Hi all,
Following on from my Actron QUE Local project, I’ve now put together Actron NEO Local Cloud, a Home Assistant app for local control of ActronAir NEO systems.
The aim is the same: keep air-conditioning control in Home Assistant working without relying on Actron’s cloud service or an internet connection.
How it works
The NEO normally connects to Actron’s Nimbus service and exchanges commands and status over MQTT. This app provides a local replacement for those services.
A DNS override directs the NEO’s requests for nimbus.actronair.com.au to your Home Assistant host. The app then handles the controller’s connection locally and bridges commands and status through the Mosquitto broker. Devices and entities appear automatically through MQTT Discovery—there’s no separate custom integration to install.
Despite “Cloud” in the name, the replacement service runs locally on your network.
Features
- Main climate control with operating mode, target temperature, fan speed and live heating/cooling/idle status.
- Quiet, Turbo, Away and Continuous Fan controls, where supported.
- Enable or disable the NEO’s existing schedule from Home Assistant.
- Zone climate entities, with temperature, humidity and airflow controls according to the capabilities reported by your system.
- Outdoor temperature, humidity, compressor power and speed, indoor fan RPM, filter and defrost status.
- Additional engineering and diagnostic entities, disabled by default so you can enable only those you want.
- Automatic discovery of connected NEO systems.
- Native status updates, supplemented by local refreshes approximately every 5 seconds while on and 30 seconds while off.
Available controls and sensors depend on the connected equipment and zone configuration. The Schedule switch enables or disables the stored NEO schedule; it does not edit its events.
Installation
For Home Assistant OS installations, use the button below to open the app in your Home Assistant instance:
The button opens the app page; installation and network configuration still need to be completed.
- Install and start the Mosquitto broker app, and confirm the MQTT integration is working.
- Install Actron NEO Local Cloud and set
local_ipto your Home Assistant host’s reserved LAN IP address. - Keep the default network mappings:
443/tcp → 443and8883/tcp → 28883, withneo_mqtt_port: 28883. - Start the app, and allow the NEO controller(s) to reach the Home Assistant host on TCP 443 and 28883. Port 443 must be available for the app.
- On the DNS server used by the NEO, point
nimbus.actronair.com.auto your Home Assistant LAN IP. - Reconnect or reboot one NEO first. Once its full status is received, Home Assistant creates its devices and entities automatically.
You need control of your network’s DNS configuration, or equivalent source-specific network redirection. The full setup guide includes network examples, expected logs and troubleshooting.
If adding the repository manually, its URL is:
https://github.com/JCalvi/HASSAddons
Things to know
This replaces the NEO’s connection to Actron’s cloud. Expect cloud-dependent access, including NEO Connect remote access, to be unavailable for controllers using the local service.
Actron firmware updates are not served by the local replacement. To use Actron’s normal firmware update service, temporarily restore the controller’s normal DNS/network path.
A network-wide DNS override can also affect the official Actron Air cloud integration. Disable that integration while using the local replacement, or use source-specific redirection if both need to coexist.
Source and feedback
Actron NEO Local Cloud on GitHub
I’d be interested to hear how it works with other NEO installations, particularly different outdoor units and zone configurations. Please share your results here, or report an issue on GitHub with your controller firmware, system details and relevant logs. Remove any personal details or credentials before posting logs.
Hopefully this is useful to other NEO owners who would like to keep their air-conditioning control local!
