Working on getting aarlo setup but no matter what Ii try, I cant get the 2fa to work. Wondering if I’m missing something. Logs and config Config I’ve got is:
unable to connect to Arlo: attempt=1,sleep=15,error=authentication failed
unable to connect to Arlo: attempt=2,sleep=30,error=2fa startup failed
unable to connect to Arlo: attempt=3,sleep=60,error=authentication failed
my config looks the same and was working unit today. I restored from a back up of yesterday and still nothing. I did get a 2FA email yesterday, but I don’t know where to enter the code in HA. The Arlo Glances cars so the signal strength, battery level, etc but the image is broken link.
i can log in to the My arlo website with the same creds and everything looks great, but then it kicks me:
You have been logged out because you logged in from another device.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/connection.py:89
Integration: Home Assistant WebSocket API ([documentation](https://www.home-assistant.io/integrations/websocket_api), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+websocket_api%22))
First occurred: 12:27:10 PM (12 occurrences)
Last logged: 12:32:50 PM
* [140117938316912] Received invalid command: aarlo_library
* [140117937485184] Received invalid command: aarlo_library
* [140117712345168] Received invalid command: aarlo_library
I am facing a similar issue. 2FA notifications over push are not being sent to the conigured device
2021-11-21 15:25:43 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140098016537856] Received invalid command: mobile_app/push_notification_channel
2021-11-21 15:25:43 WARNING (SyncWorker_0) [pyaarlo] error in new response={'meta': {'code': 400, 'error': 9233, 'message': 'Authentication is not finished yet'}}
2021-11-21 15:25:43 WARNING (SyncWorker_0) [pyaarlo] 2fa finishAuth - tries 1
2021-11-21 15:25:43 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 12.3 seconds
2021-11-21 15:25:43 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for melcloud integration not ready yet; Retrying in background
2021-11-21 15:25:43 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.5 seconds
2021-11-21 15:25:43 INFO (Thread-10) [roombapy.roomba] Connecting to Roomba roomba.home.creative-innovation.net
2021-11-21 15:25:43 INFO (MainThread) [homeassistant.setup] Setup of domain camera took 1.7 seconds
2021-11-21 15:25:44 INFO (MainThread) [homeassistant.components.camera] Setting up camera.mjpeg
2021-11-21 15:25:44 ERROR (MainThread) [homeassistant.components.binary_sensor] The octoprint platform for the binary_sensor integration does not support platform setup. Please remove it from your config.
2021-11-21 15:25:44 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.octoprint
2021-11-21 15:25:44 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.octoprint
2021-11-21 15:25:44 ERROR (MainThread) [homeassistant.components.sensor] alpha_vantage: Error on device update!
I have the same issue as well, I had the push setup working before but it stopped working a while back and I could never get the gmail app password to work either.
I had this working fine after setting the app password in google but now it seems to have mysteriously stopped working. Anyone else have this problem, not sure it it relates to the new Home Assistant OS updates recently?
