A different take on designing a Lovelace UI
What a great design for my wallmounted tablet! Trying to get everything on the dashboard, I’d like to see.
Can someone help or point me in the right direction?
I would like to replace the Corona statistics with Sensor data (Energy consumption, Solar Energy and Temperature for example), how should I implement something like that?
Original code for this part is:
          - type: custom:hui-markdown-card
            class: coronavirus
            style:
              {top: 93.65%, left: 70.2%}
            content: >
              {% if is_state('sensor.covid_19_folkhalsomyndigheten', 'Tillgänglig') %}
                {% set data = state_attr('sensor.covid_19_folkhalsomyndigheten', 'embedCode') %}
                {% set total = data | regex_findall_index('Totalt[^,]*?(\d+)[^,]*?(\d+)[^,]*?(\d+)') | list %}
                {% set break = ' ‍ ‍ ‍ ‍ ‍ ‍<font color="#2f3436">|</font> ‍ ‍ ‍ ‍ ‍ ‍' %}
                <font color='#6a7377'>
                <ha-icon icon="mdi:virus"></ha-icon> <b>Coronavirus</b>{{ break -}}
                <ha-icon icon="mdi:chart-bar"></ha-icon> <b>{{ ((total[0] | int / 10327589) * 100) | round(2) }}%</b> av Sverige{{ break -}}
                <ha-icon icon="mdi:emoticon-sad"></ha-icon> <b>{{ total[0] }}</b> fall{{ break -}}
                <ha-icon icon="mdi:grave-stone"></ha-icon> <b>{{ total[2] }}</b> avlidna{{ break -}}
                <ha-icon icon="mdi:map-marker-radius"></ha-icon> <b>{{ data | regex_findall_index('Skåne[^,]*?(\d+)') }}</b> fall i Skåne
                </font>
              {% endif %}
You need to define the color in the style section of the custom field. Just add the color in there. It is not taking the style from the value of the entity, because you defined a new custom_field which has randomly the same name.
    styles:
      custom_fields:
        value:
          [top: 74%, left: 11%, line-height: 2vw, position: absolute, color: 'rgba(0, 0, 0, 0.6)']
Or the better way, use your logic as state_display:
    state_display: >
        [[[ if (entity.attributes.hvac_action === 'heating' ) { return 'verwarmen'; }
        if (entity.attributes.hvac_action === 'idle') { return 'inactief';
This only overwrites the value of the state and do not create a new.
What extension you use for the S5 card (with percent displays for filter etc. And the card)?
This looks really great!
thanks for helping.
But putting the color in the value isn’t working, when the thermostat is off it uses the same color.
Where do i put the state_display in this one and do i have to set color?
Use this template for state_display. I already deleted the unneccessary lines from the additional “value”.
  climate:
    template: ['base']
    aspect_ratio: 1/1
    show_state: false
    show_icon: false
    show_name: true
    show_current_temperature: true
    show_control: true
    state_display: >
    state:
      - operator: template
        value: >
          [[[ return (states[entity.entity_id].attributes.hvac_action == 'heating') ]]]
        styles:
          card: [background-color: 'rgba(255, 255, 255, 0.8)']
          name: [color: 'rgba(0, 0, 0, 0.6)']
          value: [color: 'rgba(0, 0, 0, 0.6)']
    custom_fields:
      circle_current: >
        const temperature = entity.attributes.current_temperature;
        const stroke_color = entity.attributes.hvac_action === 'heating' ? 'rgba(255, 255, 255, 0.8)' : 'rgba(255, 255, 255, 0.8)';
        const fill_color = entity.attributes.hvac_action === 'heating' ? 'rgba(255, 255, 255, 0.8)' : 'rgba(255, 255, 255, 0.8)';
        const radius = 0;
        return `<svg viewBox="0 0 60 60"><circle cx="30" cy="30" r="${radius}" stroke="${stroke_color}" stroke-width="0" fill="${fill_color}" style="
        transform: rotate(-90deg); transform-origin: 50% 50%; " />
        <text x="50%" y="54%" fill="#8d8e90" font-size="25" text-anchor="middle" alignment-baseline="middle">${temperature}<tspan font-size="10">°</tspan></text></svg>`; } ]]]
      circle_target: >
        [[[ if (entity.attributes.hvac_action === 'heating' && entity.attributes.temperature) {
        const temperature = entity.attributes.temperature;
        const stroke_color = entity.attributes.hvac_action === 'heating' ? '#b2b2b2' : '#313638';
        const fill_color = entity.attributes.hvac_action === 'heating' ? 'idle' : '#FFFFFF08';
        const radius = 0;
        return `<svg viewBox="0 0 50 50"><circle cx="30" cy="30" r="${radius}" stroke="${stroke_color}" stroke-width="0" fill="${fill_color}" style="
        <text x="50%" y="54%" fill="#3182b7" font-size="14" text-anchor="middle" alignment-baseline="middle">${temperature}<tspan font-size="10">°</tspan></text></svg>`; } ]]]
    styles:
      name:
        [top: 57.7%, left: 11%, line-height: 2vw, position: absolute]
      state:
        [top: 74%, left: 11%, line-height: 2vw, position: absolute]
      card:
        [font-family: Sf Display, letter-spacing: 0.05vw, font-weight: 400, color: 'rgba(255, 255, 255, 0.3)', font-size: 1.34vw, background-color: 'rgba(115, 115, 115, 0.2)', border-radius: 0.8vw, box-shadow: none, transition: none]
      custom_fields:
        circle_target:
          [top: 8.5%, left: 54.5%, width: 3.5vw, position: absolute, letter-spacing: 0.03vw]
        circle_current:
          [top: 8.5%, left: 6%, width: 3.5vw, position: absolute, letter-spacing: 0.03vw]
Does your climate.entity does not have a state like heat or idle? If so, you can also replace
    state:
        value: >
        styles:
with
    state:
      - value: 'heating'
Just change ‘heating’ to whatever your entity has.
I used the template only to change color to red in depence of boost is activated or not.
Thanks for the reply, but it isn’t working. Now it won’t show anything. The climate.entity only has two states, one is heat the thermostat is working and one is off and this is really off. I have to do it with the hvac_action this is the one that does change from heating to idle when i set a temprature.
On Off
So please only change the template. Ignore the last two pieces of code in my post.
Can you confirm that you only changed the template and it is still not working?
I only used your template and it won’t work.
EDIT
Its working now.
the show_state was set to false and in styles for state there where value: instead of state:
Thanks for helping
Got problems with border-radius.
Why is the border-radius not taken?
          - type: 'custom:mini-graph-card'
            entities:
              - sensor.wohnzimmer_temperatursensor_luftfeuchtigkeit
            color_thresholds:
              - color: '#007BFE'
                value: 55
              - color: '#26fe00'
                value: 47.5
              - color: '#FF5733'
                value: 40
              - color: '#fe0000'
                value: 35
            style:
              top: 43.4%
              left: 30.31%
              width: 10%
            line_color: blue
            line_width: 8
            font_size: 75
            show:
              icon: false
              state: false
Tried 0.8vw and 25px. nothing works.
Also card-mod workaround wont work
How are you implementing it?
screenshot
this works fine
          - type: custom:button-card
            entity: light.skrivbord
            style:
              top: 20.35%
              left: 41.31%
              width: 10%
            custom_fields:
              graph:
                card:
                  entities:
                    - sensor.hall_temperature
                  color_thresholds:
                    - color: '#007BFE'
                      value: 55
                    - color: '#26fe00'
                      value: 47.5
                    - color: '#FF5733'
                      value: 40
                    - color: '#fe0000'
                      value: 35
                  line_color: blue
                  line_width: 8
                  font_size: 75
                  show:
                    icon: false
                    state: false
            styles:
              custom_fields:
                graph:
                  [top: 75%, left: 0%, width: 100%, position: absolute]
            template: light
Then you can pretty much delete everything under content: >
{{ states('sensor.energy1') }} | {{ states('sensor.energy2') }}
It’s working.
Made a second card and placed it over the button-card. Read it anywhere in this thread. Didn’t know that I can implement it that way.
That way is very nice. Just finished the first version of my camera-card:
Use the picture-glance card here. Only the black bar on the bottom is annoying. Dont know how to get rid of that, or maybe another card, which can show me a regulary updated picture of a camera.
Thanks! Almost there, seem to have some issues with the alignment of the sensor/data.
            class: coronavirus
            style: {top: 93.65%, left: 70.2%}
            content: >
                <ha-icon icon="mdi:power-plug"></ha-icon> <b>Temperature</b>{{ break -}}
                <ha-icon icon="mdi:chart-bar"></ha-icon> <b>{{ states('sensor.aqara_temp_bedroom_temperature') }}</b> fall{{ break -}}
                <ha-icon icon="mdi:chart-bar"></ha-icon> <b>{{ states('sensor.aqara_temp_bedroom_humidity') }}</b> fall{{ break -}}
                </font>
Using Temperature sensors now to have some data to present, should work with other sensors I guess.
Help will be much appreciated!
It’s natively supported. Search camera.
How did you get the camera in there? :slight_smile:
Do you have the code for me please? I would then namely finish a popup when clicking so that it is then enlarged
I just changed to picture-elements-card like @Mattias_Persson mentioned above.
Also struggling with the state-badge. As far as I see, at least one element is neccessary, so o moved the badge out of sight. The best would be, to have a nice animated svg-icon to show motion.
            entity: camera.garten_kamera_hof
            show_entity_picture: false
            show_state: false
            style:
              top: 64.5%
              left: 55.18%
              width: 10%
            tap_action:
              action: more-info
            # hold_action:
            custom_fields:
              picture:
                card:
                  type: picture-elements
                  camera_image: camera.garten_kamera_hof
                  elements:
                    - type: state-badge
                      entity: binary_sensor.garten_kamera_hof_bewegung
                      style:
                        top: 20%
                        left: 15%
            styles:
              custom_fields:
                picture:
                  [top: -7%, left: -75%, width: 190%, position: absolute]
            template: base
The position of the custom_field “picture” is optimated to see the best area of the camera, because its widescreen and not square.
The option camera_view for the picture-elements-card should give you a live-view if you want that. But note that it will require the stream component.
Just add it unter camera_image
camera_view: live
I dont use that, because i disabled the stream component to prevent camera lags.
I meant just adding the camera
picture elements -> camera
You’re doing
picture elements -> button-card -> picture elements -> camera
I mean it works but it’s unnecessary
Hi, can somebody tell what am I missing? There’s clock somehow shifted up, the sidebar fonts are strange, and something missing in a middle of sidebar…
pls help mi.
how to solve this problem with updating time?
