It’s a USB-C cable, connected to a USB 3.0 hub I use daily. The small end of the USB-C cable goes into the Onn speaker connector, and the 5VDC is tapped directly from those two points on the board, where the cable is soldered. Both the Vcc and GND connections feed a pair of Wago lever-nut connectors, where ALL power and ALL grounds are connected. So while it seems like it could be a ground loop, it’s not very likely.
Let me get a few things managed here around the house, and I’ll post it shortly. Be aware, I have turned down the brightness settings in the control_led
routine at the bottom of the code.
substitutions:
# ESPHome Device Name
device_name: 'vasst-living-room'
device_friendly_name: 'Voice Assistant Living Room'
# Voice Assist phase IDs
voice_assist_idle_phase_id: '1'
voice_assist_listening_phase_id: '2'
voice_assist_thinking_phase_id: '3'
voice_assist_replying_phase_id: '4'
voice_assist_not_ready_phase_id: '10'
voice_assist_error_phase_id: '11'
voice_assist_muted_phase_id: '12'
# P A R T S L I S T
# Small Rugged Speaker with Bluetooth Wireless Technology, Blue
# https://www.walmart.com/ip/onn-Small-Rugged-Speaker-with-Bluetooth-Wireless-Technology-Blue/883044562
# AITRIP ESP32-S3-DevKitC-1-N16R8 Development Board
# https://www.amazon.com/dp/B0CGYXJB6Y
# KWMSTPLT WS2812B RGB LED Strip
# https://www.amazon.com/dp/B09P8MH56K
# Max98357 I2S 3W Class D Audio Amplifier
# https://www.amazon.com/dp/B0B4GK5R1R
# INMP441 I2S Microphone Module MEMS
# https://www.amazon.com/dp/B09G4RNT3G
# GPIO pin assignments
# Validated according to
# https://www.studiopieters.nl/esp32-s3-wroom-pinout/
# I2S audio thanks to
# https://dronebotworkshop.com/esp32-i2s/
i2s_in_lrclk_gpio: 'GPIO4' # INP Left/Right Clock 4 YELLOW
i2s_in_bclk_gpio: 'GPIO5' # INP Bit Clock 5 ORANGE
i2s_in_mic_gpio: 'GPIO6' # INP Digital Data 6 BLUE
ws2812_led_gpio: 'GPIO18' # LED strip 18 GRAY
i2s_out_lrclk_gpio: 'GPIO15' # OUT Left/Right Clock 15 YELLOW
i2s_out_bclk_gpio: 'GPIO16' # OUT Bit Clock 16 ORANGE
i2s_out_spkr_gpio: 'GPIO10' # OUT Digital Data 10 PURPLE
esphome:
friendly_name: $device_friendly_name
platformio_options:
board_build.flash_mode: dio
# Startup - init the LED strip and phase ID
on_boot:
priority: 600
then:
- script.execute: control_led
- delay: 30s
- if:
condition:
lambda: return id(init_in_progress);
then:
- lambda: id(init_in_progress) = false;
psram:
mode: octal
speed: 80MHz
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
framework:
type: esp-idf
components:
- name: esphome_board
source: github://jesserockz/esphome-esp-adf-board@main
refresh: 0s
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_AUDIO_BOARD_CUSTOM: "y"
# Logging
logger:
level: VERBOSE
# Enable Home Assistant API
api:
encryption:
key: !secret encryption_key
# toggle the LED on HA connect and HA disconnect
on_client_connected:
on_client_disconnected:
# Allow Over-the-air firmware updates
ota:
password: !secret ota_password
# WiFi ssid and password
wifi:
ssid: !secret wifi_ssid
# toggle the LED on WiFi connect and WiFi disconnect
on_connect:
on_disconnect:
# ESP-ADF audio component
esp_adf:
external_components:
- source: github://pr#5230
components:
- esp_adf
refresh: 0s
# Establish a device web page
# for recovery via WiFi
captive_portal:
# WS2812 LED Strip
light:
- platform: esp32_rmt_led_strip
chipset: WS2812
rgb_order: GRB
pin: $ws2812_led_gpio
num_leds: 3
rmt_channel: 0
default_transition_length: 0s
effects:
- pulse:
transition_length: 800ms
update_interval: 800ms
min_brightness: 0%
max_brightness: 30%
- pulse:
transition_length: 250ms
update_interval: 250ms
min_brightness: 50%
max_brightness: 100%
- pulse:
transition_length: 100ms
update_interval: 100ms
min_brightness: 50%
# I2S Audio IN and OUT
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: $i2s_in_lrclk_gpio
i2s_bclk_pin: $i2s_in_bclk_gpio
- id: i2s_out
i2s_lrclk_pin: $i2s_out_lrclk_gpio
i2s_bclk_pin: $i2s_out_bclk_gpio
# INMP441 I2S INPUT Microphone
microphone:
platform: i2s_audio
adc_type: external
i2s_audio_id: i2s_in
i2s_din_pin: $i2s_in_mic_gpio
pdm: false
# MAX98357a IS2 OUTPUT Amplifier
speaker:
platform: i2s_audio
dac_type: external
i2s_audio_id: i2s_out
i2s_dout_pin: $i2s_out_spkr_gpio
# ESPHome Voice Assistant
voice_assistant:
microphone: INMP441_I2S_MICROPHONE
speaker: MAX98357_I2S_AMP
use_wake_word: true
noise_suppression_level: 4
auto_gain: 31dBFS
volume_multiplier: 8.0
on_listening:
- lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
on_stt_vad_end:
- lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
on_tts_stream_start:
- lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
on_tts_stream_end:
- lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
on_error:
- if:
condition:
lambda: return !id(init_in_progress);
then:
- lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
- delay: 1s
- if:
condition:
switch.is_on: use_wake_word
then:
else:
- lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
- if:
condition:
then:
- voice_assistant.start_continuous
else:
- lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
switch:
name: Use Wake Word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
- if:
condition:
then:
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- if:
condition:
then:
- voice_assistant.stop
globals:
- id: init_in_progress
type: bool
restore_value: no
initial_value: 'true'
- id: voice_assistant_phase
type: int
restore_value: no
initial_value: ${voice_assist_not_ready_phase_id}
script:
- id: control_led
then:
- if:
condition:
then:
- if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- lambda: |
switch(id(voice_assistant_phase)) {
case ${voice_assist_listening_phase_id}:
id(led).turn_on().set_rgb(1, 0, 0).set_brightness(0.3).set_effect("none").perform();
break;
case ${voice_assist_thinking_phase_id}:
id(led).turn_on().set_rgb(1, 0, 0).set_effect("slow_pulse").perform();
break;
case ${voice_assist_replying_phase_id}:
id(led).turn_on().set_rgb(1, 0, 0).set_brightness(0.3).set_effect("fast_pulse").perform();
break;
case ${voice_assist_error_phase_id}:
id(led).turn_on().set_rgb(1, 1, 1).set_brightness(0.3).set_effect("none").perform();
break;
case ${voice_assist_muted_phase_id}:
id(led).turn_off().perform();
break;
case ${voice_assist_not_ready_phase_id}:
id(led).turn_on().perform();
break;
default:
id(led).turn_on().set_rgb(1, 0, 0).set_brightness(0.2).set_effect("none").perform();
break;
else:
- light.turn_off:
else:
- light.turn_off:
else:
- light.turn_on:
blue: 30%
red: 30%
green: 30%
effect: "fast_pulse"
You’ve inspired me to put my Wyoming Satellite based system in a couple of the Onn Surf Speakers along with an additional Bluetooth adapter to make portable powered speakers out of them. I may do a video and take pictures of the project and share them.
I also have yet to see a bt speaker or soundbar set in bt mode which doesn’t turn itself off after some amount of idle time, for that matter. This has been my experience when trying to use them as media player targets for tts notifications over the past 5 years. Maybe you will have better luck.
In case you didn’t know, I’m hoping you find the magic incantation of GPIO pin assignments that resolves the amplifier noise with this ESP32-S3 board. I spent today shortening wires, soldering, and removing the Wago connectors, but haven’t finished getting it fully assembled yet. Won’t know if it helps until I do.
Try moving the i2s_bclk_pin for Audio out to pin 20
I have no audio noise but cant get the microphone to work…
I’ve wondered if it was working. The noise from the amp was so bad, I’d keep pulling the power. Sometimes, it seems like it takes forever to connect to Home Assistant. Hopefully, shortening the wires and your suggestion provide results. Thanks for that!
EDIT: Reviewing the INM441 microphone connection: The L/R
signal at the MIC is tied to GND
, and not to the I2S Input channel. What is available is the WS Word Select
signal connected to I2S Input. The ESPHome I2S Audio page describes WS
as the LRCLK
signal. I’m testing the new wiring this morning, and will update with any details as I get them.
I can confirm your suggestion to eliminate the amp noise worked. It’s as quiet as can be now. Even with the MIC configuration updated, it does not appear to be working correctly.
More tracing, more troubleshooting to go . . . MIC wiring confirmed okay with a multi-meter, all pins show connectivity from the MIC to the ESP32. Hrmmm, so why isn’t it detecting any voice input? I set log_level: DEBUG
and don’t see anything no matter what wakeword is spoken. These are my current pin assignments. Note I changed the name of
i2s_in_lrclk_gpio
to follow the MIC pin name, and it’s now i2s_in_ws_gpio
i2s_in_ws_gpio: 'GPIO4' # INP WordSelect/LRCLK 4 YELLOW
i2s_in_bclk_gpio: 'GPIO21' # INP Bit Clock 21 ORANGE
ws2812_led_gpio: 'GPIO18' # LED strip 18 BLUE
i2s_out_bclk_gpio: 'GPIO20' # OUT Bit Clock 20 ORANGE
i2s_out_spkr_gpio: 'GPIO10' # OUT Digital Data 10 BLUE
So, this Espressif ESP32-S3 I2S page shows code samples using the following pin assignments:
.gpio_cfg = {
.mclk = I2S_GPIO_UNUSED,
.bclk = GPIO_NUM_4,
.ws = GPIO_NUM_5,
.dout = I2S_GPIO_UNUSED,
.din = GPIO_NUM_19,
.invert_flags = {
.mclk_inv = false,
.bclk_inv = false,
.ws_inv = false,
Trying these pin assignments now… First attempt, no change. Second attempt, still no change. Suspecting something in the ESP32-S3 code may possibly be amiss with I2S Audio?
The table of pin you posted was a little off based on your code.
GPIO 32 is connected to LRCLK.
GPIO 12 is connected to DIN.
The audio output is not always clear. It studders. Any thoughts on why that might happen? Also, at some points when trying to play the response the system never gets back to a state where it is waiting for the wake word. When this happens the LEDs just keep flashing blue. Below shows the log when this happens.
[12:29:57][D][voice_assistant:519]: Event Type: 9
[12:30:02][D][voice_assistant:519]: Event Type: 0
[12:30:02][D][voice_assistant:519]: Event Type: 2
[12:30:02][D][voice_assistant:609]: Assist Pipeline ended
[12:30:02][D][voice_assistant:412]: State changed from STREAMING_MICROPHONE to WAIT_FOR_VAD
[12:30:02][D][voice_assistant:418]: Desired state set to WAITING_FOR_VAD
[12:30:02][D][voice_assistant:170]: Waiting for speech...
[12:30:02][D][voice_assistant:412]: State changed from WAIT_FOR_VAD to WAITING_FOR_VAD
[12:30:02][D][voice_assistant:183]: VAD detected speech
[12:30:02][D][voice_assistant:412]: State changed from WAITING_FOR_VAD to START_PIPELINE
[12:30:02][D][voice_assistant:418]: Desired state set to STREAMING_MICROPHONE
[12:30:02][D][voice_assistant:200]: Requesting start...
[12:30:02][D][voice_assistant:412]: State changed from START_PIPELINE to STARTING_PIPELINE
[12:30:02][D][voice_assistant:433]: Client started, streaming microphone
[12:30:02][D][voice_assistant:412]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[12:30:02][D][voice_assistant:519]: Event Type: 1
[12:30:02][D][voice_assistant:522]: Assist Pipeline running
[12:30:02][D][voice_assistant:519]: Event Type: 9
[12:30:05][D][voice_assistant:519]: Event Type: 10
[12:30:05][D][voice_assistant:528]: Wake word detected
[12:30:05][D][voice_assistant:519]: Event Type: 3
[12:30:05][D][voice_assistant:533]: STT started
[12:30:05][D][light:036]: 'Status LED' Setting:
[12:30:05][D][light:051]: Brightness: 100%
[12:30:05][D][light:059]: Red: 0%, Green: 0%, Blue: 100%
[12:30:07][D][voice_assistant:519]: Event Type: 11
[12:30:07][D][voice_assistant:670]: Starting STT by VAD
[12:30:08][D][voice_assistant:519]: Event Type: 12
[12:30:08][D][voice_assistant:674]: STT by VAD end
[12:30:08][D][voice_assistant:412]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[12:30:08][D][voice_assistant:418]: Desired state set to AWAITING_RESPONSE
[12:30:08][D][voice_assistant:412]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[12:30:08][D][light:036]: 'Status LED' Setting:
[12:30:08][D][light:059]: Red: 0%, Green: 100%, Blue: 0%
[12:30:08][D][light:109]: Effect: 'slow_pulse'
[12:30:08][D][esp-idf:000]: I (102738) I2S: DMA queue destroyed
[12:30:08][D][voice_assistant:412]: State changed from STOPPING_MICROPHONE to AWAITING_RESPONSE
[12:30:10][D][voice_assistant:519]: Event Type: 4
[12:30:10][D][voice_assistant:547]: Speech recognised as: " Turn on Porch lamp."
[12:30:10][D][voice_assistant:519]: Event Type: 5
[12:30:10][D][voice_assistant:552]: Intent started
[12:30:10][D][voice_assistant:519]: Event Type: 6
[12:30:10][D][voice_assistant:519]: Event Type: 7
[12:30:10][D][voice_assistant:575]: Response: "Turned on the light"
[12:30:10][D][voice_assistant:519]: Event Type: 8
[12:30:10][D][voice_assistant:595]: Response URL: "https://ha.connectionblocks.com/api/tts_proxy/104c89b5f9053e4751d03002aab527c96124bd77_en-us_d6114071a7_tts.piper.wav"
[12:30:10][D][voice_assistant:412]: State changed from AWAITING_RESPONSE to STREAMING_RESPONSE
[12:30:10][D][voice_assistant:418]: Desired state set to STREAMING_RESPONSE
[12:30:10][D][esp-idf:000]: I (105191) I2S: DMA Malloc info, datalen=blocksize=512, dma_buf_count=8
[12:30:10][D][i2s_audio.speaker:164]: Started I2S Audio Speaker
[12:30:11][D][voice_assistant:347]: Speaker buffer full, trying again next loop
[12:30:11][D][voice_assistant:519]: Event Type: 99
[12:30:11][D][voice_assistant:665]: TTS stream end
[12:30:11][D][voice_assistant:283]: End of audio stream received
[12:30:11][D][voice_assistant:412]: State changed from STREAMING_RESPONSE to RESPONSE_FINISHED
[12:30:11][D][voice_assistant:418]: Desired state set to RESPONSE_FINISHED
There were no more debug messages printed out after this point until I power cycled the device. I could turn off the wake word and have the LED stop flashing blue, then turn it back on to solid red, but this didn’t start audio processing. Do you experience this issue? Any thoughts on how to address it?
A couple of the ones I made I had to change a couple pins.
The speaker buffer full is what is causing that. I dont know why it happens, but it happens much less using OpenAi as the conversation agent.
Im able to query some pretty long responses from OpenAI and not have that issue.
I did notice before I switched to OpenAI, that it was doing it less often. Hopefully its an issue that will be fixed soon.
I’ve been chatting with @robgough1970 in the ESPhome discord, and had to update a few things today. He told me the trick to getting the MIC input is to add channel: left
to the I2S Microphone config.
Another error popping up (due to ESPhome 2024.2.0, apparently) requires changes to the esp32:
section:
esp32:
variant: esp32s3
framework:
type: esp-idf
version: recommended
sdkconfig_options:
CONFIG_ESP32_S3_BOX_BOARD: "y"
Hi Keith,
just so you have another pinout to confuse matters even more ! This is my goto for the ESP32-S3-N16R8
i2s_audio:
- id: va_mic
i2s_lrclk_pin: GPIO3
i2s_bclk_pin: GPIO2
- id: va_spk
i2s_lrclk_pin: GPIO6
i2s_bclk_pin: GPIO7
microphone:
platform: i2s_audio
adc_type: external
i2s_audio_id: va_mic
i2s_din_pin: GPIO4
channel: left
pdm: false
speaker:
platform: i2s_audio
dac_type: external
i2s_audio_id: va_spk
i2s_dout_pin: GPIO8
that is with an inmp441 mic and the Max98357 DAC
No issue with noise and get clear audio input from the mic
Cheers
Rob
I found a thread where someone indicated that they got better audio out by disabling wake word detection during play back. They controlled this on the HA side. I couldn’t see figure out exactly what they were doing so I figured I’d try to adjust things on the ESP side. I made a couple of small changes to the code as follows. First I added a disable of wake word detection in the voice_assistant section.
on_tts_start:
- switch.turn_off: use_wake_word
- delay: .25s
This turns off wake_word detection, however the delay didn’t have the desired effect. Ideally the delay would give a little time for wake word detection to be turned off. I added a web interface and I could see the wake word switch, but it happened at the same time the audio stated playing, As a result the initial part of the playback has a studder, but after the initial studder, playback was normally clear. If anyone has any insight into how to get this delay in place that would be helpful.
Next I added two to the on_tts_stream_end action so it looked like this:
on_tts_stream_end:
- delay: 1s
- switch.turn_on: use_wake_word
This turns wake word detection back on after playback.
This did not fix the issue with the system failing to complete playback and return to wait word detection state periodically.
I was hoping to be able to try things on an M5StampS3. Here is the yaml I attempted to use:
substitutions:
esphome:
friendly_name: voice satellite eps32 S3 test
on_boot:
priority: 600
then:
- delay: 30s
- if:
condition:
then:
esp32:
framework:
type: esp-idf
# Enable logging
logger:
api:
encryption:
key: !secret api_key
ota:
wifi:
ap:
ssid: "voicething"
# Enable Web server.
web_server:
port: 80
captive_portal:
# restart-button
button:
- platform: restart
esp_adf:
components:
- esp_adf
refresh: 0s
light:
rgb_order: GRB
pin: GPIO3
num_leds: 3
rmt_channel: 0
chipset: WS2812
effects:
- pulse:
min_brightness: 0%
max_brightness: 30%
- pulse:
min_brightness: 50%
- pulse:
min_brightness: 50%
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: GPIO15
i2s_bclk_pin: GPIO13
- id: i2s_out
i2s_lrclk_pin: GPIO11
i2s_bclk_pin: GPIO09
microphone:
platform: i2s_audio
adc_type: external
i2s_din_pin: GPIO7
pdm: false
bits_per_sample: 32bit
speaker:
platform: i2s_audio
dac_type: external
i2s_dout_pin: GPIO5
mode: mono
voice_assistant:
microphone: external_microphone
speaker: external_speaker
use_wake_word: true
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 2.5
on_tts_start:
- delay: 1s
on_listening:
on_stt_vad_end:
on_tts_stream_end:
- delay: 1s
on_error:
- if:
condition:
then:
- delay: 1s
- if:
condition:
then:
else:
- if:
condition:
then:
else:
switch:
name: Use Wake Word
optimistic: true
on_turn_on:
- if:
condition:
then:
- if:
condition:
not:
then:
on_turn_off:
- if:
condition:
then:
globals:
type: bool
restore_value: no
type: int
restore_value: no
script:
- id: control_led
then:
- if:
condition:
then:
- if:
condition:
wifi.connected:
then:
- if:
condition:
api.connected:
then:
- lambda: |
id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("none").perform();
break;
id(led).turn_on().set_rgb(0, 1, 0).set_effect("slow_pulse").perform();
break;
id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("fast_pulse").perform();
break;
id(led).turn_on().set_rgb(1, 1, 1).set_brightness(.5).set_effect("none").perform();
break;
break;
break;
default:
break;
else:
- light.turn_off:
else:
- light.turn_off:
else:
- light.turn_on:
blue: 50%
red: 50%
green: 50%
This gives the following errors:
INFO ESPHome 2023.12.8
INFO Reading configuration /config/esphome/voice-satellite-eps32-s3-test.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/5230/head
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Updating https://github.com/espressif/[email protected]
INFO Updating submodules (components/esp-sr, components/esp-adf-libs) for https://github.com/espressif/[email protected]
INFO Compiling app...
Processing voice-satellite-eps32-s3-test (board: esp32-s3-devkitc-1; framework: espidf; platform: platformio/[email protected])
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
- framework-espidf @ 3.40405.230623 (4.4.5)
- tool-cmake @ 3.16.9
- tool-ninja @ 1.10.2
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.4
|-- ArduinoJson @ 6.18.5
Compiling .pioenvs/voice-satellite-eps32-s3-test/components/audio_board/lyrat_v4_3/board_pins_config.o
components/audio_board/lyrat_v4_3/board_pins_config.c: In function 'get_i2c_pins':
components/audio_board/lyrat_v4_3/board_pins_config.c:39:34: error: 'GPIO_NUM_23' undeclared (first use in this function); did you mean 'GPIO_NUM_43'?
i2c_config->scl_io_num = GPIO_NUM_23;
GPIO_NUM_43
components/audio_board/lyrat_v4_3/board_pins_config.c:39:34: note: each undeclared identifier is reported only once for each function it appears in
components/audio_board/lyrat_v4_3/board_pins_config.c: In function 'get_i2s_pins':
components/audio_board/lyrat_v4_3/board_pins_config.c:54:33: error: 'GPIO_NUM_25' undeclared (first use in this function); did you mean 'GPIO_NUM_45'?
i2s_config->ws_io_num = GPIO_NUM_25;
GPIO_NUM_45
In file included from /data/cache/platformio/packages/framework-espidf/components/esp_rom/include/esp32s3/rom/ets_sys.h:19,
from /data/cache/platformio/packages/framework-espidf/components/log/include/esp_log.h:19,
from components/audio_board/lyrat_v4_3/board_pins_config.c:25:
components/audio_board/lyrat_v4_3/board_pins_config.c: In function 'i2s_mclk_gpio_select':
components/audio_board/lyrat_v4_3/board_pins_config.c:95:53: error: 'FUNC_GPIO0_CLK_OUT1' undeclared (first use in this function); did you mean 'FUNC_GPIO20_CLK_OUT1'?
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_GPIO0_CLK_OUT1);
/data/cache/platformio/packages/framework-espidf/components/soc/esp32s3/include/soc/soc.h:136:45: note: in definition of macro 'REG_WRITE'
(*(volatile uint32_t *)(_r)) = (_v); \
/data/cache/platformio/packages/framework-espidf/components/soc/esp32s3/include/soc/io_mux_reg.h:93:46: note: in expansion of macro 'REG_SET_FIELD'
#define PIN_FUNC_SELECT(PIN_NAME, FUNC) REG_SET_FIELD(PIN_NAME, MCU_SEL, FUNC)
components/audio_board/lyrat_v4_3/board_pins_config.c:95:13: note: in expansion of macro 'PIN_FUNC_SELECT'
components/audio_board/lyrat_v4_3/board_pins_config.c:98:53: error: 'FUNC_U0TXD_CLK_OUT3' undeclared (first use in this function); did you mean 'FUNC_U0TXD_CLK_OUT1'?
PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0TXD_U, FUNC_U0TXD_CLK_OUT3);
components/audio_board/lyrat_v4_3/board_pins_config.c:98:13: note: in expansion of macro 'PIN_FUNC_SELECT'
In file included from components/audio_board/lyrat_v4_3/board.h:29,
from components/audio_board/lyrat_v4_3/board_pins_config.c:28:
components/audio_board/lyrat_v4_3/board_pins_config.c: In function 'get_green_led_gpio':
components/audio_board/lyrat_v4_3/board_def.h:42:35: error: 'GPIO_NUM_22' undeclared (first use in this function); did you mean 'GPIO_NUM_42'?
#define GREEN_LED_GPIO GPIO_NUM_22
components/audio_board/lyrat_v4_3/board_pins_config.c:186:12: note: in expansion of macro 'GREEN_LED_GPIO'
return GREEN_LED_GPIO;
components/audio_board/lyrat_v4_3/board_pins_config.c:187:1: error: control reaches end of non-void function [-Werror=return-type]
cc1: some warnings being treated as errors
Archiving .pioenvs/voice-satellite-eps32-s3-test/esp-idf/audio_hal/libaudio_hal.a
Compiling .pioenvs/voice-satellite-eps32-s3-test/components/audio_pipeline/audio_event_iface.o
Compiling .pioenvs/voice-satellite-eps32-s3-test/components/audio_pipeline/audio_pipeline.o
Compiling .pioenvs/voice-satellite-eps32-s3-test/components/audio_pipeline/ringbuf.o
*** [.pioenvs/voice-satellite-eps32-s3-test/components/audio_board/lyrat_v4_3/board_pins_config.o] Error 1
Compiling .pioenvs/voice-satellite-eps32-s3-test/components/audio_recorder/recorder_encoder.o
========================= [FAILED] Took 12.74 seconds =========================
I didn’t configure the pins it’s complaining about, so they must be hard coded in the voice assistant esp code. Any thoughts on how to get past this error?
Can you post yoiur full config? Im getting nowhere with this board…
That config doesnt work with the board you are using.
this is one with micro wake word - just trying to dig one out that hasn’t got a load of other waffle in it - that’s the most basic one i can lay my hands on at the mo
esphome:
platformio_options:
on_boot:
- script.execute: idle_pg
esp32:
variant: esp32s3
framework:
type: esp-idf
sdkconfig_options:
psram:
mode: octal
speed: 80MHz
logger:
ota:
wifi:
api:
then:
- delay: 50ms
- micro_wake_word.start:
then:
- voice_assistant.stop:
button:
- platform: restart
switch:
optimistic: true
on_turn_on:
- micro_wake_word.stop:
- homeassistant.service:
service: select.select_option
option: Heartbeat
entity_id: select.tree_lamp_preset
on_turn_off:
option: ok
i2s_audio:
- id: i2s_mic
i2s_bclk_pin: GPIO2
- id: i2s_spk
i2s_bclk_pin: GPIO7
microphone:
platform: i2s_audio
adc_type: external
i2s_audio_id: i2s_mic
i2s_din_pin: GPIO4
channel: left
pdm: false
speaker:
platform: i2s_audio
dac_type: external
i2s_audio_id: i2s_spk
i2s_dout_pin: GPIO8
micro_wake_word:
model: hey_jarvis
on_wake_word_detected:
- voice_assistant.start:
- script.stop: idle_pg
- display.page.show: va_pg_wk
option: wake
service: media_player.play_media
media_content_id: media-source://media_source/local/vad.mp3
media_content_type: music
entity_id: media_player.tree_media
voice_assistant:
microphone: va_mic
# speaker: va_spk
noise_suppression_level: 2.0
volume_multiplier: 10
on_error:
- display.page.show: va_pg_err
on_stt_end:
- display.page.show: va_pg_ok
option: ok
on_end:
then:
- wait_until:
not:
voice_assistant.is_running:
option: flame
on_tts_end:
media_content_id: !lambda 'return x;'
announce: "true"
forgot there’s this one here too kahrendt_micro_wake_word/obww_esp32_s3_mic_and_speaker.yaml
try adding this to your esp32: component
sdkconfig_options:
Three steps forward…
- MIC is working with your pin assignments (slightly shifted, see below).
i2s_in_ws_gpio: 'GPIO2' # INP WordSelect/LRCLK 2 YELLOW
i2s_in_bclk_gpio: 'GPIO3' # INP Bit Clock 3 ORANGE
i2s_in_mic_gpio: 'GPIO4' # INP Digital Data 4 BLUE
ws2812_led_gpio: 'GPIO20' # LED strip 20 BLUE
i2s_out_lrclk_gpio: 'GPIO6' # OUT Left/Right Clock 6 YELLOW
i2s_out_bclk_gpio: 'GPIO7' # OUT Bit Clock 7 ORANGE
i2s_out_spkr_gpio: 'GPIO8' # OUT Digital Data 8 BLUE
- ESPhome logs are displaying on the USB/Serial port used to load the firmware (see YAML below).
logger:
level: DEBUG
hardware_uart: uart0
- This is the most progress with this board in days, and I’ll gladly take that.
Positive progress is a wonderful thing for motivation.
Later observation: When powering the ESP32 board from the USB port of my computer, the MIC is working, and the wake word is detected. When powering the ESP32 board using the 5Vin and GND pins, it’s not. Very wonky.
This sounds entirely like the LDO voltage regulator is delivering insufficient voltage or current, a problem previously seen on many D1mini clone boards.It’s marked 1117c, which is supposed to be the good LDO VR component. Except it’s limited to 800 mA, which is too low for the MAX98357 audio amplifier, honestly.
