Adaptive Cover in degraded mode waiting for some upgrade… i
n.b. French translation HERE
Last update : 2025-04-27
For the attention of users of this superb integration v1.4.5 from @basbruss, which nevertheless has some incomprehensible and confusing glitches, particularly in “Climate” mode, here’s how I worked around its few “teething problems” to achieve efficient and satisfactory operation of my roller shutters and BSO…
Let’s hope that @basbruss will soon give us the gift of a new version… This integration is truly of great interest and great potential; it would be a shame to stop there.
Here is a French translation of the logic diagram developed by @basbruss to better understand what this integration can offer us.
First, we’ll stick with Basic Mode, which allows you to adjust the height of the shutters to keep the sun out of your eyes, on your desk, or in the room.
A - Vertical roller shutter in BASIC MODE only
It’s best to stick to the values ​​below to fully understand how this integration works (and any temporary weaknesses).
Stick to a single roller shutter until you’ve mastered all the functions, otherwise you might end up tearing your hair out like I did… Ideally, whenever possible, you should choose the one located where you work to immediately see how the shutter reacts to the changes made on the computer.
Prerequisite for this integration, which really lacks clear explanations:
  • a shutter at 100% means 100% open
  • a shutter at 0% means 0% open, therefore closed
After installing the integration and choosing Vertical Blind as the shutter type, let’s move on to the configuration.
a1 - Configuration - Vertical Cover Tab
  • Climate Mode: OFF
  • Entity: the vertical roller shutter
  • Window Height: the height of the roller shutter
  • Shaded area: 1.0 m to start (this is the theoretical horizontal distance*** between the outer edge of the shutter and the boundary between sun and shade at the bottom of the shutter).
  • Window Azimuth: azimuth of the shutter’s facade
  • Default position: default position of the shutter if it is not (azimuth or elevation) in the sun zone. Mini position ≤ Default position ≤ Maxi position
  • Maximum position: 100%
  • Minimum position: 0%
  • Minimum elevation: 3 to 5°
  • Left field of view: 85°
  • Right field of view: 85°
  • Sunset position: 50% - This is the position of the shutters after sunset. Mini ≤ Sunset position ≤ Maxi
  • Inverse the state: do not check
  • Setup Blindspot: do not check
  • Set custom open/close positions…: do not check!
a2 - Settings - Options tab
  • Starting time: 7:0:0
  • Manual reset override duration: check
  • End time: 23:0:0
  • Always adjust position to sunset…: check
  • Leave the other options at default
a3 - Dashboard
At this point, we can now import the corresponding entities into a section that will allow us to view and control all the roller shutters in a single table.
  • The top left tile displays the current position of the roller shutter, the top right tile displays the position calculated by Adaptive Cover, its default position, its sunset position, and its left and right field views.
  • Next are the active and passive entities of the roller shutter for Basic mode.
a4 - How it works
  • if the sun is within the window’s field of view and its elevation in the sky is higher than the defined Minimum Elevation of the Sun, then the shutter adopts the calculated position to obtain the desired Shaded Area.
  • otherwise, the shutter adopts the default position.
  • or the Sunset Default position if it is nighttime (between sunset and sunrise).
Unless Adaptive Cover is disabled (Switch Toggle Control), the shutter’s position will always be calculated to avoid sun exposure, provided the sun is within the window’s field of view (azimuth and elevation) and between the set start and end times. And this applies regardless of the weather, whether it’s sunny or not!
For those like me who live in the Paris region, lucky enough to have three days of sunshine every three months, this Basic Mode will allow them to configure their shutters regardless of the weather! :rofl: :rofl: :rofl:
Depending on the settings you define, the shutter, outside the calculated period or if the integration is stopped, can remain in its calculated position, its default position, or after sunset.
We’ll see that Climate Mode fortunately allows for further automation, not without some teething problems that will need to be worked around. However, in parallel with Adaptive Cover’s actions, it will still be necessary to supplement the shutter movement with HA or Node Red automations in the early morning, during the day, in the evening, or at night, in the event of a prolonged absence.
a5 - Definition of Shaded Area
As can be seen in these sectional views, the Shaded Area is the horizontal distance between the outer edge of the shutter at the bottom of the window and the beginning of the shaded area in the room at the same level. In other words, if you want to protect your office work surface from the sun’s rays, as in the example on the left, you’ll have to do some trial and error to find the right value.
The major problem is that the time it takes for the shutter to unfold its slats until they uncover the bottom of the window and finally open (10 to 12%) is not taken into account.
As a result, the opening calculation will position the shutter at different heights depending on whether you start with a fully open or closed shutter.
Hence the need to play with the Shaded area parameter to find the best compromise.
Note: It seems that the “Set custom open/close positions…” option allows you to correct these discrepancies, but all my attempts have yielded inconsistent results, with interference on other parameters, especially since any input in this option is then impossible to erase.
a6 - Manual Override
Manual Override Duration allows you to set the time after which the shutter will return to the calculated position after a manual operation.
e.g.: you open the shutter to go out onto the terrace; you have 15 minutes before the shutter returns to its calculated position.
To do this, the Manual Override switch must be set to ON. If you want to return to the calculated position without waiting for the override period to elapse, press Reset Manual Override, but you must first select Reset Manual Override Duration in the Options tab.
Feel free to run all the necessary simulations and adopt your own settings when you are satisfied and fully reassured about the shutter’s operation.
For a BSO, you will need to create a Vertical Blind and a Tilted Blind. You will notice that changing the position of one interferes with the other. Good news, I read that @basbruss is working on merging the two services into one
B - CLIMATE MODE - Triggers
Now that your shutters are correctly configured in Basic Mode, let’s focus on Climate Mode so that it provides maximum functionality despite its current limitations.
As with Basic Mode, only work on one shutter until you have fully mastered Climate Mode.
Several triggers are available to improve shutter automation:
b1 - Indoor Temperature Sensor (°C)
Generally the room thermostat
b2 - Indoor Comfort Temperature Range
In this temperature range (between minimum and maximum comfort), the Control Method will be in Intermediate mode. Otherwise, it will be in Summer or Winter mode.
b3 - Outdoor Temperature Sensor (°C)
Replaces the Weather Services sensor if used.
b4 - Summer Mode Switch Threshold (°C)
Triggers the switch to Summer mode (shutter 100% closed).
b5 - Presence/Absence Switch
In the event of unoccupancy (Presence entity), the integration logically assumes that there is no need to calculate the Shaded Area. The shutter will therefore be set to the Default value, Sunset default, 100% open, or 100% closed, depending on whether the sun is in its field of view or whether the indoor temperature is outside the defined comfort range.
  • Personally, I prefer to strengthen shutter management in the event of unoccupancy with Node Red and integrate it with existing automatic alarms (short absences, daily absences, long absences, night mode, etc.). * Although this is an option, it’s preferable to create an input_boolean.on_presence that will always be visible and actionable in the Dashboard.
b6 - Exterior light sensor (lux)
When it comes to managing shutters to avoid being bothered by the sun, this measure is completely ineffective!
Indeed, while the illumination of direct sunlight at sunrise, sunset, or at its zenith can vary from 400 to 120,000 lux, that of a cloudy sky facing away from the sun can reach 10 to 25,000 lux.
It’s difficult, under these conditions, to trust a lux meter…
  • We will therefore not use this trigger as such, but for lack of anything better, we will use this function in another way…
  • To do this, we will create a lux meter - input_number.lux_virtuel (range 1,000 to 10,000 - with a step of 1,000) to replace the outdoor lux meter.
b7 - Outdoor brightness trigger (lux)
Minimum brightness at which the Lux function will be applied.
b8 - Weather services (cloud cover and outdoor temperature)
It’s also difficult to fully trust real-time weather services to rely on forecasted weather conditions.
The information transmitted (sunny, partly cloudy, clear) is too imprecise and often delayed over time. * I therefore chose not to use this trigger in this degraded mode, but we’ll see later that it can remain a backup option.
  • Let’s keep in mind, however, that this trigger also provides the local outdoor temperature, information that will be replaced by an Outside Temperature Sensor if used.
b9 - Irradiance Measurement (W/m2)
This is certainly the most effective trigger for measuring sunlight on the facade, thanks to the installation of a pyranometer.
A device connected to an ESP32 via RS485 that I plan to install. I’ll come back to it later (unless other users with the device can tell us about the effectiveness of such a device…)
b10 - Transparent Blind
I refuse to translate this option until I’m sure I understand it! Initially interpreted as an option for curtains (sheers), here it’s more a matter of making the position calculation transparent (neutralizing it). In any case, it’s impossible to find the slightest explanation for this function, which will also be useful to us later.
Everything is now ready to take care of the climate in degraded mode.
Set the Climate switch to ON** in the Fine tune Blind settings tab and proceed to configuring all these triggers!
C - CLIMATE MODE - Settings
If you have changed them in the meantime, retrieve the recommended settings for the Basic Mode test (see a1 and a2)
c1 - Fine-tune Blind Settings tab
  • Set the Climate Mode switch to ON
c2 - Climate settings tab
  • Inside temperature entity: insert the room temperature sensor
  • Low temperature threshold: 17°C
  • High temperature threshold: 28°C
  • Outside temperature sensor: insert the outdoor temperature sensor
  • Minimum outside temperature for summer mode: 30°C
  • Presence entity: insert the ON Presence button (see b1)
  • Lux sensor: insert the virtual lux meter (see b2)
  • Lux threshold: 4,000 lux
  • Irradiance sensor: - (unless you have a pyranometer connected, in which case the Luxmeter trigger is useless)
  • Irradiance threshold: 300 W/m2 by default
  • Transparent blind: ON
  • Weather entity: -
c3 - Triggers
  • Set the virtual lux meter to 2,000 lux
c4 - Dashboard Display
  • Complete your map with the 3 switches Vertical Climate Mode, Vertical Lux, and Vertical Outside Temperature
Your vertical shutter dashboard should now look like this:
D - CLIMATE MODE - Logic Diagram and Operation
Let’s summarize: At this point, we have seen that Basic Mode alone allows, within the defined time limits, Azimuth, and Sun Elevation, but regardless of the weather, whether there is sun or not!, to position the shutters to protect against the sun. Direct illumination.
The Climate Mode, with the Presence Mode switch still set to ON, will now allow us to check the current situation (the Control Method entity):
  • Intermediate: the indoor temperature is below the Comfort range and the brightness (Lux) is above the reference value (green circuit on the diagram - theoretically sunny weather). We’re back in Basic Mode, but we’ve taken brightness into account, even though this value isn’t significant (for the moment)…
  • Winter: the brightness is lower than the setpoint (theoretically very overcast), the indoor temperature is below the Mini Comfort setting, but the sun is shining through the window. We open the shutter 100% to let the heat in.
  • Summer: the indoor temperature is above the Comfort setting and Transparent Blind is checked. We close the shutter to prevent heat from entering the room. Otherwise, we return to Basic Mode.
Notes:
  • An inserted Weather (Weather Station or Weather Services) will replace the Brightness (Lux) sensor!
  • The outdoor temperature sensor will replace the indoor temperature sensor in the calculations if the Outside Temperature switch is enabled!
  • I still have so much trouble understanding this term Transparent, but it works…
  • I deliberately set a wide comfort range (17°C - 28°C) to avoid seeing the shutters automatically close or open 100%. You’re then free to choose the right range depending on the room.
The Usefulness of the Virtual Lux Meter
Without a connected pyranometer, which we’ve seen is apparently the only reliable sensor capable of calculating the shutter position to protect the room from sunlight beyond the Shaded Area, we’ll have to do it manually (or vocally with Assist).
d1 - Sunny Period
  • Switch Vertical Climate mode to OFF
  • Switch Vertical Lux to OFF
Climate Mode is disabled; the calculation is done in Basic mode only. The shutter position is calculated to respect the Shaded Area.
d2 - Cloudy Period
  • Switch Vertical Climate mode to ON
  • Switch Vertical Lux to ON
Climate Mode is activated, the brightness of the virtual lux meter (2,000 lux) is below the Lux threshold (4,000 lux), and the room temperature is within the comfort range.
The shutter adopts the default position!
In both cases, the position calculations outside of the time slots and after Sunset are respected.
n.b.: the lux values ​​declared in this tutorial are arbitrary and allow you to simulate a period of time without sun. You could therefore just as easily choose 30 lux and 20 lux. The main thing is that the amount of lux allowing the calculation to be triggered in Climate mode (4,000) is greater than that of the virtual sensor (2,000) so that the calculation returns to Basic mode
Does manual intervention mean Degraded Mode? Actually, not so much, since again, without irradiance measurement (W/m2), the shutter’s behavior is unreliable!
Let’s summarize:
  • You have a connected pyranometer: that’s perfect, you don’t need the virtual lux meter or the weather trigger.
  • You’re not too demanding about the information transmitted by your weather station: remove the Lux Group from the Climate Mode Group and use Weather.
  • Otherwise, switch to manual degraded mode as described above and let Assist help you!
E - Dashboard Optimization
Once you’ve mastered these behaviors, you can add all your shutters by choosing your own settings. Finally, to have a Dashboard that allows you to control all the panels and interact effectively with all the parameters, you still need to create Entity Groups to control them for all the panels at once:
  • Group Toggle Control
  • Group Lux
  • Group Climate and Lux ​​(in which we add Climate Mode and Group Lux)
  • Group Manual Override
So, to switch from a sunny period to an overcast period, you simply need to activate the Climate and Lux ​​Groups.
Add a few well-chosen tiles (Switch Presence, Sun Azimuth, Sun Elevation, Outdoor Temperature, Indoor Temperature, etc.) to feel like a captain aboard an Airbus A-380!!!
F - Let’s go further with Climate Mode
All roller shutters now operate in degraded mode with a virtual lux meter, which requires systematic manual intervention (remember that we still don’t have a pyranometer):
  • it’s sunny: Climate mode is OFF
  • it’s cloudy: Climate mode is ON
We’re going to replace the light information with the climate conditions from a weather station. As we saw previously, this is far from reliable in real time, but it’s better than unsuitable light information.
f1 - Weather Station (Weather entity)
To do this, in the Climate settings tab, enter the Weather entity with the station of your choice and leave only Sunny as the condition to trigger the calculation, as other probable sunshine conditions (partly cloudy, cloudy, etc.) remain far too random.
By default, we now leave the Climate mode switch set to ON and set the Virtual lux meter to 5,000 lux (>4,000).
  • As long as the weather information is correct, the roller shutters protect against glare on sunny days or assume their default position on cloudy days.
  • Otherwise, deactivate the Climate switch while the information is wrong.
Please note:
  • Weather entity provides the cloud cover status (sunny) AND the outdoor temperature at the station location.
  • If an outdoor temperature sensor is also registered in Outside temperature sensor, this will be used for the calculations.
If you’re lucky enough to live in a very sunny region, you’ll have very little manual intervention required.
Here are the main functions of this integration, with some functions and/or additional details will be added later. In any case, please feel free to share your comments, suggestions, and/or experiences.
Thank you for your attention,
patrickp78
What is a roller shutter door..?
I don’t understand your question. I’m talking about a vertical blind, but maybe I mistranslated it.
For your convenience, I’ve included the complete English version of the tutorial in the original post.
The French diagrams will be translated later.
patrickp78
Fantastic write-up, thanks!
In your research with this plugin, did you discover how it handles temperature units (F vs. C) with respect to climate mode and temperature entities? I set up one blind, thought I had it figured out, and then when I enabled climate mode and input my temperature values from my thermostat and weather entities, nothing behaved as expected.
I reset the whole thing and I’ve left climate mode off for now until I can find an answer.
I am in the US, and my thermostat is set in F°, and my weather entity (OpenWeatherMap) is delivering data in F°, so I first tried just translating my temperature ranges into C°, but the plugin closed the blinds to 100% even though it should have put them into basic mode (presence was either set to TRUE or not set at all). Then I tried setting my temp ranges to F° values, but same result.
Any clues? I sure hope the creator can step in at some point and make some updates. It’s a reall fantastic use-case for HA and logical control.
In the parameter description, @Basbruss specified a temperature range of 0 to 86° (30°C) with a default of 21 (70°F) and 25 (77°F).
Therefore, I think you just need to decide whether you want to enter the values ​​in °C or °F and not try to convert them!
Obviously, if one of your sensors is not in the unit you decided to work with, that won’t’walk
After testing Adaptive Cover in Basic mode alone, as in my tutorial, choose a roller shutter as a test and apply the values ​​from my Step-by-Step in “degraded” Climate mode. You’ll see that everything works correctly.
Then, you can add the weather station information as an additional step.
I’ll complete my tutorial soon…
patrickp78
For your information, I’ve added another calculation option in Climate mode with Weather entity (§ F and f1).
I had my own automations to control the Venetian blinds and only recently discovered this promising Adaptive Cover integration.
However, I am lost regarding how it is supposed to work with the Venetian blinds: I expect it to control both vertical position and the tilt of the slates.
Googling a lot, I understand now:
  • I have to create a service for vertical blinds to control the vertical position.
  • I have to create another service for Venetian blinds to control the tilt only.
  • I have a single entity cover.bedroom_roller_shutter understanding both cover.set_cover_position and cover.set_cover_tilt_position, however, this integration cannot operate one entity with two services, so I have to create a template for a new tilt entity.
EDIT: Okay, I understand now that the abreviation “BSO” used by OP is a french term for Venetian blinds and that Adaptive Cover integration does not support their full operation (vertical and tilt adjustments within one service) yet. It would be good if this is added to the GitHub README :slight_smile:
Hi @archont00 ,
First of all, BSO means in french “Brise Soleil Orientable”, the same thing than a Venetian blind but for outside.
Effectively, I read @basbruss had as project to fix a BSO (or Venetian blind) as a same entity to control tilt and vertical, but for now, we must work with two entities.
An other problem is one bug between these two entities. When one of them is modified by the Adaptive Cover calculation, the other is often put on Manual mode. So I made an little .yaml automatism to avoid any stop when that happens…
Unfortunally, the GitHub Read Me is terribly poor ans @basbruss doesn’t anymore at questions, the reason of my personal tutorial
Hello!
i’m pretty new to Home Assistant and i found this project - but i’m not sure if this is the right approach for me. this is my cover definition:
cover:
  - name: "Büro"
    move_long_address: "2/2/36"
    stop_address: "2/2/35"
    position_address: "2/2/37"
    position_state_address: "2/2/114"
    move_short_address:  "2/2/35"
    angle_address: "2/2/38"
    angle_state_address: "2/2/115"
so i guess this is what you call a BSO.
what i would like to do:
  • when sun is shining on that window and irradiance above treshold > position 0% (closed), angle_position = 0% (open)
  • when sun is not shining on the window or irradiance is under treshold > position 100% (fully open), angle position = 0% (open)
i just wand my shutters to be open or closed, with slates always open. no need for a calculated position. i don’t need other climate settings (presence, outside temp…)
is this integration the right solution for me or are there simplers solutions?
i know exactly at which azimuth values every shutter should be open or closed.
could you explain more?
best regards
Hi @daHouse,
From your description, you have KNX shutters… just like me!
I find it a shame that you don’t want a more comprehensive automation system to adjust the shutter height and slat orientation, for example to protect a houseplant from direct sunlight, but hey, if that’s your choice…
In that case, I don’t think you need this app.
I recommend instead creating your automation with Node Red (it’s a very visual Home Assistant integration). It will be much easier and you’ll be able to take into account all the parameters you need:
  • Start and end times (or sunrise and sunset)
  • The position of the sun relative to the facade
  • Irradiance level (W/m2) if you have a pyranometer
  • Weather conditions
With all these parameters, you’ll be able to decide whether your shutter and slats should be open or closed.
Regards
patrickp78
i’ve already implemented this in openhab and i’m happy without calculated positions.
would i have to to this for every window?
Whichever app you use, it’s up to you whether you want to control your shutters by facade or individually…
i’ve tried some things with one of my shutters and it looks like it can do just what i need. the only thing that i still need to figure out is how to combine vertical + tilt.
you mentioned that you do this with a yaml file.
could you elaborate that part?
best regards
oh man, now i’ve encountered another problem…
between sunset and sunrise vertical works as expected (position = 0%), but tilt continues to set calculated position (at the moment 89%) when it should be 2%.
settings for vertical and tilt:
:thinking:
Hello Patrick, I was getting crazy in the past 4 days to configure my BSO till I read this comment. At least I know that I’m not doing something wrong :grimacing:
Anyway, my BSOs don’t move at all with the integration (vertical or tilt). The solution with two entities works, or is it better to wait for the fixed release?
Do you know if there is a tutorial to make them work?
Thanks for your help :slight_smile:
Hi, sorry for this delay…
Configuring the BSO in tilt mode is a little more fiddly, but when it’s in vertical mode, it works correctly like a roller shutter.
If nothing works, you need to go through the settings step by step, following the logic diagram and starting by eliminating the Climate mode.
How do you guys handle “sleep mode” with this?
I have a house mode entity and obviously cover automations should only work while I’m awake.
I currently use node-red-contrib-sun-position which supports setting different rules and conditions but doesn’t look like it can be done with this?
you use also KNX? I’m having trouble that i don’t see the entity of my KNX shutter in the CloudCover interface. How did you get those entities in there? A Zigbee shutter is no problem, that is the only one that appears.
Any ideas?
