Anyone know which theme this is in the postās screenshot?
Could you release this or help us get this theme? It looks so much better than the default UI. Is it a theme?? Please ![]()
@mtrista That is the āSectionsā view and the it is showing cards that have been converted to the new standard. Read the whole orginal post about the new āSectionsā view.
As mentioned that new Sections view is still experimental but you can try it out and how-to do so is covered by that post above at the top.
If it is still unclear then I suggest you follow some of the many guide videos already available on YouTube:
I meant the theme, I already knew about the sections view and using them right now. I do appreciate the help though. Apparently the theme Iām talking about is a proof of concept from @madelena and isnāt available anywhere yet
Is it possible to delete badges or buttons that are added to a section? I can see where to delete a whole section, but if I add a button by accident or add a badge at the top, I donāt see a way to just remove that element.
The three dots in the above right corner when you select a card.
Oh interesting - every theme I was using was making that small 3-dot menu almost invisible. Switched to āno themeā and itās clearly right there Thank you!
Is it possible to outline sections with a border or add a grey background to each section, so that the secions are also recognized as sections (like in the old mansory view for each card).
I we were capable to āoutlineā the section and/or have a dedicated background, this could be an alternative to stacking card to group some cards together.
I wish we could modify the number of āspacesā in a section. By default we are presented with 4 slots, from which we select the desired width. But letās say I want to place 3 buttons side by side in a section. I am only able to place 1 big button, or 2 normal buttons or 4 tiny buttons, but not able to add 3. Sections should have a parameter of max slots.
I want a section that looks like this:
Only solution I found to that is to add a grid card with three columns.
At the moment I canāt even get four tiles next to each other.
We are currently working on a solution to provide more resizing precision to handle this type of issue.
Any way to increase the columns on the Google Nest Hub from 2 columns to 3?
On the latest version of the HA Companion App, there is a new setting to change the page zoom level. Reducing the level will allow you to show more columns on the screen.
That feature has been there for as long as I can remember. Doesnāt change the usefulness. I always run at 85%
How would you do this on the Google Nest Hub when itās just casting? There is no settings.
I was trying out the new sections layout and noticed a small error in the display of a card. Didnāt see anywhere on the forum to file this kind of bug so thought Iād put it here. When the browser window is full-size it shows the error. When I resize it goes away. Returning to full-size displays the error again.
Have you tried viewing it with another theme? If the problem persists, the correct location to file an issue is on the HA Frontend Github repo.
No, this is with the default theme. I have no other themes installed. Iāll check it out and file a bug there then. Thanks!
Looking for a solution as well, has someone solved this by now?
