Well quite embarrassing to tell you then that I have had Home Assistant for several years. I’m also a web developer. So codes are not strange to me. But for the record, just because I’m a developer myself doesn’t mean I develop everything I use. No need to invent the wheel several times.
And I haven’t gone this deep into Home Assistant that I know why “local” is “www”. But if that is something basic then, I guess I need to lookup the basic guide again.
Is it possible to edit the custom_fields of the custom button card config so that it will show battery level instead of brightness? I use the button to show the state of zigbee motion and door/window sensors and would like to be able to tell at a glance what the battery level is.
This is the part of the button that controls the brightness graphic, but my battery levels are actually their own sensor instead of being an attribute of the binary sensor. i.e The entity for the Laundry button in my screencap is named binary_sensor.laundry_window and the battery level is sensor.laundry_window_power. How would I go about editing the custom field to display the battery % instead of brightness?
FYI
I don’t know if you have seen it, but the sensor values for the Roborock have changed.
So in your sensors.yaml, it is now like this:
sensor.main_filter = sensor.filter_left
sensor.main_brush = sensor.main_brush_left
sensor.sensor = sensor.sensor_dirty_left
right_side_brush = sensor.side_brush_left
And then a question. My sensor.robot_last_clean, gives me this time format: 2021-04-01T14:27:37. I have your config, but would like something more clean. Has this also changed on your end?
Hello everybody!
First of all many thanks to the creator. After the classic lovelace and hadashboard i wanted to try something else for a new display in the kitchen…
I have been having fun with this for a few weeks, but I got stuck: clicking or holding a button does nothing. I must be missing sth quite obvious but cannot find what.
custom components are installed
the dashboard looks fine (state of lights are correctly displayed)
sure but what yaml you mean? it is the base code from the author with my devices/Entities (nothing changed besides this)
the unchanged buttons (like the sidebar (info, vacuum, update) also dont react when clicked
I have been fiddling back and forward: the hold action works and changes in the light template work (for hold action). It needs a restart though (clearing the browser is not enough).
so for instance:
hold_action:
action: toggle
works fine in the light template. So I conclude I am in the right place in the code
Adding the tap action inside the light template itself (and reverting hold action):
tap_action:
action: toggle
does not work either…
EDIT: (SOLVED for NOW) : deleting the sound part in the tap_action in the base template fixed it .
No i did not do what you want to do.I’m using template. Honestly i do not understand the « i do not like to use template » but whatever. Templates let you use the same code several time without making repetition.
Look what is defined inside a template (base for example) and add those lines at the end of the button definition
Good afternoon everyone!) @Mattias_Persson Thank you so much for your job!
I have such a question for everyone, sorry, maybe its a stupid…
What do I need to do to start using this lovelace panel design?
Copy all the files from github to the /hassio/homeassistant directory and then configure it for my system? Or do I need something else?
Please, write in detail!
Thank you in advance!
