Good time of day!
I have a question again.)
Following the recommendations, I copied all the files from github to my directories. I had to comment out a few lines in the files because it wouldn’t start. Now it started but gives errors. Custom element doesn’t exist: button-card.
Did you install the add-on wtih HACS ?
Go to Configuration / Lovelace Dashboards
In the TAB Resources, you need to have the following entry:
/hacsfiles/button-card/button-card.js
Thank you for your feedback!)
Yes, I have HACS installed.
And yes, in resources I have /hacsfiles/button-card/button-card.js
Now Installed - IOS Dark Theme
Auto-entities was installed, I removed it because it didn’t start … and after removing it, the cards appeared,
Please tell me if auto-entities need to be installed, or is it possible without it? Maybe one interferes with the other and there is a conflict between them?
Before that, I just copied the folders and files from github to the appropriate directories, without installing.
Then I installed the button-card, as they recommended to me
In the integrations, I installed browser_mod, I realized what was also needed so that there were no errors in the cards.
What else needs to be installed to display information from the start?
Because now like this …
And if possible, then briefly explain to me the logic of this all, well, or maybe there is a link to an explanation of the principle of interaction of elements. I just want to understand how it all interacts and what it needs and for what, so as not to ask you a lot of questions!)
Thanks a lot in advance!
Have you ever found a solution for a wide cameras?
I finished with aspect_ratio but it doesn’t look good imho
better to resize and trim, but cannot figure out how :\
Propably not the best solution and I still have the black bar at the bottom. But it works perfectly for me.
I can move the area of the camera image with the style of the custom field.
I really don’t understand why nothing works for me. No card is working. I have removed one after one to see if anyone will work. Right now I get a red box with
But the file is in HACS and I have also added lovelace-card-preload.js as suggested. Any suggestion of what I could try more?
