Tadies
(Tadies)
April 9, 2024, 2:22pm
1
Im not sure if this is the proper place to post…
But im looking for a hand concerning outset in theming…
In card_mod you could use:
card_mod:
style: |
ha-card {
border: 2.5px outset lime !important;
I did try to get this working strait on the theme.yaml
Without the card_mod…
The borders etc works fine
But somehow the outset i can’t figure out to work…
Like it would show on cards with help of the card_mod
Anyone has an idea if this ever will work?
Thank You…
If I understand your question correctly, you want to apply card_mod within the theme with the parameters applied to each card?
If so, some tips are:
The theme MUST define a variable card-mod-theme
which MUST have the same value as the name of the theme.:
my-awesome-theme:
card-mod-theme: my-awesome-theme
... other theme variables go here ...
Place the card mod variables at the bottom of the theme document, with 2 indentations, so it becomes a child of your theme name.
Apply the card theming variables to the: card-mod-card section.
See for more info on the above details the Wiki that Thomas made for card-mod:
## Themes
More to come. In the mean time, see [the Wiki](https://github.com/thomasloven/lovelace-card-mod/wiki/Card-mod-Themes).
### card-mod-theme
This is very important!
The theme MUST define a variable `card-mod-theme` which MUST have the same value as the name of the theme.
Eg:
```yaml
my-awesome-theme:
### Theme variables
This file has been truncated. show original
I hope that helps!
Tadies
(Tadies)
April 9, 2024, 5:37pm
3
hi Heijit771…
thank for your reply…
ya got it almost right tho!
and your tip is useful aswell! (kuddo’s for that!)
but i was trying to avoid the card_mod
i only posted that code cause on card_mod it works fine…
what im trying to do is add it in theme.yaml itself…
without the card_mod…if possible
i wanted only to get the outset part working…
Not sure I will be able to help with that. Sorry…
But out of curiosity, why not just use the card-mod inside the theme.yaml?
It works fine if you use the following in your theme…
card-mod-card: |
ha-card {
Please check out the following guide and reference Themes
Tadies
(Tadies)
April 10, 2024, 5:49pm
6
Thank You to LiQuid_cOOled !
it looks like it’s the only way to get that outset
working…
keep on rocking !
( can’t give 2 solutions tho! lol )
Tadies
(Tadies)
7
No Wurry’s Heijit771!
appreciated ur help too!
kuddo’s!
