick question though. Is it possible to set the alignment of the text (from markdown)? I have set up multiple markdown cards with templates for dynamic texts. But when the number is above 9 (so double digits) the text becomes longer ofcourse. However, the text seems te be centered, which expands the text from left and right. Basically I want the text to be aligned from left, so if the text becomes longer it just expands to the right. I tried adding ‘text-align: left’ to style, but that didn’t work.
Am I missing something crucial and simple, or is it just not possible?
When I add max-width: 1px it aligns but only shows one text per line as you can see. Basically I want the text in the screenshot, but aligned. Am I missing something from my code?
Yeah, max-width probably wouldn’t work for markdown. I don’t know why the text doesn’t align for you. Remove max width and background: none to see whats going on.
You could also make it a template sensor and use state-label with the max-width trick, but then you wouldn’t get line breaks at all.
Hey this is so cool greate job, I am tring to set up the swipe-card and anything is working except the control it’s just blank, but if I swipe I see my 4 media players and what they are plaing, do you have any clue what i might doing wrong??
I got the text aligning working btw. Took a few hours of reading up on CSS but all is good now. I’ve been using HA for little over 3 months now, and have never worked with CSS or scripting. Thanks for your config setup, came real handy with understanding how to use picture elements. Also showed me how to create structure using yaml mode. Also borrowed your background
I created a tablet version of my smartphone setup:
