If an entity is unavailable, like on startup or whatever, lovelace throws red errors and this prevents that
What do you mean by started over again? I started building my dashboard after the last large update, so i should have all files up to date. I’m still trying to figure out what is going wrong, but i have no idea…
Oh, okay. I still have problems with integration. I installed dron hacs and manually. I’ll figure it out. It is very difficult to replicate what you did. I do not finish discovering everything. Thank you very much for sharing this project
Very thanks!!
Its working:
But maybe it’s asking too much. Is it possible to put the footer to pass infinitely? Otherwise just show me 2 or 3 games…
Hi everyone. How can I make the temperature look good on the different devices. What am I doing wrong? Thanks
icon_clima:
styles:
custom_fields:
temperature:
top: 84%,
right: 1%,
width: 80px,
height: 50px,
position: absolute,
letter-spacing: 0.03vw,
font-size: 2.2rem,
extra_styles: |
#temperature {
font-size: 6vw;
letter-spacing: 0.05vw;
/* portrait */
@media screen and (max-width: 1200px) {
#temperature {
font-size: 5vw;
/* phone */
@media screen and (max-width: 800px) {
#temperature {
font-size: 10vw;
top: 10%
Good morning.
my inner Monk is killing me
Where to find the settings to change the space between the buttons ?
Many thanks …
If I’m not mistaken, it’s in theme file
How do you remove the top strip where usually the names of the views are?
Hi guys,
I use an Ipad Pro 12.9 inches on the wall. The pop function is currently not working on all of my IOS devices. No matter which button I press, nothing happens. If I do this on the PC via Firefox, it works.
Does somebody has any idea?
Would you mind share your icons? I’am looking for a nice window icon since ever.
The rest is also nice and could be used on my dashboard. Especially heating, washing machine, carport, camera.
Hi is there any issues using watchtower getting unhealthy after update,
(HAsupervised Debian 11)
You need https://github.com/maykar/kiosk-mode and change your config to:
kiosk_mode:
hide_header: true
If you are using this but wants to edit your dashboard you can add “?disable_km” to your url.
for example:
https://ipaddress:8123/lovelace/0 --> https://ipaddress:8123/lovelace/0?disable_km
Hi Matthias. If I replace the footer sensor information with the button cards instead so i basically have 6 buttons under eachother I get a scroll bar on the right. Is there a way the dashboard will auto adjust the cards size in the grid to fit screen? It works fine in columns but not in rows. The cards height is controlled by aspect ratio? should i change this to hieght and width instead in procentage? hope you understand my issue and can advise.
i took the icons from here
Hey, @Mattias_Persson thanks again.
I’ve been using this method for a while in the visual ui editor (raw editor) and finally made the step to convert everything I have to all YAML.
I wanted to ask about the loader, do you think it’s possible to make it accept another entity (not the main card entity) as a variable, in order to decide when to stop the loading visual?
Right now it only stops according to the entity, but what if I want to set it to something else, for example, a script that turns on something, and the loader should relate to that something, even that card entity is the actual script.
Hope i’m clear.
I tried something like that but it doesn’t work:
if (variables.loader_entity !== undefined) {
let elt = this.shadowRoot;
const loader = (id, style, timeout) => {
if (elt.getElementById(id)) {
elt.getElementById(id).style.display = style;
window.setTimeout(() => {
elt.getElementById(id).style.display = timeout;
}, 20000)
loader('circle', 'none', 'initial');
loader('loader', 'initial', 'none');
maybe this old template will help? change it to if script is on return loader
https://github.com/matt8707/hass-config/blob/0547dffc849dedebe5a55d843fd8a106afba2653/button_card_templates.yaml#L107
It will not auto adjust. Change base template and grid card config
https://github.com/custom-cards/button-card#aspect-ratio
https://www.home-assistant.io/lovelace/grid/#square
I use it the other way around with no config changes so it defaults to no kiosk
url?kiosk
for homeassistant-desktop and fullykiosk
and the rest just url
so you don’t get locked out from ios app or whatever
I don’t think anybody here knows, create an issue from the watchtower repository
