jcastro
(Jonatan)
April 30, 2016, 11:08pm
1
Currently I have 4 z-wave devices, 2 sensors (same model) and 2 lights (also same model). Current names are the following:
binary_sensor.aeotec_zw100_multisensor_6_sensor_6
binary_sensor.aeotec_zw100_multisensor_6_sensor_7
light.domitech_smart_led_retrofit_kit_ze27eu_level_4
light.domitech_smart_led_retrofit_kit_ze27eu_level_5
It would be great if I can rename sensors to easy identify them, like:
binary_sensor.kitchen_motion
binary_sensor.porch_motion
light.kitchen_light
light.porch_light
Thanks!
dap35
May 1, 2016, 2:06am
2
Take a look at .homeassistant/zwcfg…xml
IF you stop HA, then you can edit this file and add more meaningful names and locations
This now translates to light.kitchen_dimmer_level_9
kophinos
(kophinos)
May 1, 2016, 5:46am
3
You can also edit your devices names using OZWCP setup guide here , and either copy the zwcfg…xml into the .homeassistant directory, or be fancy and symlink them.
Just found this in a sample config in the docs. Haven’t tested this myself yet, but might be what you’re looking for.
customize: switch.aeon_labs_smart_energy_switch_switch_2: friendly_name: Mac Switch-Meter
But then you can’t use switch.Mac_Switch-Meter as an entity ID.
You will want to use OZWCP or modify ozwcfg…xml in order to rename Z-Wave devices.
jcastro
(Jonatan)
May 4, 2016, 11:13pm
6
thanks guys, will take a look!
