Shut down hass and manually update the entries in the zwcfg_xxx.xml file in the root of your HA configuration directory. The xxx will be the hex ID of your zwave network.
Shut down hass and fire up ozwcp and make the changes in there and save to file. Then you’ll need to copy the zwcfg_xxx.xml file back into the HA configuration directory before restarting hass.
