Well, it was your idea. This makes the text scroll.
state_display: >
return `<marquee>${entity.attributes.football}<\marquee>`;
state_display: >
Where is ‘sensor.template_sidebar’ created, and how does it gets the values?
I can only see one mention of it with no other references
- type: vertical-stack
view_layout:
grid-area: sidebar
cards:
- type: custom:button-card
entity: sensor.template_sidebar
template: sidebar_template
Hi. I have to ask Again. If i change aspect to 4/1 and add square: true in grid it doesnt come together.
Just sharing the beginning of the code to keep it simple.
layout:
#default
grid-gap: var(--custom-layout-card-padding)
grid-template-columns: repeat(4, 1fr) 0
grid-template-rows: repeat(3, fit-content(100%))
grid-template-areas: |
"sidebar hverdagsrum opgaveliste media "
"sidebar temperatur picture_slide . "
"sidebar weather picture_slide . "
cards:
- view_layout:
grid-area: hverdagsrum
type: grid
title: Hverdagsrum
square: true
columns: 2
cards:
entity: light.spisebord
aspect_ratio: 4/1
It’s because square should be false
Perfect, fixed it … many Thx Mattias
Thanks. that pulls it up. But if i still want to maintain a ratio of 1/1. Do i then need to move away from aspect and do width and height procentage?
Where is there a call to template.yaml?
template.yaml
creates sensor.template_sidebar
entitysidebar_template
in button_card_templates.yaml
and sidebar_template
are defined in ui-lovelace.yaml
I clearly don’t get what you’re asking
aspect ratio = width/height%
Thanks, I mean where is the !include action for “template.yaml” file?
where is the place that tells this file to load
Haha. sorry for confusing you. i wanted to keep the aspect-ratio but at a smaller size.
i Thought i good adjust the custom layout grid to fit the cards style. So setting three rows at a specific height and the card would fit itself inside each row and not auto exspand grid so i get the scroller.
Does it give meaning what i am trying to explain? basically i want to make the layout fixed within the resolution size of the screen.
I guess so, you’re talking about grid-template-columns
and grid-template-rows
Use this https://grid-v1.layoutit.com/, I’d use fr/%
but if you really need it fixed use px
Did you used the icons as png oder svg?
If png, can you show me your code how you implemented png as icons?
I use the png
state:
- value: 'on'
entity_picture: \local\img\icons8-scoop-beleuchtung-48.png
color: rgba(255,255,255,0.9)
- value: 'off'
color: rgba(65,65,63,0.8)
styles:
card:
- filter: opacity(50%)
icon:
- filter: grayscale(100%)
Can sombody explain why this does not work? I wont show the entity_picture.
entity: cover.garage_tor
tap_action:
action: toggle
hold_action:
action: more-info
show_entity_picture: true
entity_picture: \local\img\icons8-closed-window-48.png
template:
- base
base:
variables:
state: >
[[[ return entity === undefined || entity.state; ]]]
timeout: >
[[[ return entity === undefined || Date.now() - Date.parse(entity.last_changed); ]]]
light_color: >
[[[ return entity === undefined ? 'var(--state-icon-color)' : 'var(--button-card-light-color-no-temperature)'; ]]]
consider_on: >
var state = entity === undefined || entity.state;
return (
state == 'on' ||
state == 'home' ||
state == 'cool' ||
state == 'fan_only' ||
state == 'playing'
aspect_ratio: 1/1
show_state: true
show_icon: false
state_display: >
[[[ if (variables.state === true) return 'Unbekannt'; ]]]
tap_action:
ui_sound_tablet: |
const screensaver = states['switch.dashboard_screensaver'] === undefined ||
states['switch.dashboard_screensaver'].state;
if (variables.state === 'off' && screensaver === 'off') {
hass.callService('media_player', 'play_media', {
entity_id: 'media_player.browsermod_dashboard_fullykiosk',
media_content_id: '/local/sound/on.m4a',
media_content_type: 'music'
if (variables.state === 'on' && screensaver === 'off') {
media_content_id: '/local/sound/off.m4a',
animation_card: |
const animation_speed_ms = 900;
const animation = `card_bounce ${animation_speed_ms}ms cubic-bezier(0.22, 1, 0.36, 1)`;
this.shadowRoot.getElementById("card").style.animation = animation;
window.setTimeout(() => {
this.shadowRoot.getElementById("card").style.animation = "none";
}, animation_speed_ms)
action: toggle
haptic: medium
styles:
grid:
- grid-template-areas: |
"icon circle"
"n n"
"s s"
- grid-template-columns: repeat(2, 1fr)
- grid-template-rows: auto repeat(2, min-content)
- gap: 2%
- align-items: start
name:
- justify-self: start
- line-height: 115%
state:
- line-height: 115%
card:
- font-family: Sf Display
- border-radius: var(--custom-button-card-border-radius)
- -webkit-tap-highlight-color: rgba(0,0,0,0)
- transition: none
- padding: 10%
- --mdc-ripple-color: >
return (variables.state === 'on' || variables.state === 'home' || variables.state === 'open') ?
'rgb(0, 0, 0)' :
'rgba(255, 255, 255, 0.3)';
- color: >
'rgba(0, 0, 0, 0.6)' :
- background-color: >
'rgba(255, 255, 255, 0.8)' :
'rgba(115, 115, 115, 0.2)';
extra_styles: |
if (entity) {
let hs = entity.attributes.hs_color == undefined;
let h = hs || entity.attributes.hs_color[0];
let s = hs || entity.attributes.hs_color[1];
let l_min = 28;
let l_max = 48;
let l_calc =
((entity.attributes.brightness / 2.54) * (l_max - l_min)) / 100 + l_min;
var light_color =
entity.attributes.color_mode === 'color_temp'
? `hsl(204, 58%, ${l_calc}%);`
: `hsl(${h}, ${s}%, ${l_calc}%);`;
return `
svg {
--light-color:
${ variables.state === 'on' && entity.attributes.brightness != undefined
? light_color
: variables.state === 'on' && entity.attributes.brightness == undefined
? 'var(--state-icon-active-color);'
: 'var(--state-icon-color);'
#name, #state {
font-size: 1.34vw;
letter-spacing: 0.05vw;
/* portrait */
@media screen and (max-width: 1200px) {
#name, #state {
font-size: 2vw;
/* phone */
@media screen and (max-width: 800px) {
#name, #state {
font-size: 3.1vw;
letter-spacing: 0.12vw;
@keyframes card_bounce {
0% {
transform: scale(1);
15% {
transform: scale(0.9);
25% {
30% {
transform: scale(0.98);
100% {
Because I do not make use of img_cell
or i
. In that grid area I use the custom_fields
icon
This is without altering the grid
custom_fields:
icon: >
<img src="/local/*.png" width="100%">
and like this if you really need entity_picture
entity_picture: /local/*.png
styles:
grid:
"i circle"
"n n"
"s s"
Now it is working. Thought it would be something with the grid, but didnt get it.
Can you please write a short manual on your github repo for neccessery steps for installation process? Thanks
