This could be a new feature of HomeAssistant! You should submit it @claudio…
Ok, got it working. So, i guess, compared to Alexa what is cooler on Google?
IMO the interaction with Google is way better then with Alexa-Echo.
Plus you have Chromecast integration, multi-user support, and multi-room audio (when google will implement it for the pi too)
If you use lower powered raspberry +mic+ speaker is cheaper then 50$ Alexa
i installed it just now to test.
i saw i could use snowboy for a wakeword, but i dont know how
i was browsing through the code a bit searching for where google waits for an enter, but i cant find it so fast.
is there an option that it starts listening and the programm ends after the reply?
that way i could create a commandline switch in HA that makes google listen to me.
yes please, at least we can start using it from now, without waiting Google code. The code is not lonbg so I guess is not too difficult to identify what tio do.
Should be at line 190\
while True:
if wait_for_user_trigger:
click.pause(info='Press Enter to send a new request...')
conversation_stream.start_recording()
it starts listening after you see the text “Press Enter to send a new request…”, and after you press enter it stays in listening mode
i want to change the “Press enter” and use a HA switch for that
yes, exactly!
and it works on a pi zero. I guess we could have 20$ google home in every room
oke, i see it now.
in the assistant there is a line
that makes the assistant wait.
so i guess i could create my own function and use that to let the assstant wait for any action i like.
i am gonna create a input_boolean and a small appdaemon app.
after that i should be able to ask Alexa to make google listen to me
yeah knowing how to code I think is not difficult, awaiting your efforts.
I saw snowboy instructions, way too complicated for me. I rather wait the switch code, or google wake word code
check this
Trigger the Assistant
Modify the sample code to control when to trigger an Assistant request (for example, at the push of a button). Triggering an Assistant request is done by sending a request to EmbeddedAssistant.Converse.
trying to see how to make it works on windows PC, and android device, so we can use our HASS with voice from a smartphone …
@anon35356645 I managed to get Google Assistant talking to me on my iMac.
I’d imagine it’s a similar process to this for a Windows PC too?
I guess but don’t find any link
you know how to? Any progress?
No, my HA runs in a virtual server (Ubuntu - Hyper-V) on my main server at home. The Google is on a RPi.
yeah i created an app and can fire the google assistant with an input_boolean now.
but i have run into a few problems, because i did install the google assistant in a virtual env.
so i ended up installing a second appdaemon in that environment.
i will test some more and then upload it to github.
Did you add the emulated_hue entities through the google home app? I got google home working on the rpi3 but can’t find a way to add lights/swtiches.
The Google documentation says you need a real Home to set services like Hue, same reason you can’t do it with just Assistant and Home app on a phone.
