A different take on designing a Lovelace UI
When I change something in the button_card_templates.yaml, is there any way not to restart homeassistant to try?
Nice work.
I copied it but it doenst work with a Nest thermostat. The Nest always says heating also when its not heating so the card never goes “out”. Can someone help me what i have to change to get this working, i tried several things but no succes sofar. I know i have to use hvac_action but how?
hvac_modes:
  - heat
  - 'off'
min_temp: 7
max_temp: 35
preset_modes:
  - none
  - eco
current_temperature: 19.3
temperature: 20.5
current_humidity: 31
hvac_action: heating
preset_mode: none
friendly_name: thermostaat
supported_features: 17
Thank you.
Can you manually turn it off? Because it shows that the thermostat has two modes. heat and off.
Mine look nearly the same
hvac_modes: off, heat
min_temp: 7
max_temp: 35
current_temperature: 22.1
temperature: 22.5
friendly_name: Wohnesszimmer
min_temp: 7
max_temp: 35
preset_modes: none, Heat Eco, Full Power, Manufacturer Specific
current_temperature: 22.2
temperature: 19
preset_mode: none
node_id: 20
valve_position: 0 %
friendly_name: bad_heizung
Hi! New here. Thanks for your great work!
I’ve everything working except the sidebar with markdown.
Somehow I get every time a (white) panel background. How can I solve this?
Screen Shot 2021-02-12 at 09.59.44
Did you selected the correct theme?
Ah that’s what the problem was. Pff thanks!!!
When i turn it off it is really off, so it doesnt do anything. So the mode on my Nest is heat then it works and off than its really off and i can’t set a temperature. I have to use hvac_action then i get or heating and when de set temperature is reached i get idle.
That means it works now?
Sorry no, i don’t know how i use the hvac_action in the code :thinking:
Sorry, I dont know. The hvac_action is a attribute and I dont know how to use them.
But I got a similiar thing called preset_mode. I use that for extra power when wife is complaining. That could be used to color the card red when active.
maybe @Mattias_Persson or @kuuji has a Idea how to use attributes as state for the card?
Edit: This could be the way GitHub - custom-cards/button-card: ❇️ Lovelace button-card for home assistant but I am struggling to get it running
ButtonCardJSTemplateError: TypeError: Cannot read property ‘attributes’ of undefined in ‘return (states[‘entity.entity_id’].attributes.preset_mode == ‘none’)’
      - operator: template
        value: >
          [[[ return (states['entity.entity_id'].attributes.preset_mode == 'none') ]]]
        styles:
          card: [background-color: 'rgba(255, 0, 0, 0.8)']
Edit: just remove the quotes from entity.entity_id and it will work. So you can use the attribute as state.
        value:  >
          [[[ return (states[entity.entity_id].attributes.preset_mode == 'Full Power') ]]]
        styles:
This will color the card in red when the attribute “preset_mode” is set to Full Power
Thanks for helping. I will try that later on. For now i have to look why i don’t see any history in the grafics.
I can confirm that.
They changed the way to call popup from frontend
HI,
what thermostat card you use?
Can you show me you code?
Thank You.
I made a new yaml file inside the popup folder.
              action: call-service
              service: browser_mod.popup
              service_data:
                title: Information
                hide_header: true
                deviceID: this
                style:
                    :host .content {
                      width: calc(385px + 385px + 385px);
                      max-width: 90vw;
                    .mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
                      background: none !important;
                card:
                  type: custom:layout-card
                  column_num: 3
                  column_width: [385, 385, 385]
                  layout: vertical
                  cards:
                   - type: thermostat
                     title: Nest
                     class: add_header
                     show_header_toggle: false
                     entity: climate.family_room_thermostat
                   - break
                   - type: entities
                     title: Badkamer
                     class: add_header
                     entities:
                       - entity: sensor.temperature_158d0002437d14
                       - entity: sensor.humidity_158d0002437d14
                       - entity: sensor.pressure_158d0002437d14
                       - entity: sensor.battery_158d0002437d14
                       - type: custom:mini-graph-card
                         entities:
                            - color: '#385581'
                            - color: green
                         align_state: left
                         group: false
                         points_per_hour: 1
                         line_width: 3
                         hour24: true
                         hours_to_show: 4
                         show:
                           {fill: fade, icon: false, name: false, state: false,
                           name_adaptive_color: true, labels: hover, legend: false}
                         tap_action:
                           action: none
                   - type: entities
                     title: Slpk. Ouders
                     class: add_header
                     entities:
                        - entity: sensor.temperature_158d0001a1fa6c
                        - entity: sensor.humidity_158d0001a1fa6c
                        - entity: sensor.pressure_158d0001a1fa6c
                        - entity: sensor.battery_158d0001a1fa6c
                          entities:
                            - color: '#385581'
                            - color: green
                          align_state: left
                          group: false
                          points_per_hour: 1
                          line_width: 3
                          hour24: true
                          hours_to_show: 4
                          show:
                          tap_action:
                            action: none
                   - break
                   - type: entities
                     title: Slpk. Kyan
                     class: add_header
                     entities:
                        - entity: sensor.temperature_158d0002320b36
                        - entity: sensor.humidity_158d0002320b36
                        - entity: sensor.pressure_158d0002320b36
                        - entity: sensor.battery_158d0002320b36
                          entities:
                            - color: '#385581'
                            - color: green
                          align_state: left
                          group: false
                          points_per_hour: 1
                          line_width: 3
                          hour24: true
                          hours_to_show: 4
                          show:
                          tap_action:
                            action: none
                   - type: entities
                     title: Studeerkamer
                     class: add_header
                     entities:
                        - entity: sensor.temperature_158d0002320b45
                        - entity: sensor.humidity_158d0002320b45
                        - entity: sensor.pressure_158d0002320b45
                        - entity: sensor.battery_158d0002320b45
                          entities:
                            - color: '#385581'
                            - color: green
                          align_state: left
                          group: false
                          points_per_hour: 1
                          line_width: 3
                          hour24: true
                          hours_to_show: 4
                          show:
                          tap_action:
                            action: none
I think I am done for the moment with the climate-card. Thanks to @andrew47 for the idea with the attribute :slight_smile: .
I made a button-card with three states. Off, heating and full power.
When it is off, it shows the current temperature measured by the device.
grafik
When its on the circle on the right will show the target temperature as text and the actual valve opening as a stroke. From 0-100%
grafik
The third mode is called “full power”. It us used to open the valve on the radiator completely for a few minutes. Its more a WAF thing. But when the mode is active, the card turns red and the target temperature dissapears.
grafik
And when you click the button-card you will get a nice popup made with thermostat-popup-card.
ui-lovelace.yaml
          - type: custom:button-card
            entity: climate.buero_heizung
            style:
              top: 20.35%
              left: 55.18%
              width: 10%
            template: climate
  climate:
    template: ['base']
    aspect_ratio: 1/1
    show_state: true
    show_icon: false
    show_name: true
    show_current_temperature: true
    show_control: true
    state:
        value: >
          [[[ return (states[entity.entity_id].attributes.preset_mode == 'none') && (states[entity.entity_id].state == 'heat') ]]]
        styles:
          card: [background-color: 'rgba(255, 255, 255, 0.8)']
          name: [color: 'rgba(0, 0, 0, 0.6)']
          state: [color: 'rgba(0, 0, 0, 0.6)']
        value:  >
        styles:
          card: [background-color: 'rgba(227, 56, 18, 0.4)']
    tap_action:
      service_data:
        title: '[[[ return entity.attributes.friendly_name ]]]'
        deviceID: this
        card:
          type: entities
          entities:
            - type: custom:thermostat-popup-card
              entity: '[[[ return entity.entity_id ]]]'
              icon: none
              fullscreen: false
              brightnessWidth: 130px
              brightnessHeight: 360px
              borderRadius: 1.7em
              sliderColor: '#c7c7c7'
              sliderTrackColor: rgba(25, 25, 25, 0.9)
              actionSize: 4.5em
              actionsInARow: 2
    custom_fields:
      circle_current: >
        const temperature = entity.attributes.current_temperature;
        const stroke_color = entity.state === 'heat' ? '#b2b2b2' : '#313638';
        const fill_color = entity.state === 'heat' ? '#00ba32' : '#FFFFFF08';
        const radius = 28;
        return `<svg viewBox="0 0 60 60"><circle cx="30" cy="30" r="${radius}" stroke="${stroke_color}" stroke-width="1.5" fill="${fill_color}" style="
        transform: rotate(-90deg); transform-origin: 50% 50%; " />
        <text x="50%" y="54%" fill="#f7f8fa" font-size="18" text-anchor="middle" alignment-baseline="middle">${temperature}<tspan font-size="10">°</tspan></text></svg>`; } ]]]
      circle_target: >
        [[[ if (entity.state === 'heat' && entity.attributes.temperature) {
        const temperature = entity.attributes.temperature;
        const valve_position = entity.attributes.valve_position;
        const valve_position_num = valve_position.slice(0, -1);
        const fill_color = entity.state === 'heat' ? 'none' : '#FFFFFF08';
        const radius = 20.5; const circumference = radius * 2 * Math.PI;
        return `<svg viewBox="0 0 50 50"><circle cx="25" cy="25" r="${radius}" stroke="${stroke_color}" stroke-width="1.5" fill="${fill_color}" style="
        transform: rotate(-90deg); transform-origin: 50% 50%; stroke-dasharray: ${circumference}; stroke-dashoffset: ${circumference - valve_position_num / 100 * circumference};" />
        <text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle">${temperature}<tspan font-size="10">°</tspan></text></svg>`; } ]]]
    styles:
      name:
        [top: 57.7%, left: 11%, line-height: 2vw, position: absolute]
      state:
        [top: 74%, left: 11%, line-height: 2vw, position: absolute]
      card:
        [font-family: Sf Display, letter-spacing: 0.05vw, font-weight: 400, color: 'rgba(255, 255, 255, 0.3)', font-size: 1.34vw, background-color: 'rgba(115, 115, 115, 0.2)', border-radius: 0.8vw, box-shadow: none, transition: none]
      custom_fields:
        circle_target:
          [top: 6.5%, left: 54.5%, width: 3.5vw, position: absolute, letter-spacing: 0.03vw]
        circle_current:
          [top: 6.5%, left: 6%, width: 3.5vw, position: absolute, letter-spacing: 0.03vw]
Sieht gut aus :slight_smile:
looks great :slight_smile:
HI,
i copied your Code now this Error:
Button-card template 'climate' is missing!
type: 'custom:button-card'
style:
  top: 20.35%
  left: 55.18%
  width: 10%
template: climate
Have you a idea?
OKi sorry i placed the tamplate on the right position. Works now
Can someone help. I can’t get the text “verwarmen” in the same color as “Woonkamer”.
Tried different things but i stuck now.
temp
  climate:
    template: ['base']
    aspect_ratio: 1/1
    show_state: false
    show_icon: false
    show_name: true
    show_control: true
    state:
        value: >
          [[[ return (states[entity.entity_id].attributes.hvac_action == 'heating') ]]]
        styles:
          value: [color: 'rgba(0, 0, 0, 0.6)']
    custom_fields:
      circle_current: >
        const stroke_color = entity.attributes.hvac_action === 'heating' ? 'rgba(255, 255, 255, 0.8)' : 'rgba(255, 255, 255, 0.8)';
        const fill_color = entity.attributes.hvac_action === 'heating' ? 'rgba(255, 255, 255, 0.8)' : 'rgba(255, 255, 255, 0.8)';
        const radius = 0;
        return `<svg viewBox="0 0 60 60"><circle cx="30" cy="30" r="${radius}" stroke="${stroke_color}" stroke-width="0" fill="${fill_color}" style="
        <text x="50%" y="54%" fill="#8d8e90" font-size="25" text-anchor="middle" alignment-baseline="middle">${temperature}<tspan font-size="10">°</tspan></text></svg>`; } ]]]
      circle_target: >
        [[[ if (entity.attributes.hvac_action === 'heating' && entity.attributes.temperature) {
        const stroke_color = entity.attributes.hvac_action === 'heating' ? '#b2b2b2' : '#313638';
        const fill_color = entity.attributes.hvac_action === 'heating' ? 'idle' : '#FFFFFF08';
        const radius = 0;
        return `<svg viewBox="0 0 50 50"><circle cx="30" cy="30" r="${radius}" stroke="${stroke_color}" stroke-width="0" fill="${fill_color}" style="
        <text x="50%" y="54%" fill="#3182b7" font-size="14" text-anchor="middle" alignment-baseline="middle">${temperature}<tspan font-size="10">°</tspan></text></svg>`; } ]]]
      value: >
        [[[ if (entity.attributes.hvac_action === 'heating' ) { return 'verwarmen'; }
        if (entity.attributes.hvac_action === 'idle') { return 'inactief';
    styles:
      name:
      state:
      card:
      custom_fields:
        circle_target:
          [top: 8.5%, left: 54.5%, width: 3.5vw, position: absolute, letter-spacing: 0.03vw]
        circle_current:
          [top: 8.5%, left: 6%, width: 3.5vw, position: absolute, letter-spacing: 0.03vw]
        value:
