i love your theme! Can you share your lovelace?
how did you get the links working on the sidebar?
I have the same question.
And how do I enter the weather? in 4x4? It’s possible?
Hi Mattias_Persson… do you have problem with the lattest versions of Home Assistant and your lovelace config???
I update to 0.107 and now we have a problem with “custom:hui-markdown-card” the error is:
“Custom Element not exist custom:hui-markdown-card”
I read that is for changes on 0.106… do you have a workaround or similar???
Thanks…
Hi… I read your config in github and the trick is the lovelace-card-preloader module…
Now working…
I just have a question. do you know if the use of this module (lovelace-card-preloader) is now a pre-requisite or is only a temporal solution when all the plugins update???
Thanks…
You got it. I don’t know but balloob responded in this thread
Really asweome! Where did you get the icon gif’s? Did you make them yourself?
the switches or which one? I have most of the things from free sides and customize them a little.
Sorry, i meant the icons in the original post. The playstation gif and such
Do you have a GitHub repository?
No sorry;-(
Looks good!, can you please share your background image?
Can you share your switches, they look really good.
Of corse i have it from here: https://design.tutsplus.com/tutorials/quick-tip-create-a-round-switch-button-in-photoshop--psd-16955
hmmm, I got the pictures, but I don’t know how to use them as a switch. I thought there would be something simple but I don’t see one.
Can you point me in the right direction as to how you did it?
Its a PSD File in this you have Layers one Layer from the Button in Off Position and one in On Position. I have made a State Image for every Light. One for the Statn On one for State Of.
- entity: light.bar
state_image:
"off": /local/bar_aus.png
"on": /local/bar_an.png
unavailable: /local/leer.png![Buttons|690x411]
ahhh, forgot this is all in a picture element. Perfect thanks much.
Just curious, why a different Image for each switch? I am just using on.png and off.png for all switches.
Got it, there is no title
I guess the background around the buttons is transparency?
Yes. If you want, I can make a Button without the name under it for on and of.
